I'm thinking my engine is toast......
Old 05-23-2008, 10:47 AM
Whitebread's Avatar
Went to get the oil changed today and ended up with way more than I paid for. While the techs were changing the oil, one triggered the alarm, panicked, began randomly pushing buttons on the remote and triggered the remote start while the pan was dropped..............
The manager pulled the positive lead on the battery within 5 seconds, or so he says.
The car runs as if nothing happened, but from experience I know that bearing wear is difficult to diagnose. The only two audible symptoms I know of are crankwalk and rod knock, neither of which I have. The fact that bearing damage occurred is undeniable, but just how much is what I'm worried about. I had originally planned on driving my 03 until it fell apart, which I assumed would be well after I graduate (I'm 20 will be a junior in the fall) but now I'm not confident the car will make it. I've got 90100 miles on the clock and I would love to get an idea of how much life the engine has left. Getting the engine disassembled and tolerances checked is not an option but, I was thinking of getting the oil tested. Would high metal concentration be able to provide some estimate on engine life? Since the oil just got changed, should I wait a little before sending a sample in?
Thanks.
Whitebread is offline
Old 05-23-2008, 10:52 AM
Norkoastal's Avatar
Thanks.
They should be liable regardless if the damage is severe or not.. I doubt he got the battery lead off that quick... More like a minute me thinks..
Norkoastal is offline
Old 05-23-2008, 10:58 AM
Whitebread's Avatar
Well, I got a statement from the manager where he wrote out what happened and signed the document. He told me 5 seconds 3 times, but wrote 10 seconds. I don't know why he would say 10, it only strengthens my argument should I decide to take the place to court. But I have to agree with you, I wouldn't be able to pull off the battery lead that quick, they are bolted onto the terminals.
This all would have been avoided if I had remembered to disable the damn remote start and the alarm.........................
Edit: I seriously doubt any engine would last for a minute with 0 oil pressure.
Old 05-23-2008, 11:27 AM
ICEMAN76's Avatar
Ok quick question. Even though you pull the terminals off of the battery wouldn't the engine keep running?? Isn't that what the alternator is for?? If that is the case, why would you pull the terminals?? Hopefully all goes well for you though. G/L. Take them to court if you have too. I don't trust him if he told you 5 min. and he wrote 10. Something isn't right.
ICEMAN76 is offline
Old 05-23-2008, 11:41 AM
Whitebread's Avatar
Pulling the battery lead kills spark and fuel injection. The only think keeping the engine spinning is inertia. Friction and pumping loads make quick work of the momentum of the reciprocating mass in the engine. Its the same as turning the engine off using the ignition.
Old 05-23-2008, 11:43 AM
mist max2000's Avatar
you have a solid case.. get a good lawyer and take them to court.. going to be a PITA but you will regret it if you dont..
mist max2000 is offline
Old 05-23-2008, 12:08 PM
Froggmann's Avatar
I think your overreacting, the motor is fine. If it had run a minute or 3 yes you could have some major damage Hell a motor doesn't get fully oiled until 45seconds to one minute after cold start. If you want restitution have them eat 2-3 more oil changes at another shop.
Froggmann is offline
Old 05-23-2008, 12:17 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
as you said no problem and the engine is runnign fine.. I see no case unless the engine stpo working within a few weeks form today....
Lontar1 is offline
Old 05-23-2008, 12:19 PM
nsnrider's Avatar
pulling the battery terminal of while running will NOT kill the engine, as mentioned above, the alternator will supply enough juice to keep it running. if he (the tech) ran the motor for 5-10 seconds without oil, you shouldn't have too much problems but if he ran for a considirably more than that, I can see a whole bunch of problems for you in the future. just keep on eye on it and if you see/hear problems, bring it to a trusted mechanic for a diagnosis and if need be, get another motor in by the oil change shop (out of their pocket).
also, 90k miles is nothing for this motor, if you keep up the maintanance, it should be good for another 100k miles.
nsnrider is offline
Old 05-23-2008, 12:31 PM
Da Roller Coaster!
foodmanry's Avatar
at pulling positive battery cable to kill the car. If your alternator is working properly then it will not stop.
