Wide psi range fuel pressure regulator
Anyone know of a fuel pressure regulator that can handle up to 43psi on the inlet side, but bump that down as low as 10psi on the outlet side? i currently run a SARD for my main fpr, but I need a secondary for a nitrous install I am doing. I have some mallorys but i don't think they can handle our high psi on the inlet side. i also have a BG 2 port plus, but i haven;t heard back from BG tech support yet. thanks in advance.
Re: Wide psi range fuel pressure regulator
http://www.holley.com/HiOctn/ProdLin.../FPregltr.html
I helped install a direct port NX system and this was recommended and works very well. Inlet pressure on this system is 55 so it will work for you. Its operating at 10 psi, but is adjustable from 0-12.
Jim
Re: Re: Wide psi range fuel pressure regulator
Originally posted by Jime
This one will work.
Jim
This one will work.
Jim
jmlee44
10-02-2022 02:13 PM
Forge277
06-13-2016 09:26 PM
