Pics of my cousin's sunroof rebuild
Old 06-30-2002, 07:46 PM
deezo's Avatar
This job is time consuming (I won't get into the lost time of running to Home Depot for a lost screw which my cousin lost). I figure now that I know what I'm doing, it should take about 4 hours to do the rebuild.
The sunroof rebuild kit costs about $43 (which it seems that the dealerships are trying to make a killing on unsuspecting Maxima owners charging anywhere from $500 on up over $1000 to do what I did I'd say this is a $150 job at the most).
Here are the pics:
At this point, everything needs to come out of the roof including the lining. The rear seat, the plastic covers for all of the pillars, visors, the rear view mirror, the 3 interior handles and the interior lights were removed to drop the roof liner.
http://a5.cpimg.com/image/73/56/1424...-028001E0-.jpg
http://a6.cpimg.com/image/74/56/1424...-028001E0-.jpg
http://a8.cpimg.com/image/76/56/1424...-028001E0-.jpg
We unbolted the sunroof track from the roof of the car. This is all straight forward when you remove it.
http://a9.cpimg.com/image/77/56/1424...-028001E0-.jpg
The next pic shows the bolts that need to be loosened to remove the glass from the track. There are plastic covers that need to be removed that hid the bolts. This goes for both sides.
http://a0.cpimg.com/image/78/56/1424...-028001E0-.jpg
My cousin Dave preparing the track for disassembly.
http://a2.cpimg.com/image/7A/56/1424...-028001E0-.jpg
There are brass fittings at the end of the track that need to be removed in order to slide the broken tracks off. Chances are if your sunroof doesn't move properly, your tracks my look like this...
The first of the 3 pics show that damaged tracks. The cables are disconnected from them. The last pic shows the old against the new.
http://a6.cpimg.com/image/7E/56/1424...-028001E0-.jpg
http://a4.cpimg.com/image/7C/56/1424...-028001E0-.jpg
http://a3.cpimg.com/image/7B/56/1424...-028001E0-.jpg
When we removed the old tracks , the cables were still stuck inside of their guides. We used the new cables to push them out. There is much more to be explained on this part of the job because after the new tracks go in, you will need to put the track back up into the car (with the sunroof glass bolted back onto the tracks) to see if the glass is flush with the roof when in closed position. Befroe this is done, everything will need to be in position as if the sunroof is closed. We must have pulled the sunroof out like 10 times to get the sunroof's height correct.
If everything goes right, the roof should fit back in like this....
http://a6.cpimg.com/image/2E/54/1424...-028001E0-.jpg
You will need to adjust the height after test fitting the sunroof to the roof.
The rest of the pics show us getting the car back together and showing the end results of the sunroof's movement and open/closed position. We were very happy with the results.
http://a2.cpimg.com/image/34/54/1424...-028001E0-.jpg
http://a7.cpimg.com/image/2F/54/1424...-028001E0-.jpg
http://a1.cpimg.com/image/33/54/1424...-028001E0-.jpg
http://a3.cpimg.com/image/35/54/1424...-028001E0-.jpg
http://a5.cpimg.com/image/41/54/1424...-028001E0-.jpg
http://a4.cpimg.com/image/40/54/1424...-028001E0-.jpg
http://a6.cpimg.com/image/42/54/1424...-028001E0-.jpg
http://a0.cpimg.com/image/3C/54/1424...-028001E0-.jpg
The kit from Clay Nissan:
http://a5.cpimg.com/image/37/54/1424...-028001E0-.jpg
deezo is offline
Old 06-30-2002, 08:11 PM
deezo's Avatar
Originally posted by maxedout95
Im thinkin about putting a sunroof in my car but the problem is that there was never one in there before so do you think it would be impossible for me to do this cuz I heard that even the dealer would have a problem to do this and it would cost me like $ 500-700 just for labor.
