sound system
Old 12-26-2002, 07:50 PM
starbrite996's Avatar
sound system
i've already replaced the 6 by 9's and i now i'm lookin to get a sub and a new head unit, would i have to replace the front speakers? and how much work would all of this be?
starbrite996 is offline
Old 12-26-2002, 10:49 PM
subs1000w's Avatar
you dont have to replace them but if you want better sound you should,especialy considering you hear more from them than your rears and if your adding an aftermarket radio you should definitly bypass the bose amps and its not hard at all just run new speakerwire to all 4 speakers and hookit up the the aftermarket radios wiring harness or go all out and bu a 2 or 4 channel amp for the speaker and run the wire from the speakers directly to the amp that way you can have the speakers on highpass for the best clarity
subs1000w is offline
Old 01-04-2003, 08:12 AM
i have an amp to go with it that's 220, should i go higher or would that just be stupid? and how high can i go without gettin another battery?
Old 01-04-2003, 11:27 AM
mtcookson's Avatar
you don't need to run new wires, just cut the two small wires that are going into the bose speaker. you will need to extend the wires a little bit by adding some but that's not that hard at all, way easier than running new wires.
mtcookson is offline
Old 01-04-2003, 03:44 PM
Soul Fly
REALLY - you have 4x6 in the front right? get infinity kappas for those...YOU CAN INSTALL them yourself. EASY!! there's nothing but screws holding the door panel in. get an audiobahn sub w/ rockford amp. Good prices for great products.
Old 01-04-2003, 04:03 PM
maxdout92se's Avatar
when i was having my 4 channel pioneer amp looked at, i bought a sony xplod 9?? 4 channel amp until i got it back and tha sound was beautiful....on top of that, my subs 760 watts were connected too and all this on an auotzone battery...lights didn't dim or anything....from what i've heard, just use a lil bigger gauge wire and you should be ok, but with 220, you're more than fine...no new/added battery needed!!
maxdout92se is offline
Miket2006
03-01-2021 03:55 AM
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: sound system
