How-To: Install AE Pedals + 350Z Dead Pedal On Your 4th Gen
Old 06-12-2008, 10:54 PM
99BlackMaxMS's Avatar
Alright, since there is no write-up for this on the .org, I figured I would take everyone though a step-by-step process of how to do it. It is really an easy job and anyone can do it.
Parts Needed:
(1) Nissan 350Z Footrest Assembly: Part # - 67840-CD00C ($23.68)
(2) Nissan AE Maxima Clutch/Brake Pedal Cover: Part # - 46531-AB000 ($19.14 ea.)
(1) Nissan AE Maxima Gas Lever Assembly: Part # - 18005-4Y900 ($27.76)
(1) 8x1-3/4 Flat Philip Head Zinc Finish Screws ($1.03)
I got the OEM parts from Dave Burnette at Southpoint Nissan at cost, and after shipping my grand total of parts came to $99.50 with the screws added in.
99BlackMaxMS is offline
Old 06-12-2008, 10:55 PM
Tools Needed:
Bench Vise
Metal Hack Saw
Bench Grinder
Power Drill
1/8" Drill Bit
10mm Socket
Ratchet
Small Philips Head Screwdriver
Long Flathead Screwdriver
Stubby Flathead Screwdriver
Step One: Preparing The Dead Pedal
The 350Z does not come from the factory with an elevated spot for a dead pedal, therefore there is a lot of unnecessary plastic that needs to be cut away.
First, remove the five (5) screws (four silver metal ones at each corner, and one black one in the center). Put the aluminum cover in a safe spot as it is very bendable.
Once separated, clamp the black plastic base to the bench vise and start sawing away. Leave about 1/2-3/4" of clearance between the top and the side of the pedal. Next, use the bench grinder or a sander/sandpaper to finish the edge of the pedal and to even out the base. It should look like this when finished:
Old 06-12-2008, 10:56 PM
Step Two: Positioning/Mounting The Dead Pedal
Now that your dead pedal is correctly cut and finished to your liking, use the small Philips head screwdriver and screw in the small black screw to secure the aluminum plate to the base.
Go outside into your car and place the pedal where you would permanently like to place it. Rest it in place and begin drilling. You can drill directly through the carpeting. After drilling the four holes, take one 8x1-3/4 screw and fill in the four holes you just drilled. Voila, your dead pedal is installed and secured safely.
Before:
After:
Step Three: Clutch/Brake Pedals
First off, if you have an automatic, you complete this task with only one pedal (clearly) but can use the same method as I did.
Begin by peeling back the old clutch and brake pedals. They should come off with little effort. I found it best to reinstall the new pedal cover in a specific order, making each corner/side easier to slip on. Using the stubby flathead screwdriver, slide the top right corner and right side on. Next, use the flathead to flip the backing away while you set the top left part of the cover in place. Continue this process until you get the entire cover on.
I found it best to install the cover in the following order:
Continue on and do the same for the brake pedal.
Step Four: Accelerator Pedal
Begin by removing the throttle cable from the very top of the pedal assembly. It is kind of tricky, but if you wedge your long flathead screwdriver between the plastic clip and the metal on the pedal arm, it will pop free. The cable is located where these two red arrows are pointing to:
Next, unbolt the two 10mm nuts holding the pedal bracket in place (located on the firewall). Once these are taken off, the whole gas pedal assembly (pedal and arm) will fall out.
Continue the re-installation of the new pedal in reverse order of taking out the old one (first bolt in the two 10mm nuts that hold the pedal to the mounting bracket, then clip in the throttle cable).
Old 06-12-2008, 10:57 PM
You are finished. Put back your floormat and enjoy.
Before:
After:
Old 06-12-2008, 11:18 PM
Snypa's Avatar
Well done !!!...looks good mate.
Snypa is offline
Old 06-13-2008, 12:32 AM
maxx0831's Avatar
looks great!!
maxx0831 is offline
Old 06-13-2008, 06:47 AM
Kevlo for President
Kevlo911's Avatar
Nice write up. I believe the old one say you can swap out just the gas pedal by drilling out the back of the pedal bigger.
Kevlo911 is offline
Old 06-13-2008, 07:04 AM
Wild for Width
Fr33way™'s Avatar
Nice job and thanks for detailed pics.
Fr33way™ is offline
Old 06-13-2008, 07:30 AM
ajcool2's Avatar
Cool looks like my Z. lol
ajcool2 is offline
Old 06-13-2008, 07:40 AM
QNO_A32's Avatar
good job.... this is a nice cheap little interior project.+1
QNO_A32 is offline
Old 06-13-2008, 08:17 AM
G4nismo's Avatar
very nice write up man! i need to do this sometime down the road...
