Error code p0110
Error code p0110
I got this and the knock sensor code p0325 I did a search and found a good thread on leads for the knock sensor on the 0110 code I am a little confused is it the IAT or an o2 sensor?
the failed smog test gave me my codes. the exact reading was p0110 IAT CKT malfunction
is this a common problem replacement or does it just need a simple cleaning.
I would not be surprised if it was an o2 sensor since I have a dead cyl which is putting excess HCs to the sensor
97 SE 5spd with 113k
Re: Error code p0110
P0110 = DTC 0401
http://forums.maxima.org/showthread....sensor+circuit
Search results for 0401:
http://forums.maxima.org/search.php?...der=descending
Good luck.
ok so I don't know how to read my ohmmeter I have it set at the 200k ohm setting and it says 2.7
does that mean its 540Kohms? or something diffrent according to the Haynes manual it should be reading somewhere from .2-20 Kohms or more specifically approx .4 Kohms at this temp.
if so than its way out of whack and is one of the culprits.
Kyle Lee Cleveland
09-28-2015 09:01 PM