The only way you can really build a case is if you have had your oil tested previously. Then you can get another oil analysis by sampling at your next oil change interval and compare the results.
Without that you don't have much of a leg to stand on...
foodmanry is offline
Old 05-23-2008, 01:06 PM
Whitebread's Avatar
Normally the motor will keep running, but my alternator isn't functioning as it should.
I don't plan on taking legal action unless something actually goes wrong. I just wanted to know if an oil analysis could give some insight into engine life.
Old 05-23-2008, 01:07 PM
Curb Rash Repair 100 a wheel
Maxima112's Avatar
well technically if you have the hood pin connected (if installed correctly) when he opened the hood while the remote start was on to disconnect the battery. it would auto shut down the engine the second the hood is popped and the pin it released.
Maxima112 is offline
Old 05-23-2008, 01:16 PM
If the car is already started, it will run with no battery so whoever thinks otherwise.
NmexMAX is offline
Old 05-23-2008, 01:21 PM
Whitebread's Avatar
I'm not saying your wrong. I've been noticing reduced bass when playing music loud, which is what makes me think the alternator is going. Although, this is just speculation.
I'm going to call the guy now and ask him if he really did pull the battery lead.
Old 05-23-2008, 01:22 PM
Whitebread's Avatar
Eh, its a possibility but I think the hood was already up because they had already drained the oil.
Old 05-23-2008, 01:23 PM
Sure that makes sense, especially if @ idle, but i'm calling out the tech at the shop where he stated he pulled the + cable
NmexMAX is offline
Old 05-23-2008, 01:35 PM
Whitebread's Avatar
The manager said that while he was trying to pull the battery lead, another tech was attempting to kill the engine with the key (he didn't tell me this when I was at the shop). When using the remote start with my vehicle, there are only 2 ways to turn the engine off. One way is to push the starter button on the FOB twice and the second way is to push the break pedal before turning the key to the on position. My guess is the second tech who jumped in the driver seat pushed the brake while trying to insert the key into the ignition. Such a situation is entirely plausible. And could easily occur within the 5 second time frame the manager claims this happened in.
Old 05-23-2008, 01:42 PM
Da Roller Coaster!
foodmanry's Avatar
This is true....it is an integral safety part of a remote start system. Either your hood pin wiring is fubared or the oil change place is making **** up. My vote is for the latter...but you can always check your wiring for the hood pin and remote start. You will see some stray wire running into one of your front hood pins, most likely the one on the driver's side.
Old 05-23-2008, 01:46 PM
Cletus
SoonerFan's Avatar
your engine is fine
SoonerFan is offline
Old 05-23-2008, 01:52 PM
Maxima112's Avatar
then if installed correctly, the remote start would not have started the engine.
Old 05-23-2008, 01:56 PM
UOA time?
NmexMAX is offline
Old 05-23-2008, 01:57 PM
Whitebread's Avatar
I really don't think the hood pin played a part in all this. One of the first things a tech would do during an oil change is pop the hood. This alone is not enough to trigger my alarm. Furthermore, the hood was probably popped before my alarm system rearmed itself (I believe this takes 30-45 seconds after the ignition is killed). The whole reason this happened is because one of the techs got spooked by the alarm and started pushing buttons. Therefore, if my assumption above is correct there is no way the hood pin could have killed the engine.
Because the techs did not know how to use the FOB, I doubt they were able to use it to kill the car. The only remaining possibility is the brake pedal. Therefore, there are two possible outcomes to this situation. The first is that they were unable to push the break pedal and the engine grinds itself to a halt. The second is that they push the pedal most likely accidentally, and the engine quits. The engine runs for a few seconds without oil.
This couldn't have been done on purpose and my engine block and crank shaft are not fused into one. I think the manager is telling the truth. 5 seconds is more than enough time to move 4 feet, open the door and push the brake pedal. And thank God he did.............
Old 05-23-2008, 02:01 PM
Whitebread's Avatar
I know for fact that the engine will start remotely with the hood up and I can pop the hood with the car started remotely (key not in the ignition). This is something I'll have to address.
