This is power steering fluid right?
Old 04-05-2008, 06:00 AM
Scott LaRock's Avatar
Scott LaRock is offline
Old 04-05-2008, 06:02 AM
caseymaxima's Avatar
That could be anything! As far as PS fluid goes remember that it is just regular ATF, so is your trans leaking?
Zack
caseymaxima is offline
Old 04-05-2008, 06:04 AM
No my trans isn't leaking but the car is making a mess and the power steering fluid is draining.
Old 04-05-2008, 10:08 AM
Oh then that could be blinker fluid all over your driveway.
Seriously.
Old 04-05-2008, 01:33 PM
MAXIMAK99's Avatar
There's no way to tell what fluid it is from the pic. If you say that the power steering fluid is draining then why dont you just get that fixed and see if the problem stops.
MAXIMAK99 is offline
Old 04-05-2008, 06:10 PM
QNO_A32's Avatar
you just answered your own question. clean and dry everything PS related. start the car and kinda slowly go lock to lock. than look to see where it starts getting wet.that should help you.
QNO_A32 is offline
Old 04-05-2008, 07:43 PM
Snypa's Avatar
power steering it is then.
Snypa is offline
Old 04-05-2008, 10:25 PM
00vi Equipped.......
maxgp1029's Avatar
Is this a joke?
maxgp1029 is offline
Old 04-05-2008, 10:35 PM
hot_wax_tree's Avatar
most likely your ps.
hot_wax_tree is offline
Old 04-05-2008, 10:50 PM
tarun900's Avatar
Yeah when my rack and pinion was leaking PS fluid, it looks dark too. We originally thought it was oil...
tarun900 is offline
Old 04-06-2008, 08:06 AM
Maintenance Monster
dgeesaman's Avatar
Gear oil, ps fluid, ATF, and motor oil all look dark on the ground.
Get under the car and find the leak.
dgeesaman is offline
Old 04-06-2008, 08:23 AM
SLOW
Nealoc187's Avatar
you've got to be kidding. did you seriously just take a picture of a spot on the ground and ask us to identify the fluid? did you seriously just say "hey guys my power steering fluid is disappearing and I have some unknown fluid on the ground, do you think my PS fluid is leaking?" come on...
Nealoc187 is offline
Old 04-06-2008, 08:50 AM
tarun900's Avatar
^^Hahaha....yeah I guess your question has been answered. When my PS fluid was leaking, I could look at the rack/pinion thing and see it leaking, so I had the rack/pinion replaced.
tarun900 is offline
Old 04-06-2008, 08:54 AM
wants an I35
ROCKART's Avatar
tranny fluid = ps fluid. both are reddish unless youve actually put "power steering fluid" in your reservoir, which is clear
those spots on the ground look like water the way they are dispursed. im guessing thats condensation from your ac (water).
ROCKART is offline
Old 04-06-2008, 09:24 AM
Kbghdg's Avatar
Looks just like my carport under my 1995 gle did. Before I had the steering rack replaced. Also the control arm bushings were shot too. My brother in law did all the work and no more leaks.
Kbghdg is offline
Old 04-06-2008, 12:46 PM
tarun900's Avatar
What are control arm bushings?
tarun900 is offline
Old 04-06-2008, 01:11 PM
andrei3333's Avatar
I have observed this many times, it disappears after a while - scared me the first time though... but i dont think i eved had that much of it on the asphalt...
just check the damn underbelly
andrei3333 is offline
Old 04-06-2008, 01:41 PM
LeVeL's Avatar
wow
Your ps fluid isnt evaporating so yeah, Id say its all over your driveway.
Sniff it next time... no way to tell by looking at it
LeVeL is offline
Old 04-06-2008, 04:08 PM
Relax people, I'm no mechanic so give me a break already. My car has multiple leaks and I'm just trying to find out what is what.
I'm going to the mechanic in the morning.
Old 04-06-2008, 04:14 PM
SLOW
Nealoc187's Avatar
you don't need to be a mechanic to have common sense and use some modicum of logic.