G4nismo is offline
Old 06-13-2008, 09:01 AM
MOHFpro90's Avatar
Holy crap that was a nice write up. Yeah looks hella better man, very nice job.
MOHFpro90 is offline
Old 06-13-2008, 09:44 AM
SoMarvelus's Avatar
yeah, thats nice, now whats needed is the black carpet
SoMarvelus is offline
Old 06-13-2008, 11:56 AM
Bandfan1024's Avatar
Looks awesome, love the pedals!
Bandfan1024 is offline
Old 06-13-2008, 03:04 PM
Project Ruby......
4DRSpeed's Avatar
good job on the write up. With the gas pedal all you need to do is take the stock pedal off. The Z's pedal hole is a little bigger, so I just took some electrical tape and wrapped it around the pedal assembly and then just slid the Z pedal on. It was nice and snug then.
4DRSpeed is offline
Old 06-13-2008, 03:27 PM
Silver Tooth S2K 9k FTMFW
95 maxima se's Avatar
wow im gonna have to do this to my max
95 maxima se is offline
Old 06-13-2008, 06:43 PM
khantalha+'s Avatar
nice work man.... good job .. and thanks for the part numbers tooo
khantalha+ is offline
Old 06-13-2008, 07:38 PM
Turbo 4th Gen
93altima's Avatar
This Should be Stickied ill try this in about a month or two
93altima is offline
Old 06-13-2008, 10:11 PM
Thanks for all the compliments guys. Kevlo already stickied it in the interior sticky under the 4th gen forum.
For the reference these are stock 20th anniversary edition pedals (clutch, brake, and gas) with only the 350z dead pedal.
Old 06-13-2008, 10:43 PM
4th Gen Parts King
Maxima_Joe's Avatar
Do you happen to know if they make the brake cover for automatic cars?
Maxima_Joe is offline
Old 06-14-2008, 08:39 AM
nismology's Avatar
Yes.
46531-AB010
nismology is offline
Old 06-14-2008, 09:34 AM
maxina97's Avatar
Wow! I can't wait to try this one out. Looks Good.
maxina97 is offline
Old 06-21-2008, 01:16 PM
speedymax99's Avatar
I just did the install and was very easy to put in
speedymax99 is offline
Old 06-22-2008, 07:54 AM
Gb2St's Avatar
damn looks good, might just have to do that
Gb2St is offline
Old 05-12-2009, 09:09 AM
xXDarkNightXx's Avatar
NICE!!!!!!!
Hey, how much did you pay for shipping??
xXDarkNightXx is offline
Old 05-12-2009, 01:17 PM
No more Maximas...
pmohr's Avatar
Well if you actually do some math, $8.75 or less.
Now why did you bump an 11 month old thread to ask something like that?
Good writeup though.
pmohr is offline
Old 05-12-2009, 07:13 PM
Max-e-MO!'s Avatar
Finding an 2000 AE with the pedal your looking for (auto/manual) and get the kit for about 20, that's what I did. Though the 2000 doesn't offer the dead pedal.
Max-e-MO! is offline
Old 09-27-2010, 05:43 PM
gdal's Avatar
Thanks for the writeup!!
Is there a gap between the sheetmetal behind the dead pedal area? I'm don't want to drill only to have a rust issue down the road.
gdal is offline
Old 06-21-2015, 07:23 PM
chrisduke's Avatar
Originally Posted by 4DRSpeed
good job on the write up. With the gas pedal all you need to do is take the stock pedal off. The Z's pedal hole is a little bigger, so I just took some electrical tape and wrapped it around the pedal assembly and then just slid the Z pedyal on. It was nice and snug then.
I know this thread is super old but it motivated me to change the pedals in my 2002.
I did the same with the gas pedal as far as using the AE pedal and not the whole assembly. Also used a little electrical tape so the pedal was tight at the bottom section.
The old pedal can be pried off with a small flathead.
I still have to do the dead pedal.
chrisduke is offline
Old 09-29-2015, 08:25 AM
Stagnet04's Avatar
Thats sick, will 350z pedals fit 4th gens? not just the dead pedal?
Stagnet04 is offline
Stagnet04
08-16-2015 11:15 PM
ef9
08-13-2015 01:19 AM
MikesChevelle
08-10-2015 10:53 AM
ViciousVQ30
08-05-2015 05:40 PM
Quick Reply: How-To: Install AE Pedals + 350Z Dead Pedal On Your 4th Gen