I'd say its not worth the time, money or headaches with owning the sunroof. You'd need a lot of parts to do it plus you would haveto cut a hole in your roof. The cost of all of the parts would probably run a little over a $1000. I'd say keep your money or use it for engine mods.
I forgot to add, when you remove the sunroof assembly, it is a good idea to clean the guides with brake cleaner. Brake cleaner is the best for removing oil and grease residue quickly. Just be sure to lube the guides and every other moving part before you put everything back together.
Originally posted by Bernout
Good thread. My sunroof has a 'track' problem; i.e. the motor is fine, but it won't slide back, and it only pops up about an inch on one side only... is it off the track?
Oh yeah!!!!! The cable is more than likely disconnected from the track. The track itself has nowhere to go but forward and reverse so it can't jump off the track (which is a good thing).
Originally posted by JustMaxin96
DO you really think It was the track that is bent? Where do I get that kit? Thanks Again!!
The only way to know is to take the roof lining out. I don't think its bent, I think you may have the same issue as most people have with these sunroofs. Scroll up a bit and you will see where to get the kit from (for under $50).
Originally posted by PolarisGT
Thanks for the writeup. Now I am thinking of repairing the same roof problem with my Maxima myself. What deters me is "The rear seat, the plastic covers for all of the pillars, visors, the rear view mirror, the 3 interior handles and the interior lights were removed to drop the roof liner." How hard is it to remove virtually all upper interior of the car? Any special tools needed other than the common wrench and screwdriver?
I used a drill with a Phillips head bit and a socket set because some of the screws and bolts are in tight.
there's nothing to be discouraged about. All you ahve to do is pull all of the pillars and lay thm on the ground in order so you can keep track of the parts. In order to drop the headliner, you will need to remove everything attached to the roof. Oh yeah, it's better if you get another set of hands to help because the sunroof will need to be held in place in order for you to bolt it back up.
If you guys look through the 4th Gen FAQ's you'll find some of the answers to your questions.
The parts shown are the major parts to control the sunroof. If the sunroof isn't funtioning properly, the rebuild will solve the problem (unless the motor burns out).
deezo is offline
Old 07-01-2002, 10:57 AM
party_boy's Avatar
Yes the part you are looking for is the cable with the lifter mechanism. That is why your sunroof can only move up and down on one side. This is the weak link of your sunroof system.
Deezo- you got the entire kit for 50 bucks? Just the part I just mentioned is over 100 from the dealer. Where can I get this kit? Can you please e mail me this information at party_boys@hotmail.com
Thanks for the info.
Jon
party_boy is offline
Old 07-01-2002, 11:53 AM
Licensed to Spell
ptatohed's Avatar
:o)
Deez., I know I already complimented you in your other thread:
http://forums.maxima.org/showthread....5&pagenumber=1
But I just wanted to say 'good job' one more time. Thanks.
ptatohed is offline
Old 07-10-2002, 07:09 PM
4 Maximas and counting
philpoe's Avatar
The dealer (well, maybe not your dealer should be able to point you to a place that does aftermarket sunroofs.
Some dealers send out cars that arrive OEM without roofs to get them.
Typical costs are $800-$900 with a lifetime leakage warranty.
I never bothered trying to find such an installer myself without asking the dealer. Both times I asked I ended up getting a car with the OEM roof.
Actually, dealers can get the equivalent of pretty much any factory option installed through local shops.
philpoe is offline
Old 07-16-2002, 07:45 PM
elgatomax's Avatar
hey deezo
i have the same problem..my sunroof stop working after my spring break in april. I brought it to the dealer and they told me 1000+ to fix it. And is my track liner that got disconnected or broken but the motor is working fine. I would like to get a instruction of how u did yours so in the future i can do mine.
