brand new keyless entry?
Old 02-01-2012, 08:54 AM
Amerikaner83's Avatar
Hey guys, was bored at work today. And I was thinking... how simple is it to buy a keyless entry system (oem preferred but not required) if my car did NOT come with keyless as a factory item?
Nothing fancy like remote start and alarm...but just door lock/unlock/trunk pop.
My car only came with two keys from the original owner, no fob or anything.
Would I just need to install a signal receiver and wire it into the power lock circuitry? Just floating some ideas through...
Amerikaner83 is offline
Old 02-01-2012, 09:12 AM
I'm pretty sure all 4th gens are set up with keyless entry. You would just need a fob and to program it.
New ones from the dealer are around $85 while used ones are around $20. The program procedure is extremely simple.
ChrisMan287 is offline
Old 02-01-2012, 09:17 AM
max1008's Avatar
I've had my car for two years and have yet to purchase the fob either. Plan on ebaying it. I do have the security light that flashes once the car is locked.
max1008 is offline
Old 02-01-2012, 10:33 AM
Ok, I will check my trunk at lunch to see if I have the little metal case for the keyless.
If I DO, then can I just get any old nissan key fob and have it program properly, or must I source from another 4th gen? I ask because the style of fob is different and I think I like the 5th gen fob better.
Old 02-01-2012, 12:30 PM
aackshun's Avatar
You can use ANY key fob you want.....
as long as it has "A269ZUA078" on the back of it
aackshun is offline
Old 02-01-2012, 12:36 PM
Any '95-'99 Maxima/I30 fob will work is what he's trying to say.
Old 02-01-2012, 12:39 PM
so this one would NOT work for me, then?
http://www.amazon.com/2002-2006-Niss...8128648&sr=1-1
Old 02-01-2012, 12:45 PM
Old 02-01-2012, 12:49 PM
/sad face
Allright, Allright, I guess I'm gonna have to go with the 95-99 version.
Got busy at work so unable to take a peek around the trunk latch to verify if my car has the relay or not...will try later today
Old 02-01-2012, 01:48 PM
DennisMik's Avatar
You could also check to see if you have the antenna/receiver box. It is in the trunk, mounted on the backside of the metal up & down panel just forward of the antenna motor.
Also if you buy a key fob, Nissan or non Nissan, it has to have a FCC ID of A269ZUA078 which say it works at 434 MHz.
DennisMik is offline
Old 02-01-2012, 02:06 PM
throw this wrench into the plans:
I texted the original owner of the car, the one I bought her from, and he told me the car never had keyless remote, only the two keys.
So now what do I need to get?
Trunk relay and receiver box, yes, in addition to a fob?
EDIT - I just spoke with two local Nissan dealers, and they both told me that it DOES have the remote keyless entry option on it, so I am going to go ahead and order a 95-99 fob off of ebay :-)
Old 02-01-2012, 03:06 PM
done
16 bucks later and in a week I'll have a new keyless fob.
Old 02-05-2012, 10:26 PM
Ok so I got the fob and tried to program it, but the car wouldn't go into program mode.
I did the procedure right...lock door insert and remove key fully @ least 6 times within 10 seconds, but I do not get the flash of my hazards.
In bed now but will check trunk tomorrow 4 that relay.
Old 02-06-2012, 07:20 AM
Ok so I got the fob and tried to program it, but the car wouldn't go into program mode. I did the procedure right...lock door insert and remove key fully @ least 6 times within 10 seconds, but I do not get the flash of my hazards.
Try inserting and removing the key a little slower. If you do it too fast, the system will not enter registration mode. Also, make sure you completely remove the key before reinserting it.
Old 02-06-2012, 07:32 AM
Thought I did it right...I didn't want to go too slow since there's the 10 second limit...
is it 10 seconds for the 6 times in the key only, or 10 seconds from teh time the door is shut and locked to do the key thing?
But I'll try again @ lunch
Old 02-06-2012, 07:38 AM
10secs just for the key procedure. Take your time, there's plenty with 10secs.
Old 02-06-2012, 07:41 AM
yessir
Old 02-07-2012, 02:18 PM
Ok no dice.
I looked in my trunk behind the latch and lo and behold...I think I don't have the relay needed...?
Can someone confirm the relay I need? And can I just throw the relay in and then go forth with programming, or do I need something else?
Old 02-07-2012, 03:30 PM
On my way to oreilly to get a new relay...they call it the antitheft relay... go figure
Will update with success or failure
Old 02-07-2012, 04:04 PM
No bueno
Still no luck. Relay is in, I did the thing 6 times fast and 6 times slow, and 6 times in between. Grr
Old 02-07-2012, 04:14 PM
cartman854's Avatar
Body control relay.
check fuse box in engine bay right side 7.5A
cartman854 is offline
Old 02-07-2012, 04:52 PM
The one on drivers side by battery...labelled anti theft? That fuse is good.
Old 02-07-2012, 06:45 PM
so according to this post, I should have the little metal box in this location in the trunk.
I do not.
Am I effed? This thing appears to be the actual module for the keyless entry receiver.
edit: according to courtesyparts:
http://www.courtesyparts.com/kb_sear....php?keywords=[28595X]+\%28a32b&cPath=1783_1784_1822_1828
Looks like I am indeed effed. Unless someone has one they want to unload for a bit less than 500 bucks :-)
Old 02-07-2012, 08:20 PM
infinimax96's Avatar
You are ****ed without that box. That box is the wireless control unit for the anti theft system. Get the box, program the fob, have keyless entry.
infinimax96 is offline
Old 02-07-2012, 08:38 PM
roger that.
