2006 Nissan Maxima Tranny problems?
Old 08-06-2015, 02:45 PM
Lakersallday24's Avatar
Car BANGS! when shifting to drive, it also slips in first gear and when deceleration getting close to a complete stop it feels as if something is dropping from underneath the car. Other then that everything else is fine, the wierd part that comes along is the problems go away so no more bang, and slipping etc, but then it will come back. Has anyone experience this issue? is it a valve body issue or tranny.
Lakersallday24 is offline
Old 08-28-2015, 09:22 PM
oldpuck81's Avatar
I'm gonna guess it's your valve body. I have an 06 SE auto and I had to have a new valve body put it at my shop here in Plano, TX. My mech said you can't rebuild the valve bodies because you can't buy individual solenoids and it's too hard to calibrate them. Easiest way is to buy the entire valve body (either new or rebuilt) from Valve Body Express or similar supplier. My job cost me ~$1100 but it fixed the problem, which was slamming gears, hard up-shifts and erratic shifting in slow traffic. Seemed to be worst when the car got good and hot. This is a pretty common problem to these cars that have the 5 speed auto tranny. But I really like how my car shifts. Nice and crisp w/ quick downshifts and not mushy like a lot of cars nowadays.
oldpuck81 is offline
Old 08-29-2015, 10:12 PM
wingnut2006's Avatar
1st thing to do is to change the transmission fluid. Nissan type K is required. (Toyota T-IV or Mobil 3306 is the same as type K an is usually less expensive). You may have to change several times if the fluid is dirty. Drive the car 50 or more miles between changes, then drain.. Continue to change until the fluid is bright red (may be 4 or more time.) If this corrects you problem then continue to change the fluid every 15,000 miles. If the fluid changes does not correct the problem then the next step is to either install a Transco shift kit or Rostra solenoids. If the Transco shift kit or Rostra solenoids does not correct the issue then you looking at the transmission rebuild. Good luck
wingnut2006 is offline
Old 05-30-2016, 05:20 PM
blaqpearl42's Avatar
Nissan maxima ecm fuse blowing problem.
I bought a 2004 Nissan maxima was unaware it had a factory alarm . Took it the next day and got another alarm put on. My car worked perfect from Tuesday to Friday nite. Changed all coils,sensors etc. Still keep blowing fuses. So I removed the one I had put on and still keep blowing fuse 10 in my ecm fusebox. Pleez help
blaqpearl42 is offline
Old 06-23-2016, 09:12 PM
steezmuffin686's Avatar
Check your engine mounts, that can be a cheap fix. Have someone shift from d to p and so on, watch for excessive rocking of the engine..
steezmuffin686 is offline
Old 08-06-2018, 08:57 PM
Johnny9595's Avatar
What was the final of you have the result?!?! My 96 I30 is doing the same. It's been going on for over 3 months but it doesn't seem to bad when I put the car in neutral when I am at a stoplight. It's not battery or alternator related for as because I just changed those today. If you remember what happened I would appreciate it!
Johnny9595 is offline
Old 09-03-2018, 05:21 AM
SR20Power's Avatar
Do not replace your valve body. If you are mech-inclined removed the solenoids and clean all 3 of them and reinstall. Or, just find the solenoids and swap them out with Remanned / New solenoids.
This typically that happens when metal builds up from the oil gathers into the solenoids and clogs it.
Good luck.
SR20Power is offline
Old 04-04-2019, 04:23 PM
twoweeled's Avatar
I've had Nissan CVT transmissions go out on both a 1995 Maxima and a 2011 Maxima. Advice? Save $4,000. that's what the 2011 cost me. 1995 was covered. It died in less than a year.
twoweeled is offline
Old 04-06-2019, 03:44 PM
04maximas's Avatar
id check the mount and fluid level and condition
04maximas is offline
Old 06-15-2019, 06:59 PM
Sandy Flowers's Avatar
2006 Nissan maxima
try to make this simply
Went on Sunday got oil changed...was told of valve cover leaks...thursday took it to shop, replaced valve cover gaskets , back valve cover, another type of gasket to do with main oil coolant seal something...900.00 on pick up and drove over 100 miles on Friday. Saturday drive 5 miles and car cuts off all lights come on..ALL dash lights. Push to. Side...car will start but will stall back out.....any advice?
Sandy Flowers is offline
Old 06-16-2019, 01:35 AM
Costee's Avatar
Scan for codes.
Costee is offline
MaximaNoob1
07-31-2016 06:17 PM
miccar
12-25-2013 01:58 PM
AJR6
04-12-2012 09:15 PM
Blitzfist
28
10-20-2008 05:56 AM
DcMaN
10-04-2005 05:38 PM
Quick Reply: 2006 Nissan Maxima Tranny problems?