But is a good i can have your e-mail or better yet if u have a screen name that i can talk to u about it. Let me know thanks. I hate paying that much money if i can do it for just less than 200.
elgatomax is offline
Old 03-10-2003, 02:34 PM
nizmo's Avatar
Dude can you tell me how to adjust the height of the sunroof. Mine works fine but kinda rattles and there is some up and down play in the rear end of the sunroof when closed. I'm guessing it just needs adjustment.
nizmo is offline
Old 03-14-2003, 03:21 PM
turbolaw99's Avatar
Is there a trick to forcing the cables out? There does not seem to be any movement,once I hit a certain point on the track (after it curves forward), so I think I am missing something. Both cables are broken and they are sitting in the track at the front of the sunroof. Any help would be appreciated. Thanks for the write up, without it, I would not have gotten this far.
Jeff
turbolaw99 is offline
Old 03-14-2003, 04:41 PM
klymkow's Avatar
Repair Kit
www.nissanparts.cc has this kit for $31 plus shipping.
- 91350-40U20 Repair Kit Sunr (List - $41.25) $31.43
Tim
klymkow is offline
Old 03-14-2003, 04:54 PM
gtr_rider's Avatar
instructions are avaliable here now: http://www.vqpower.com/v2/modules.ph...howpage&pid=43
gtr_rider is offline
Old 07-15-2003, 10:19 AM
pocketrocket's Avatar
Bump for this post. I have a similar problem, the track moves forward/back fine. However, when fuilly closed, one side sits a bit lower and there is some play. I have to tilt it up slightly to keep the seal.
Is it the track?
It works, but I just need to adjust the height one one side. Possible?
pocketrocket is offline
Old 12-17-2003, 06:16 AM
vntperformance's Avatar
Let me explain my problem to you guys.
Car: 1997 Nissan Maxima SE
The sunroof opens going back ONLY, but when you go to close it (Slide it Forward) you can hear the motor, and you can see the sides of what holds the sunroof go forward, but the actual sunroof doesn't close, it just sits in the closed position, untill i Physically slide the sunroof to the front with my hands. Also the tilt feature does work, you can hear the motor working but the sunroof stays still, and also i noticed after this problem, I can't fully close the sunroof as in the front is against the roof of the car, but the back portion that actually tilts, sits in kinda in...so there's a GAP, where you can hear wind noise, and water leakage when it rains.
What's your remedy?
Thanks for any help you can offer.
vnt
vntperformance is offline
Old 04-11-2004, 07:49 PM
klymkow's Avatar
Originally Posted by vntperformance
Thanks for the reply!!
I talked to the local dealer and there telling me that part number you guys have listed is an invalid part ##, those *******s. Hell if it's that simple..i'll do it myself once i locate a rebuild kit. How long did it take you to do?
Plus I can't acces vqpower.com, it says the site is down.
Thanks again.
valT>
It's a good number - try www.nissanparts.cc
Some more info from Service Bulletin:
Sunroof - Binds/Leaks/Inoperative
Classification:
BT99-049
Reference:
NTB00-001
Date:
December 15,1999
SUNROOF RAIL ASSEMBLY REPAIR
APPLIED VEHICLES:
1995-97 Maxima (A32)
1996-99 Pathfinder (R50)
SERVICE INFORMATION
If an applied vehicle exhibits the following symptoms, use the service procedure to resolve the incident(s).
^ Sunroof binds
^ Sunroof motor runs but the sunroof will not open or close
^ Sunroof leaks
klymkow is offline
Old 08-18-2004, 05:12 PM
PolarisGT's Avatar
Originally Posted by mikeyen
One question: Do I have to remove the seats in order to remove the headliner?
I didn't remove the seats.
PolarisGT is offline
Old 08-24-2004, 03:59 PM
Hooooooonda.....
DAVE Sz's Avatar
Quick question. The roof panel, the sliding panel under the moonroof, seems to be off its track. How do I get it back on track and which track is it supposed to be on? If it's answered in this thread just please say so. I'll look for it later.
