International FS: Spring is Coming!!!QT Adjustable links for A32 A33 on sale!!!
Old 03-04-2011, 02:43 PM
b15azn's Avatar
FS: Limited time only QT Adjustable links for A32 A33+free Engine Bay washer kits!!!
Introducing the newest product for all the A32, and A33 members here, QT Adjustable link. The QT name originated from Japan, it is made by Hardrace racing company and originally designed by Kuo's Garage in Taiwan. These links have been on the market the past 4 years in Taiwan until I introduced the item to U.S.A Tuner scene.
QT link has been sold over hundreds and hundreds in Taiwan, and I have sold over 150+ in the U.S market including Europe. No complaints at all so far
QT Adjustable Link bolt on B15/B14/N15/N16/P11/A32/A33
These models of cars share the same rear suspension system, rear solid beam(axle). Therefore, we have all a common issue. The rear beam(axle) would be off-centered towards the right once the car is lowered.
In order to bring it back to its original position and relieve all stresses, the QT Adjustable link is recommended.
Here is old Gb on b15 forum:
http://www.b15sentra.net/forums/showthread.php?t=175733
Stock heigh
ll ll
ll ll
After lowered
ll ll
For those don't know what QT Adjustable link is check here
One thing,I should have mentioned(Kuo forgot to tell me) I sincerer apologize that I wasn't aware this.
Due to a33 and a34 fixed point is opposite then the b15/b14/p11/a32, so a33 and a34 folks will require to thread in. However, I have a customer who ran into a problem that he tried to thread in all the way end after he lowered 2 inch. He could only get limited thread into this link so Kuo has a solution for this. If you have a grinder, you can use it to grind down on both sides of link in few mm. It depends on how much you lowered the car to get it shorten.Before you grind it down, make sure to install on your car to see the result.
For rust concern, all you have to do just spray paint it. Again, this will not effect any performance or damage on this link. QT Adjustable link is completely built by machine, no homemade or ghetto welding involved. Check Hardrace on facebook, this is the company manufacturing the pieces.
Here is an A34 JDM cefiro installed QT Adjustable Link.
http://tw.myblog.yahoo.com/b14-ser/a...567&l=f&fid=35
Here is an A33 USDM Maxima installed on QT Adjustable link
http://tw.myblog.yahoo.com/b14-ser/a...955&l=f&fid=35
Price:
100shipped(free tracking&guarantee fast shipping )
If you are not in the lower 48 states or other area please contact me
(To Europe &Australia please add extra $15)
B15 Stock link V.S. QT Adjustable link
b15azn is offline
Old 03-05-2011, 08:26 PM
b15azn's Avatar
Updated:
Sold 2 last night, 17 left.
b15azn is offline
Old 03-07-2011, 02:01 AM
b15azn's Avatar
Bump top!!! this is a great upgrade for your rear suspension and better ride quaility. You get adjustbable feature and hardbushings are already build in for you. Straight bolt on, no need any modification.
b15azn is offline
Old 03-09-2011, 11:54 AM
b15azn's Avatar
Bump Top 16 left!!!
question feel free to ask :d
b15azn is offline
Old 03-10-2011, 02:01 PM
mayur914's Avatar
so after you lower your car they tend to be off balance? and so with this it somehow balances it out? explain please thanks. but these do look interesting to buy when and after i buy and install a new suspension :P
mayur914 is offline
Old 03-11-2011, 01:43 AM
b15azn's Avatar
So let me explain how this link work out on our car after lowering
1. Why QT displace after lowering the car?
2. The movement of QT Principle and the usage of V line.
3. How does QT principle movement prevent the car incline?
1.
1.Why QT displace after lowering the car?
If you lower your car, the entire rear axles will extend out to the right hand side.
If we look at pic here, red line shows stock high, yellow line shows after lowering position.
So we use QT adjustable link to replace our SCL to extend out to left hand a little more.
Now it balance on both side.
Red shows stock high, Yellow shoes lowering positing
2.
See the red line here, it shows a V line. When the car is braking or driving on uneven road& turning, the Green arrows will lift the car up.
By now V line will be flared-out, the2 side pivots fix; therefore have the upward resistance so the v line will line up equal. (before lowering)
3.
From this pic you can see when the car makes right turn, body inclines because of the centrifugal force. The reverse strength( red arrows+blue arrows). This is how Nissan makes our car balance, and reduce the chances of inclining.
This QT adjustable link idea is alignment purpose+reduce rear axle jumping so much.
It also stiff up your rear suspension
This is from my old post and hopefully can clear some of your clues, don't over thinking. If you have more question let me know, by the way the sales will last untill to April 15th.
b15azn is offline
Old 03-11-2011, 01:47 AM
b15azn's Avatar
Updated: 14 qt adjustable link left...
b15azn is offline
Old 03-15-2011, 04:14 PM
b15azn's Avatar
bump top!!!! welcome local pick up and free installation :d
b15azn is offline
Old 03-21-2011, 02:57 PM
b15azn's Avatar
All pm replied
New pic added, this is the reason why you can have QT mount on your car without fitment issue. All you have to do is taking out the insert ring like this then will work.
b15azn is offline
Old 03-21-2011, 08:15 PM
b15azn's Avatar
1 sold today, 13 Qt adjustable link left!!!
b15azn is offline
Old 03-23-2011, 11:22 PM
b15azn's Avatar
11 QT Adjustable links left...
b15azn is offline
Old 03-25-2011, 10:10 AM
doublea's Avatar
How much to ship to H1A 2W8 > Canada, I can Paypal today. I have a 2k1 Maxima.
