IL FS: Going back to stock, lots of Performance, Suspension, and Turbo parts for 95-03
Car's going back to stock. All prices are +shipping. PM me for the best and quickest response.
Still Available:
7. Subframe collars - For 5th gens and pretty sure they fit 4th gens as well. Bought them off of here only installed the half the set and never even got around to installing the rest, the half that sits on the front part of the subframe is only available. 200 miles at most. $30
11. Blox Velocity Stack with filter - Paid $80 for the filter and stack. $60
Not Available:
1. Cattman Y-pipe - It was originally for a 4thgen but I had the hanger for the 5thgen added to it, so it currently can fit all fed-spec 4thgens and 5thgens, I would need your stock one. Going with car!
2. S-tech Lowering Springs - Fits all 00-03, have less then 15k miles if even that. SOLD
3. Ebay FSTB - For 5th gens, I just installed this a few hundred miles ago. fits and looks great. SOLD!
4. Custom 2.5" exhaust with dynomax vt muffler - For 00-03. Sounds great and a definite upgrade from stock, the dynomax does a great job of eliminating all drone. ON HOLD
5. Resonated test pipe - For 95-03. ON HOLD
6. O2 simulator with heater circuit as well - This is a hard to find object these days. ON HOLD
8. Stillen Front Lip - For 00-01. I just repainted this black not too long ago you can look in my threads and see pics, but it will need to be repainted from the bottom. Previous owner tried to cut the center of the upper part to fit it to a 02-03 bumper, it doesn't affect anything and is unseen once installed. SOLD
9. AT trans Valve Body with Transgo HD2 kit installed -Fits 00-03 automatic transmissions. This is a great mod and a must do for Autos. If you don't know what it does google it and search the forums, I have a thread about the install and a review of it as well http://forums.maxima.org/all-motor/6...kit-today.html. The kit retails for $100 and shops quoted me over $300-400 for the install, since I have installed everything internal to the valve body all you need to do is remove your stock valve body and replace it with this one, just that simple. Also, included are the extras for the external oil seal and inner clutch seal that come with the kit that I never installed on my transmission. SOLD
10. Knight_xyz midpipe - Good for making your own intake, 3" long by 3" diameter. Paid $85 for it, barely used. SOLD
12. Stillen rear sway bar - Previous owner had lost bolts so with it you get a fresh set of bolts and nuts, its also been painted grey and has minor surface rust. SOLD
13. Walbro Fuel Pump - There is literally only 10 miles on this. I just installed it and never even drove the car since its not a daily. SOLD
14. RC Engineering 440cc injectors - Come with pigtails and new o-rings I just installed, basically everything you need to install. Were cleaned and flow tested by previous owner you get the paperwork. SOLD
15. Holset HX35W - Never installed this, previous owner had it rebuilt so no shaft play. I will also include the downpipe flange and a t3 to t4 hotside flange so you can fit this to any feed and downpipe of your choice. SOLD
16. HKS SSQV BOV - Authentic, silver in color. Comes with 3" piping w/ flange that it is fitted to. SOLD
17. Ebay 38mm wastegate with 8 psi spring - Also includes an open dump tube for it. SOLD
18. Ebay FMIC 32x12x3 - Will include all the piping and couplers I have. Fins are in good condition some are slightly bent but nothing that can't easily be pushed back. SOLD
19. Autometer EGT gauge - Comes with gauge and sensor. SOLD
20. Autometer Fuel pressure gauge - Comes with everything to be installed. SOLD
21. Modified Lower oil pan with 10AN fitting for turbo oil drain with all the fittings and lines needed to feed and drain a turbo - has 4AN 36" feed line, 10AN drain line, fittings, oil pressure sender T fitting, and OBX oil pressure reducer. SOLD
22. PFI feedpipe - I'll include the downpipe which is 3" and points straight down so it would need to be extended to your exhaust or you can run it open or throw it in the trash its free. The feedpipe does have regular surface rust. Its 2.25" collectors to 2.5" feeding the turbo with a t4 flange. SOLD
23. Homemade Torque Link - Bought this off of fishtale (a member here) its not NWP but does the job. SOLD!
24. Knight_xyz Poly Mount inserts - They are brand new never used, details here http://forums.maxima.org/5th-generat...-protoype.html SOLD
25. Shinjiduo Grounding kit - was installed on my first max for about a week. SOLD
26. Retrofitted power window and lock switches - Blue LEDs. I would need your stock ones. Only fits 00-01, these are back up since I sold them to someone with an 03 and they did not work. SO ONLY 00-01. I'll ship first and once you recieve you send me your stock ones. Price is firm SOLD
Pics added below!!!
I'll add more as I go along. All prices are without shipping and nothing is written in stone. For some things you can eliminate the shipping by shipping me the stock part for what I'm selling you if it applies, let me know by pm and we can work something out. If need be you can contact me by text at seven zero eight 289 0138.
Thanks!
Still Available:
Not Available:
Pics added below!!!
Thanks!
Haha, you ******* I have been compiling pics and texting them to people so I'll be posting those pics soon.