Is that all I need though? Box, fob, and relay? Where do I connect all the stuff to? Also, do I have to get one from another 99 or can I do any 4th gen?
Old 02-07-2012, 09:21 PM
DennisMik's Avatar
You definitely need the box in the trunk as that is the antenna (and does other things). It is called the "controler, key less" (Nissan's spelling - not mine) part number 28595-0L710. It is the same one on 97, 98 and 99.
Do you have the wire harness connections for that controller? If you don't, I would forget about this project as there may be a lot of other wires missing. The alarm uses the body control module (BCM) located under the center console ashtray. It sits on top of the automatic transmission control module (TCU).
If you look in the FSM, the EL section page 250, it shows all the pieces that make up the alarm system. I wonder what other pieces you may be missing. The BCM, the alarm hood switch, the driver's door master window switch and on and on.
If you need to download the FSM, go here -
http://boredmder.com/FSMs/Nissan/Maxima/
Old 02-07-2012, 09:27 PM
I will take a pic of the wires I have in that area and get back to edit the post, one sec
Old 02-07-2012, 09:52 PM
Jason1979a's Avatar
I just read all you post, You can purchase a basic aftermaket keyless entry system for around $65 bucks. It is about a 5 wire hookup. Also comes with two fobs. I understand if you are trying to keep it all nissan. Just wanted to let you know. I personally like the any "directed" product. Just easier to install than most others. Hope everything works out for you.
Jason1979a is offline
Old 02-08-2012, 09:46 AM
Pics of my setup are below, hope this helps. I could NOT find a gray antenna thing mentioned, but I think I could just run a wire and call it good like I read about in another thread.
My trunk:
Empty wire harness and connector...does this plug into the module?
Relay installed:
Underhood fuses with reference to fuse box:
Passemger side underhood relays:
Allright guys, this is it. What do you think? Can I just get a module and call it good or do I need to return my ebay fob and relay?
Old 02-08-2012, 10:04 AM
Max_Gator's Avatar
Are there any problems with the non-oem fobs?
Max_Gator is offline
Old 02-08-2012, 10:24 AM
I bought a new non-OEM off of ebay. The issue I'm having right now is I can't get the car into programming mode in the first place. Apparently I have no module in rear corner of trunk, and I need it. I'm not even at teh fob part of diagnostics, as fob is irrelavent until I get car into programming mode
Old 02-08-2012, 11:23 AM
DennisMik's Avatar
Under the hood, you have the relays and fuses that you need. Is the hood switch there? It should be on the radiator frame in front of the battery. The relay in the trunk is nice to have but if it is missing, the alarm system would still work. All it does is open the trunk.
Since you have the relays under the hood, I will assume that the car also has the BCM under the console. It is looking like all you need is the box in the trunk, the multi-remote control unit. Go to the junk yard and get one (and the mounting brackets) from a 97 to 99 maxima. Be sure to get the antenna wire with it as the photo of your trunk does not show that connector. Look at the center photo in the link you posted ( this post ). The control box has 2 connectors on it and I don't see the top one in your trunk.
Old 02-08-2012, 11:29 AM
That blows.
The junkyards near me don't have 97-99 max. both of them only have 1 4th gen (96). Hmm, may end up getting one from another .org member (Maxima_Joe).
Old 02-08-2012, 12:15 PM
beegeezy's Avatar
I'm glad I know how to install alarms already. Instead of wasting all this time and money with the crappy factory alarm/keyless system I bought this: http://www.sonicelectronix.com/item_...P-N-5103P.html
$80 shipped for alarm, keyless, and remote start...and any other features I want. (trunk pop, hood/trunk/door triggers, parking light flash, horn honk, and impact sensor)
beegeezy is offline
Old 02-08-2012, 12:36 PM
DennisMik's Avatar
^^^ He may have a point. You may want to consider this, it looks like a good option.
Old 02-08-2012, 12:47 PM
it does, but I would never really use remote start up here in Seattle it's never really that extreme on climate. Also, the alarm portion I am not a huge fan of anyhow, factory or not. Which gives me what...keyless entry only.
I am looking at 60 bucks total for the stuff I already bought and the stuff I need to buy. I'll take that.
If I was big into alrams and had all sorts of audio crap I want to protect, then yeah that's a good deal.
Old 02-08-2012, 03:43 PM
I do NOT have the hood switch...
Old 02-08-2012, 10:26 PM
DennisMik's Avatar
Not having the hood switch starts to make me wonder about other switches. The door locks have switches that are used by the alarm. When you use the key in the door, can you lock and unlock all 4 doors with the key? I would also check and see if you have a BCM module before you commit any more money to this project.
Old 02-08-2012, 10:35 PM
YES, I can lock and unlock all 4 doors using the key in the driver's door, same with the passenger door.
Old 02-09-2012, 10:56 AM
DennisMik's Avatar
That says you have the door lock switches, Now the question is: do you have the door unlock sensors in each of the doors? Do you have the trunk lid key cylinder switch?
Look at page EL-250 of the FSM and check for the parts.
Quick Reply: brand new keyless entry?
