4th Gen FAQ question list (Attn: Mods)
Old 10-31-2002, 08:10 AM
Anachronism's Avatar
We are always telling people to check the FAQ but it is turning into a pretty big thread. I made a list of the questions in the FAQ to make it easier for people to find information. Maybe a Mod can stick this in the first post on the FAQ.
Pages are with 40 posts per page (Board default I think)
Page 1
Should I get the Tornado Air?
How about the Electrice Supercharger?
What tire size can I use?
Aftermarket rim weights:
Will mods void my warranty?
What's Nissan's phone number?
What does a VB, TC, or tranny cooler do?
How do I reaim my headlights / foglights?
Can I convert a automatic to a 5-speed?
Is it possible to make the rear windows roll all the way down?
What mods can I do relatively cheap and easily?
Can I change my 95/96 front/rear end to a 97+ front/rear end?
Where can I buy (name of mod here)?
Can I swap out a manual climate control and put in an auto climate control?
Can I add ABS to my car?
Should I punch out (gut) the catalytic converter?
Can I put 300zx headers on a Maxima?
Can I turbo my Max using parts from a 300zx?
How much would it be to paint my entire car?
I chipped/scratched my rim. How can I fix it?
Where can I find touch-up paint for my car?
Can I Save Money and Run Low Octane?
Can I put a 5th gen muffler on my 4th gen?
Alternator ampere rating
Stock Flywheel weight and upgrading
Whats this oil leak near my oil pan?
Can I install an Optima Battery in my car? What are the benefits?
My 5 speed transmission is leaking near the CV inputs
My mom's Toyota Camry has rear seat head rests, how can I get some?
Theres a Throttle Body Bypass Coolant Mod on Ebay...should I?
I saw a Max with no rear emblems, how can I do this?
How do i make the door pillars body color?
How do I get rid of my top speed limiter?
I want to install a Quaife differential- what are its benefits, can I do it myself?
What are the alignment specs for my car?
Does this hose connect to anything?
What are the more common mods?
My clutch pedal is too high/too low/wants to adjust itself...what can I do?
I have to hold my sunroof button for it to open, is there a way to make it 1 touch?
Page 2
My Car Comes with the Bose stereo, how can I add to/upgrade it?
Can I fit a Stillen bodykit onto my I30?
How do I know which trim level I am looking at?
How to decode Vehicle ID plate
I want to put a trailer hitch on my car
TSB (Technical Service Bulletins)
97-99 cars running rewired front corners and side markers
I connected an airhorn compressor directly to the horn, now no horn works....
Diamond Cut Vs Regular Clear corners
Doesn't an engine need backpressure to make power?
Do I HAVE TO use premium gas?
Which is better horsepower or torque?
Spark Plug Boot Stuck on the Plug
My bass hits so hard my rear view mirror falls down
What makes the Infiniti I30 so special?
How do I manually control my cooling fans at the track?
What information is contained in the VIN?
I have a 95-96 Maxima and want red/clear tails
How do I disassemble / rebuild my sticky sunroof?
What does the "O/D off" button do?
I have a 95-96 and want to rewire my clearance lights like a 97-99
I'm trying to find the Nissan part number for service parts on my Maxima
How to clean IAC valve
How can I get more power from my Maxima?
Where can I get a deeper final drive gearset for my 5 speed?
Does my 4th gen need a timing belt replacement?
P/N for OEM Spring Isolators
What major service does my car need?
My air conditioner smells like crap
My OD light is blinking, what does that mean?
I need centering rings for my aftermarket rims. What size is the Maxima's hub?
Why does my A/C only work on fan speed 4?
How do I take apart my dash and doors?
Where can I find a performance shop near my area?
What is "the beam" ??
What can I do about the amber tails on my 95/96??
How do I change/install the springs on my car?
Where can I find my owner's manual
What is the MEVI ?
Installing an aftermarket Y-pipe in your garage
Page 3
Tire Pressure
Can I put a Fifth Gen (2000-2001/3.0) engine in my fourth Gen?
How about a fifth Gen intake manifold?
Can I put the fifth Gen 3.5 engine in my fourth Gen?
Anachronism is offline
Old 10-31-2002, 08:19 AM
Minister of Silly Walks
mzmtg's Avatar
Thanks for the list.
The first post does describe how to search the thread, but a list is better.
I know I have my settings for 30 posts per page. I think we should number the questions. Then we only have to pray that someone is smart enough to figure out which page it will be on for them.
mzmtg is offline
Old 11-01-2002, 06:16 AM
clee130's Avatar
Thanks for writing up that "table of contents"! I'm going to edit the first post now.
And I think the default thread view is 15 posts per page.
clee130 is offline
Ben2003GLE
31
07-17-2016 08:13 AM
Finkle
09-27-2015 09:53 PM
Abdelrhman
08-17-2015 12:16 PM
ViciousVQ30
08-05-2015 05:40 PM
Quick Reply: 4th Gen FAQ question list (Attn: Mods)