Old 05-23-2008, 02:02 PM
Whitebread's Avatar
UOA time?
UOA?
Old 05-23-2008, 02:20 PM
nismology's Avatar
No he's not and incorrect.
nismology is offline
Old 05-23-2008, 03:57 PM
That's Mr. Detail to you
Scottwax's Avatar
If it really was only 5-10 seconds, there probably isn't any appreciable damage. However, if it was closer to a minute (which is entirely possible), then there could be problems down the road. No knocking is a good sign, however.
Scottwax is offline
Old 05-23-2008, 04:00 PM
jasonmax's Avatar
are we talking about the engine, or how the car was started?
the service should responsible for all the damages, so keep driving it until something happens.
jasonmax is offline
Old 05-23-2008, 04:50 PM
No more Maximas...
pmohr's Avatar
UOA?
Used Oil Analysis.
I think otherwise On this specific vehicle, true. Different vehicles behave different ways when removing the battery terminals, though. Some die, some won't.
That being said, that's how I used to jump start my '87 Maxima - put the battery in it from my '95, then switched them out again once it was running. In hindsight, a set of jumper cables would've helped back then...
If the hood pin is released period, a correctly installed remote start will not activate.
That is, 'correctly installed' per the manufacturer's directions. I for one didn't hook it up on my car, or on Merlyn's A33B (remote start is a useful tool for diagnosis of various problems, and very convenient during other diagnoses as well). If you're not an idiot, all problems can be avoided (kill switch enabled when doing things like this, for example).
It doesn't matter that it didn't transition while the alarm wasn't enabled, or while it tried to remote start; cases like this are exactly the type of thing they're trying to prevent by having a hood pin switch disable on remote starts.
pmohr is offline
Old 05-23-2008, 04:53 PM
Originally Posted by pmohr
<Insert things that pmohr said about cars other than the 5th gen Maxima here>
But this is the 5th gen section, right?
NmexMAX is offline
Old 05-23-2008, 04:55 PM
No more Maximas...
pmohr's Avatar
pmohr is offline
Old 05-23-2008, 05:08 PM
merlin2375's Avatar
Another reason to do your own oil changes...
Hope it all works out. I tend to agree that if it's running fine now there's not reason to worry that it will fail in the coming future. +1 that a running car will keep running without the battery, unplugging the battery while running is a time-honored way to test the alternator.
merlin2375 is offline
Old 05-23-2008, 05:10 PM
Why did they drop the pan?
NmexMAX is offline
Old 05-23-2008, 05:14 PM
Cletus
SoonerFan's Avatar
good point.....
Old 05-23-2008, 05:15 PM
Cletus
SoonerFan's Avatar
and even with the pan dropped, there is still oil in the engine coating all the moving parts.
Old 05-23-2008, 05:19 PM
Originally Posted by SoonerFan
good point.....
I never really read the original thread until now.
NmexMAX is offline
Old 05-23-2008, 05:25 PM
Cletus
SoonerFan's Avatar
me either
Old 05-23-2008, 05:49 PM
bigmike8771's Avatar
the car shouldn't have STARTED in the first place, with a remote start its not suppose to start with the hood, its a safety they have in the design of the alarm. i KNOW mine doesnt start with my hood open.
bigmike8771 is offline
Old 05-23-2008, 05:51 PM
Cletus
SoonerFan's Avatar
um that has been established...thanks
Old 05-23-2008, 06:07 PM
Whitebread's Avatar
Used Oil Analysis.
Already ordered the test kit
Yes, this has already been established. Like I said earlier, my remote start WILL start my vehicle with the hood open and I CANNOT kill the motor by poping the hood with the key NOT in the ignition. Either the system was incorrectly installed or the hood pin is not working as it should. Another thing I'll have to add to the fix-it list. The car does have a kill switch, but I forgot to disable the system this one time.
Old 05-23-2008, 06:09 PM
Whitebread's Avatar
Probably looking for other things that "need" to be done. One of the things the manager mentioned was that a third tech (in the bay below the car) had his hand in the crank case when the engine started. I didn't ask why they took the pan off.
Quick Reply: I'm thinking my engine is toast......
