1st & 2nd Generation Maxima (1981-1984 and 1985-1988) Learn more and share information about the 1st and 2nd Generation Maximas.
q45 caliper upgrade...
Old 12-29-2007, 05:43 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
anyone ever do this i wan wondering how this will go together. my homie slung me some and i heard that its a bolt on for 240 ppl and since we have the same nuckle hub assy it should be as easy. gonna try it tonight ill hit yall up later.
Big_E-Dog is offline
Old 12-29-2007, 09:02 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
ok its basically done just painting the calipers
so youll need the calipers, lines and rotors.
youll need to remove the dust sheild..
so it should look like this...
Old 12-29-2007, 09:07 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
the calipers should bolt right up with regular rotors but i got some different ones i think are larger than stock onesso i had to bore out the holes out a lil more to compensate...
the q45 rotors are a smidget larger than the maxima ones and are about 1/4 thincker as well. so i drilled the holes for the 4 lug assy...
test fit 1
test fit 2
and now the paint, no installed pics as of yet the paint is drying.
someone please buy this filter!!!!!
http://forums.maxima.org/showthread.php?t=545701
Old 01-09-2008, 08:59 PM
max95q's Avatar
Looks dang good!!! I like it alot. Great install mang
max95q is offline
Old 01-10-2008, 08:08 PM
Alex_V
FYI those aren't the same as 240sx hubs, RWD vs FWD. Theres a axle passing through one
The mounting points might be the same but thats about it.
Nice work though, I'll be doing a Q45 conversion on my 3rd gen some time next fall.
~Alex
Old 01-10-2008, 09:19 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
mounting points is waht i mean.
Old 01-11-2008, 02:51 PM
max95q's Avatar
Hey I got my info from a 240sx/stanza owner back in the day. Those were the words he told me
max95q is offline
Old 01-16-2008, 02:48 AM
Niku-Sama's Avatar
a hrmm, i wonder how far back they used the same mount for the calipers.
lets hope they go back to 1979.
Niku-Sama is offline
Old 01-21-2008, 02:36 AM
ColombianMax's Avatar
sweet, you beat me to the conversion. I got everything I need but I'm debating whether painting my q45 calipers red or polishing the crap out of them and just putting high temp clear coat so they always look shiny.
What do you guys think?
ColombianMax is offline
Old 01-21-2008, 06:32 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
cleaning them will make them gold color thats what i got when i power washed them+brake cleaner, same with the stock calipers.
should be easier for you because your 5 lug and you dont have to drill out new holes for the rotors.
Old 01-21-2008, 09:14 PM
Well, I actually have access to wirebrush on grind-wheel and sand blaster at work and already did one caliper partially...came out pretty good. you should see how nice my parallel links came out prior to painting them black with rust-o-leum spray paint.
Old 01-23-2008, 09:37 AM
boney's Avatar
i did this swap on my s13.. very good upgrade.
boney is offline
Old 01-23-2008, 08:35 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
so far i like it, it has a smoother stopping feel, but when you step on it hold on to your teeth!
Old 01-24-2008, 11:56 PM
Too cold to do this...cant wait for warm weather
Old 01-28-2008, 08:23 PM
maxitech's Avatar
Wimp...J/K
My high-temp black paint is drying on my Q45 calipers as I write this...gonna rebuild them and install them tomorrow.
FYI: just prepping these things for paint is a lot of work!
maxitech is offline
Old 01-28-2008, 08:26 PM
Originally Posted by maxitech
Wimp...J/K
Feels great to liven up the 1st and 2nd gen forum dont it? I've learned some things just by lurking around here
Old 01-29-2008, 10:24 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
Wimp...J/K
thats why i did it the easy way...
hit it up with a can of break cleaner then power wash the rest, whatever dosent come off prolly wont so i sprayed over it.
make shure the calipers are sitting in the sun as you spray so it wont drip, you might need 2 or 3 coats
Old 01-29-2008, 12:36 PM
I heard from traxtar944 that the brake caliper paint that you apply with a brush looks 10 times better than the spray on one, he's tried both. Anyone else notice that?