Old 04-06-2008, 04:24 PM
Product_Of_Korea's Avatar
a dog could of just took a runny dookie and someone sprayed it with the hose and that whats left over.
seriously you wouldnt be able to tell from a stain on the street. if anything if its leaking that bad put a big peice of plastic under your car over night where you suspect the leaking is coming from and go from there
Product_Of_Korea is offline
Old 04-06-2008, 06:13 PM
Kbghdg's Avatar
I should have said "Tranverse link bushings".
Kbghdg is offline
Old 04-07-2008, 07:43 PM
Sold
JSMax's Avatar
If it were truly common, would it still be called common sense?
JSMax is offline
Old 04-07-2008, 08:08 PM
tarun900's Avatar
Haha that still doesn't help me....anyoen tell me what this is? LOL
tarun900 is offline
Old 04-07-2008, 08:14 PM
Crusher103's Avatar
I think its a 5 year olds ****
Crusher103 is offline
Old 04-07-2008, 08:15 PM
nsnrider's Avatar
how about putting a white or some other light colored paper under car and take a note on what side trhe leak is comming from and what color it is. If your fluids are old, they will all pretty much be dark color and tough to identify amongs them.
But did you fix your p/s leak yet?
nsnrider is offline
Old 04-07-2008, 08:16 PM
nsnrider's Avatar
nsnrider is offline
Old 04-08-2008, 02:41 AM
im tellin you guys 5year old pee wouldnt stain like that im going with the runny dookie
Old 04-08-2008, 06:50 AM
Not yet, another mechanic told me its the rack and pin but I'm going to a different one today.
Old 04-08-2008, 07:20 AM
udienow's Avatar
you guys all fail... this is simple. I diagnosed all leaks:
Tho in all seriousness that doesnt look like any car fluids. I've had my share of leaking oil and trans fluid and the spots it leaves are darker then that. Looks like water spots to me. You need to smell the spots when they are still wet. Trans fluid has its own smell. If you dont know what that is take ur trans dipstick out and smell that, then compare. Last way to tell is park over a white towel, let the stuff drip on that and c what color the stain is on the towel.
udienow is offline
Old 04-08-2008, 08:25 AM
Kbghdg's Avatar
Buy a chiltons manual and look it up!
Kbghdg is offline
Old 04-08-2008, 08:27 AM
wants an I35
ROCKART's Avatar
i swear i read that in someone else post too....
ROCKART is offline
Old 04-08-2008, 08:39 AM
95BLKMAX's Avatar
sorry buddy, nice try, but you got it all wrong. Its very simple actually..
His MUFFLER BEARING is shot! So all the exhaust oil is dripping out the flanges!
Thats it! I just fixed his car,
I iz teh kthnxby
95BLKMAX is offline
Old 04-08-2008, 08:44 AM
absoundlab
it looks like cooking oil
Old 04-08-2008, 09:08 AM
udienow's Avatar
Oh.. sorry didnt really read the thread, just wanted to post my pic.
udienow is offline
Old 04-08-2008, 09:47 AM
black_maxed95's Avatar
its not PS fluid. your ps fluid is suppose to drain. Everytime you make a turn a little bit is used up.
black_maxed95 is offline
Old 04-08-2008, 10:03 PM
Crusher103's Avatar
ok maybe its the **** of a 12yr old
Old 04-08-2008, 10:11 PM
I have very similar spots on my drive way where I park and I know it is P/S fluid for me cause the rubber tubes on my return line are total crap and leaking. thats why I have 2qts of P/S Fluid in my trunk. just fallow the lines that lead from your P/S reservoir right after you have driven it and see if it is leaking.
Old 04-09-2008, 02:07 PM
ejarmol's Avatar
do you have steering fluid or stock steering fluid?
ejarmol is offline
Old 04-09-2008, 10:01 PM
and dookie...............
Quick Reply: This is power steering fluid right?