DAVE Sz is offline
Old 06-08-2005, 06:21 AM
SirPorl's Avatar
Quick Question
Hi all. I know this thread is from awhile ago but I have a question on how you adjust the height of our sunroof once you get it back in the car. The fron of the roof look flush fitting but the back of the glass doesn't quite fit flush, can't seem to figure out how to get it up flush fitting. Any help will be appreciated.
thanks
SirPorl
SirPorl is offline
Old 06-08-2005, 06:27 AM
WaarrEagle's Avatar
Did you reinstall the shims on the back of the glass when you put it back together?
WaarrEagle is offline
Old 08-10-2005, 01:38 PM
I Broke OT
86maxima96's Avatar
Originally Posted by meanbean
My sunroof is not closing flush against the roof but is fully functional. Will I still need to get the kit? If not, can I just realign the sunroof without taking it apart? Thanks for the assist.
Mine also moves back and forth but does not close COMPLETELY. very close though. would i still need the repair kit, or is there anything else that can be done?
thanks
86maxima96 is offline
Old 08-16-2005, 01:53 PM
MDeezy's Avatar
Great write up and pics Deezo.
PDF version for those who may want it. That might be easier to sticky.
http://s43.yousendit.com/d.aspx?id=3...10TGVUH5A62DZR
edit: WOw, I did not see the age of this thread!!
MDeezy is offline
Old 08-24-2005, 10:16 AM
mikeh's Avatar
Maxxximum90 sounds to me you are having the same problem as me... I was told by a mechanic that they are all designed to leak... that is what the drip pan is for: however when i open mine the pan slides toward the back of the car like it is supposed to but when i close it.. it stays back there instead of following the glass back to the front of the car.... this is the rigged way from keeping it from leaking....
pop moonroof up reach back inbetween headliner and pull you pan foward by hand... you have to do this every time it rains to keep from getting wet or just do it and dont open sunroof up... you can only pop it up... if you can figure out a way fix the pan economically please let me know
mikeh is offline
Old 08-24-2005, 12:34 PM
maxxximum90's Avatar
i just ordered the kit from www.buynissanparts.com the total came to around 50 bucks shipped. im gonna take the thing apart and see what is causing it to leak...and see what all i need to do.
maxxximum90 is offline
Old 02-02-2006, 09:21 AM
Tim96I30t's Avatar
Quick question, does the headliner and everything have to come out to shim the sunroof?
Tim96I30t is offline
Old 02-13-2006, 03:56 PM
anyone do a write-up on how to remove the headliner and all the trim pieces?????
Old 03-23-2006, 08:57 AM
Licensed to Spell
ptatohed's Avatar
:o)
Tim
I see $56.
http://www.nissanparts.cc/cart/?pn=9...&submit=Search
ptatohed is offline
Old 06-04-2006, 03:48 PM
purduepete's Avatar
Very nice. As an FYI, I ordered the kit online, here:
http://www.trademotion.com/partlocat...214041&make=25
Part No is: 9135040U20
Price is $63.81 with shipping.
purduepete is offline
Old 06-04-2006, 04:50 PM
jipi's Avatar
hey, i just did this rebuild memorial weekend so if you guys want to ask me any specific questions, just shoot me a pm.
as for the pan issue...
on the pan, there is a clip that connects to the sunroof track, so when the sunroof slides open, the pan slides back with it. and when u close the sunroof, the pan again slides with it. it seems to me that the clips are broken, or maybe they just fell outta place. the repair kit comes with new clips.
check the technical service bullitin of the sunroof rebuild and u'll see what im talkin about.
jipi is offline
Old 09-16-2009, 10:29 PM
godcre8d's Avatar
maxima repair kit availability
The photo links do not take me anywhere other than a general website. I would like to know where to get the sunroof rebuild kit for $43.
godcre8d is offline
Old 09-16-2009, 10:39 PM
godcre8d's Avatar
Tim
This repair kit on nissanparts.cc is $99.75. where is it available for $43??
godcre8d is offline
Old 09-17-2009, 05:03 AM
Decal Specialist
erty67's Avatar
you bumped a thread that was started in 2002! no wonder why you can't find it for $43 anymore. Nevermind the fact the last post was over three years ago.
erty67 is offline
Old 09-17-2009, 06:15 AM
Blackwind's Avatar
oh sweet jebus.