Old 02-19-2008, 06:35 PM
I love lamp.
maximase86's Avatar
What you need now is some 13 inch rotors.
maximase86 is offline
Old 03-12-2008, 06:40 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
this is no longer a caliper upgrade but a brake upgrade!!
dont forget the rears.....
different rotors i got look cooler than the other ones...
the rears are quite interesting, the rotor and hub is a complete assy, so i had to cut the rotor part off
then i had to grind down the hat a lil bit because itl make it fit a lil better in the q45 rotor
the q45 rotor has a iner lip that i had to grind off
Old 03-12-2008, 08:10 PM
vernk's Avatar
Are you planning to go to some bigger rotors? if you are check these out
http://www.sr20forum.com/custom-stee...squeemish.html
I think they will fit on our cars but not for sure yet, when I go to see p@ I will check for sure.
vernk is offline
Old 03-12-2008, 09:21 PM
NiZMo1o1's Avatar
I got a set of Q45 calipers F/S if anyone needs to run this setup
NiZMo1o1 is offline
Old 03-12-2008, 10:30 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
i think my ish is the same size as those the fronts are like 11.2 and the rears are bigger than the fronts by like .3 maybee so i think ill be good with what i got, its oem but not too flashy, looks like it would have been an upgrade from nissan. mostly the look that im looking for. now if i was going for the nismoified look then i would of went with the z32 front and rear.
nismo1o1 jump on the bandwagon cuz i also have a set of calipers, cross drilled/slotted rotors, pads and 1/4 inch spacers.
Old 03-13-2008, 10:09 AM
I love lamp.
maximase86's Avatar
Need more rotor diametar!
S
Old 03-13-2008, 10:37 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
what size are those, they look good, but then if i go to 13" ill have to make brackets(more) and for the front which is a lil bit harder, ill look into it tho.
Old 03-13-2008, 11:02 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
drill the 4 lug hole pattern...
pit a silicone 2.5 inch coupler in the middle of the rotor and a bolt in one of the holes and tightened it down. made holes in the 4 lug holes of the old front rotor and drilled with a metal bit, its essential that you use a speed drill above 15 volts (mine is 18v) get the water hose to cool the bit running it at low pressure so it runs on the bit and the hole cooling them both, essential to cool or youll kill your bit.
(comparison of rotor size)
put the hub into the q45 rotor and presto!
now for the caliper part using the maxima calipers because of the complexing e-brake situation. had to customize the bracket to fit the larger rotors.
grinded a lil off of the torque member(you might not have to but i did depends on how you make your caliper bracket.
Old 03-13-2008, 11:03 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
cut off the tips of the old caliper bracket and welded on some 1/4 inch tabs i got from the metal store.
getten better at welding and nhigh and low settings with metal.
use some washers to space the bracket from the caliper holder.
2nd Gen Boostinator
Big_E-Dog's Avatar
this mod spaces out the wheel 1/4 of an inch from the origonal position. fits the skirts perfectly but i am looking for some longer studs to be safe.
finished product
Old 03-13-2008, 11:16 AM
nice
Old 03-13-2008, 05:26 PM
I love lamp.
maximase86's Avatar
13" Cobra rotors. Jeff92SE used to sell brackets for these and quite possibly might still have some left.
S
Old 03-14-2008, 07:45 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
cobra as in mustang cobra??
Old 03-14-2008, 08:40 AM
I'm needing a caw
Jeff92se's Avatar
Um, your feet are greasy.
Jeff92se is offline
Old 03-14-2008, 09:11 AM
I love lamp.
maximase86's Avatar
Hi dar Jeffy.
Old 03-14-2008, 09:13 AM
I love lamp.
maximase86's Avatar
Yes.
Old 03-14-2008, 06:32 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
dont worry bout me toes! theyve seen lots of sparks, welding slags and all kinds of metal splinters. i love dem to death. ima look into gettin the rotors and see what it do.
Old 03-16-2008, 01:15 PM
I love lamp.
maximase86's Avatar
Working barefoot...werd. Now there is a man with a pair of steelies.
S
Old 04-19-2008, 11:51 AM
neo_densetsu's Avatar
I think the J30 Calipers would work as well, I believe they have the same bolt pattern as teh Q45 Calipers.
How about them Calipers? PowderCoat works really well on calipers, but preparing them takes forever! Will those Z32 Calipers fit?
neo_densetsu is offline
Old 04-20-2008, 08:06 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
they sure will. even with stock rotors..
Old 07-07-2008, 01:08 AM
daftinnovations's Avatar
if q45 caliper bolt on, 240sx will, j30 should, z32 turbo or non turbo should. he list goes on playaz!
daftinnovations is offline
Old 10-13-2010, 10:55 AM
lww
lww's Avatar
The REALLY important question is, will this work on a 1st Gen Max?
How different are the hubs and caliper mounts between the 1st gen and 2nd gen Maximas?
I suspect the 1st Gen is going to be stuck with 280ZX parts but I'd love to do a Z32 caliper upgrade on my 1st Gen Diesel Maxima!
lww is offline
Quick Reply: q45 caliper upgrade...
