Thanks to OBD and The Org !
Old 04-04-2002, 10:17 AM
Danielsan's Avatar
Short story:
I was driving down the road to my girl's place and all of the sudden, in-between gears, the max shuts down on me! Middle of the road and no power, wont even crank back up.
Luckily, I pulled over to a side road under the momentum I had left and parked. Having no idea what happened or what, I freaked. D*** Nissan I thought!
Then I calmed down and pondered for a bit. Why dont I checked the ECU? I crawled under my dash and did the ecu check (learned from the org) and found code 0802. Had to get a ride home to figure what that code meant (learned from the org). 0802 = Crank Pos Sensor.
I went back to my car and checked the wire location(learned from the org). The connection was dirty! After I cleaned it up, the Max started right up. Turns out I had started polishing the valve cover and shavings got in the upper connector. Total down time 1 hr 30 mins.
Thank you Maxima.org and OBD ! Would have never known had it not been for this forum having the wealth of information about Maximas.
I don't care if anyone replies or even reads this, I just wanted to say thanks!
Daniel
Danielsan is offline
Old 04-04-2002, 10:31 AM
clee130's Avatar
You're welcome.
clee130 is offline
Old 04-04-2002, 10:58 AM
Ramius83
Its all Clee....
Old 04-04-2002, 12:25 PM
SuDZ's Avatar
Glad it was such a cheap and simple fix for you. It stinks beeing stranded.
SuDZ
SuDZ is offline
Old 04-04-2002, 12:34 PM
BEWARE OF 0802
I had a friend of mine with an I30 which periodically did not start. No code was thrown either. After extensive trouble shooting with my multi meter we found no trigger signal at the coil packs. Tracing the circuit back and checking each device on it we found the Crank Position Sensor measuring a short. Took it out of the car, cleaned it up and it measured out OK. (it also had what looked like metal dust stuck all over the magnetic pickup) Put it back in and the car started up like nothing was ever wrong with it. The strange thing is we never got 0802 when the car experienced the no start conditions. This usually happened after it sat overnight. Sometimes later on that day it would start again. It was really ****ing us off. All seemed fine until........
Now 2 weeks later, driving down the highway the car just dies. He had to have it towed to the dealer. Guess what it was that failed? Crank Pos. Sensor. Code 0802
If you've had a failure of this sensor, REPLACE IT! 70 bucks for the part at your local Nissan dealer. The whole ordeal cost over 300 bucks including the tow, diagnostic charge, labor bla bla bla from the Infiniti dealer. Don't get caught with this one, it's probably getting weak. Replace it now, or you may get stranded again, the car will not run if this part goes bad.
Old 04-04-2002, 12:43 PM
Danielsan's Avatar
Originally posted by njmaxseltd
BEWARE OF 0802
I had a friend of mine with an I30 which periodically did not start. No code was thrown either. After extensive trouble shooting with my multi meter we found no trigger signal at the coil packs. Tracing the circuit back and checking each device on it we found the Crank Position Sensor measuring a short. Took it out of the car, cleaned it up and it measured out OK. Put it back in and the car started up like nothing was ever wrong with it.
Thanks, but it was my fault. I had unplugged the connector right at the valve cover because I was scrubbing the top of the valve cover to get rid of some stains and alot of the shavings got in there. I dusted it off and it started right up again. Never even had to check the CPS.
However that is a good idea, and if that code pops up again I will probably just replace it. 70 VS towing+70 I will go for the first one.
Old 04-04-2002, 01:03 PM
SuDZ's Avatar
What is is that the Crank Pos. Sensor does?
SuDZ
SuDZ is offline
Old 11-30-2005, 09:06 AM
infinity30's Avatar
trouble codes
Hi
sorry to bring this subject up, I am a newbie here but I search the OBDII sticky and all over various sites with codes and the definition and can't find out what these 2 codes means it doesn't even list them on the various sites. I need to know what P0004, and P0800 means. Most of the Site starts with P0100 +up and ends at P0790 ans atrt up around P0802. thanx
btw it's a 97 Maxima with 129k miles
infinity30 is offline
Old 11-30-2005, 09:14 AM
Do I get a tax break?
njmodi's Avatar
Originally Posted by infinity30
Hi
HOLY WAY TO DIG UP AN OLD THREAD BATMAN!
njmodi is offline
Old 11-30-2005, 09:40 AM
ajcool2's Avatar
lol wow 2002. Search and ye shall find.
ajcool2 is offline
Old 11-30-2005, 10:07 AM
infinity30's Avatar
Sorry I am newbie and Maxima.org won't allow me to use the "search feature" . This is kind of weird as other forum allow your to search the forum as a newbie, but can't start new thread and reply to other post until you reach certain post ie 100 and you can start new thread.
Old 11-30-2005, 10:14 AM
MaDMvD's Avatar
If you had read the stickies, you would've known you don't have to take your car to Autozone to read the codes yourself...
MaDMvD is offline
Old 11-30-2005, 10:57 AM
Tha Snatcher
Iron Scimitar's Avatar
^^Yeah, take your car to an Autozone and they'll check the codes for you.
Iron Scimitar is offline
Old 11-30-2005, 12:08 PM
infinity30's Avatar
I read the stickies and search all around and still can't find what these 2 codes mean P0004 and P0800 it's not even listed in the stickies. thanx
I have a Code reader that's how I pulled the 2 codes!!! thanx
adamgalazka
02-05-2023 08:24 AM
aminus21
09-12-2015 04:53 PM
16_SR
09-07-2015 06:47 AM
lux97Max
09-04-2015 05:42 PM
Quick Reply: Thanks to OBD and The Org !