Blackwind is offline
Old 04-18-2010, 12:06 PM
tongueman45's Avatar
Link to your picture don't show up
The links to you picture go to a photography web site your picture do not show.
Here are the pics:
tongueman45 is offline
Old 04-18-2010, 03:54 PM
95maxse3000's Avatar
95maxse3000 is offline
Old 03-20-2011, 09:31 AM
Shift_Nismo's Avatar
My sunroof has this same problem. Anyway to get the pics of the rebuild back up?
EDIT: Found the link on VQPower for the rebuild w/ working pics. Here is the link for anyone who needs it: http://www.vqpower.com/v2/articles.php?article_id=43
Shift_Nismo is offline
Old 03-20-2011, 12:48 PM
Donating i30 Owner
HomerMAC's Avatar
the 98/99 sunroof is a dif. design. You can pick one up for like 50$ at a JYard. It is a direct swap. save yourself the hassle of taking it down and then rebuilding. With the newer roof, you just get it and put it in. Get someone to help as it is heavy.
HomerMAC is offline
Old 03-20-2011, 06:49 PM
Will the 98-99 work with the 95-97? It should go in just the same right?
Old 03-21-2011, 06:31 PM
Donating i30 Owner
HomerMAC's Avatar
my 96t has my wrecked 98 i30's sunroof. Direct swap. When i had it out, I also shot some compressed air into thos edrain holes as well. Cleared that out. the 98/99's design is a bit diff when you compare them side by side, BUT they are essentially the same. 95/96 have a track design with a cog style belt, where as the 98/
All the bolts etc. are same, even connectors for power. EVERYTHING is the same.. You will have to adjust the glass angle. This is covered in the FSM, but essentially you put 1 Or two small whasers in between the sunroof and glass.
Also I am working on making a replacement switch for the sunroof to give us oldies ONE TOUCH open. More on that to come......
HomerMAC is offline
Old 03-23-2011, 09:46 PM
JBoogie539's Avatar
PLEASE post if you get this accomplished man, that'd be so sweet.
My sunroof opens but won't close, I'm assuming it just falls off the tracks like everyone is saying, but I haven't gotten the time to take my liner and everything off to take a look. Is it worth it to shell out the $100 bucks and get the repair kit, or should I try the junkyard for a '98/99 swap?
JBoogie539 is offline
Old 03-25-2011, 02:55 PM
Donating i30 Owner
HomerMAC's Avatar
I think the repair kit is only 50$. At least it was at one point. From personal experience, after taking my sunroof apart... before going to purchase the rebuild kit, I was turned off by the whole aspect of the rebuild. At 55$ bargained down from 90$. I had a 99 sunroof in my hands. I swapped over my tinted glasss.. and I was set. I did have to use a washer to shim the roof up, as covered in another thread on these here forums. I say go to a yard and find a 99, with a good looking interior and see if you can get the roof.
HomerMAC is offline
Old 06-20-2013, 08:26 AM
kilsin's Avatar
can not figure how to remove the sun visor clips. I have removed the cover and screws. The actual sun visor came out with no problem, the clips that hold the visor in the forward position are the problem. please help.
kilsin is offline
Old 06-20-2013, 12:14 PM
tigersharkdude's Avatar
those may possibly be attached to the headliner, with a screw from the backside............this is a complete guess. Just seems plausible since there are no visible mounting points from the front
EDIT: Holy old thread Batman! 11 years old
tigersharkdude is offline
Quick Reply: Pics of my cousin's sunroof rebuild