AA
doublea is offline
Old 03-25-2011, 09:05 PM
b15azn's Avatar
AA
Pm sent
b15azn is offline
Old 03-26-2011, 09:54 AM
HR Swap Pioneer
SurraTT's Avatar
quick question
so to make the bar lined back up right, compared to the stock link, do you adjust this one shorter or longer?
SurraTT is offline
Old 03-29-2011, 10:39 AM
b15azn's Avatar
Originally Posted by SurraTT
quick question
longer, becuase one side pulls to other side so you will need to extend
b15azn is offline
Old 03-29-2011, 10:41 AM
b15azn's Avatar
Bump top 9 left....once it sold out, the production will have to wait...
b15azn is offline
Old 03-29-2011, 07:18 PM
b15azn's Avatar
For those of you who questioing about the bushing rate.
Chech here, from material usage to bushings rating all the datas and numbers are here. This peice is not garage or homemade ....we have a company to back us up so there is no liability to concern or to risk members lives
http://www.hardrace.com/
b15azn is offline
Old 03-30-2011, 07:46 PM
b15azn's Avatar
7 left!!
b15azn is offline
Old 03-31-2011, 04:27 AM
phatboislim's Avatar
im confused as **** lol
phatboislim is offline
Old 04-01-2011, 10:31 AM
b15azn's Avatar
need help?
b15azn is offline
Old 04-01-2011, 04:02 PM
b15azn's Avatar
6 left
b15azn is offline
Old 04-07-2011, 05:28 PM
b15azn's Avatar
Last 5 left!!
b15azn is offline
Old 04-09-2011, 07:47 AM
You embarrass me.
zero2sixtyZ's Avatar
Interested as I have this problem with my rear beam. Any install threads?
zero2sixtyZ is offline
Old 04-10-2011, 09:52 AM
b15azn's Avatar
here you go, it was installed on my b15, but similiar step and same concep on a32 and a33
http://www.b15u.com/sentra-specific-...step-step.html
b15azn is offline
Old 04-10-2011, 10:15 AM
Crusher103's Avatar
ok wait, so what exactly is this for?
Crusher103 is offline
Old 04-10-2011, 06:45 PM
b15azn's Avatar
ahh...did you read my thread on top? i mean post #6
b15azn is offline
Old 04-11-2011, 08:23 PM
b15azn's Avatar
4 left....and the on sale will only last untill April 15th and after that there will no exception. Price will go back to 100shipped.
so get them quick
b15azn is offline
Old 04-12-2011, 04:59 PM
b15azn's Avatar
2 left.....
b15azn is offline
Old 04-13-2011, 11:19 AM
b15azn's Avatar
SOLD OUT
b15azn is offline
Old 06-06-2011, 12:54 PM
You embarrass me.
Are these still available? In need of one of these badly. Paypal ready.
Old 06-06-2011, 08:03 PM
I R The Law
The Law's Avatar
Damn.....if only I had known about this....
The Law is offline
Old 06-08-2011, 11:47 PM
SpeedCrazie's Avatar
I want one!!
SpeedCrazie is offline
Old 06-21-2011, 06:04 AM
b15azn's Avatar
Will have more coming in soon
b15azn is offline
Old 06-22-2011, 02:24 PM
b15azn's Avatar
Limited time supply!! give away free set of washers when you purchase 1 Qt link
In case people too lazy to read the top post:
I have sold over 90 peices of QT Adjustable links in the past, this is an easy fix your rear beam issue after you lowered your car.
And I have many demands on QT after I sold them out, but this time I can only get 15 of them.
Price:
First 5 people who purchase the QT Adjustable links, I will include a free set of Kuo's Garage silver washers.
Here is the deal, I will get them next week and if the earlier you pay then the first five spots I can researve for you.
First five, 1/5, 4 spots left:
1. shanover/b15u/paid
b15azn is offline
Old 06-22-2011, 03:37 PM
PM sent.
The Wizard is offline
Old 06-22-2011, 07:20 PM
b15azn's Avatar
PM sent.
pm sent :d
b15azn is offline
Old 06-22-2011, 07:21 PM
b15azn's Avatar
b15azn is offline
Old 06-22-2011, 08:22 PM
I R The Law
The Law's Avatar
Hey, I would like one. Please PM me your paypal and money will be sent.
The Law is offline
Old 06-22-2011, 09:01 PM
b15azn's Avatar
First five, 1/5, 3 spots left:
2. The Wizard/maxima.org
b15azn is offline
Old 06-22-2011, 09:06 PM
b15azn's Avatar
pm sent
b15azn is offline
Quick Reply: International FS: Spring is Coming!!!QT Adjustable links for A32 A33 on sale!!!
