Lots of random parts, garage clean out!
I'm nutty for Nissans
For pics, go here: http://s130.photobucket.com/albums/p...tter101/parts/
Prices are shipped and pp in the CON US
Passenger side view mirror, Black, non heated. $35
Pair of rear Konis, car was in an accident and one piston is slightly bent. I ran them for a few years like that, only issue is one seems stiffer than the other. They work and do not leak. Use them as is or send them to Koni for a rebuild. $100
00-01 MAXIMA trunk emblem painted black. Was on my dash for a few years. $7
Hazard and defrost switches, untested but I can test them, $10 for both.
Moog sway bar end link bushings, total of 4, brand new, $3 SOLD
OEM crush gasket, 20691-38u00, Gasket for rear exhaust manifold/Y-Pipe junction new in package, $4
Napa axle seal, 15372, supposedly fits both sides of m/t and left side of a/t, brand new, $15
Used cat bracket/hanger, a bit rusty, $8
2 OEM rear upper strut mounts with isolators, great conditon, $30
99 homelink sun visors, grey, good shape, newer rolling code style $35
99 main fuse panel, complete with relays, fuses, brackets, $30
2 Front struts, blown, will prep them for Konis, as is or prepped $50
Coil cover on front valve cover, fair condition, scrapes around screw holes, $15
Pair of OEM lower control arms, need ball joints and probably bushings, will prep them for ES bushings, comes with control arm bushing pins $50 as is or $90 prepped
OEM mid pipe/oil separator, complete with accordion coupler, maf reducer, IACV hose, and all clamps, $30
02-03 Muffler, typical rusted off inlet flange, no fancy tips, in good overall shape, will cut down inlet pipe to make shipping easier, $100
Dynomax axle back muffler w/ huge polished Magnaflow tip, ready to be bolted on complete with inlet, flange, and hangers, fit my Stillen B pretty good, $75
Matt93SE
04-08-2018 09:23 AM
