o2 simulator - where can i get one for my 99
Old 11-17-2007, 04:56 PM
silverdustmaxim's Avatar
im looking for an o2 sensor simulator for my 99 gle and i find universal ones but i dont trust they will work . has anyone used them on a 99 succesfully and if so what kind and where to get them would be a great help.
silverdustmaxim is offline
Old 11-17-2007, 05:01 PM
No more Maximas...
pmohr's Avatar
You're not going to find one that will plug and play with an A32. Just use the universals...many people have on this board.
pmohr is offline
Old 11-18-2007, 01:38 PM
sounds good, whats the fun in pnp anyway?
thanks
Old 11-18-2007, 02:17 PM
Horizontally opposed.
mowgli29's Avatar
http://www.o2simulator.com/index.php...4b810beba73ee1
got that one on my 97. Works great.
I left the sensor in, to avoid throwing a heater circuit code, but I cut the signal lline and ran it to the o2sim instead.
mowgli29 is offline
Old 11-18-2007, 02:47 PM
Mctwist77's Avatar
What kind of CAT do you have?
Mctwist77 is offline
Old 11-19-2007, 07:11 AM
mowgli29's Avatar
I just have a straight pipe. I don't have to pass emissions where I live, and I think it sounds better without a cat.
mowgli29 is offline
Old 11-19-2007, 07:14 AM
jvckustumz's Avatar
yep, same here! so what does an o2 sim. do?
jvckustumz is offline
Old 11-19-2007, 08:04 AM
mowgli29's Avatar
I'm just gonna say everything, before people ask it one post at a time...
95-96 have "non-heated" sensor mounted ON the cat. The ECU looks for o2 signal only.
97-99 have a "heated" sensor mounted BEHIND the cat. The ECU looks for o2 signal AND heater circuit.
non heated sensor = 3 wires (power, ground, signal)
heated sensor = 4 wires (power, ground, signal, heater)
The heater circuit is basically just power, run to the sensor to "heat" it up, rather than waiting for the exhaust gases to heat it up. This way it can begin working sooner.
The heater has a resistance associated with it, if the ECU doesn't see this resistance, it throws a code. You can try to simulate the heater with a resistor, but thats just a PITA IMO.
This means on a 95-96 you can remove the sensor and completely replace with a simulator.
On a 97-99 you have two options. You can try to simulate the signal AND the heater(good luck!). Or, you can do what I did, and leave the sensor's power, ground, and heater hooked up. Then just splice in the simulator's power, ground and signal. You retain the sensor for the heater, and simulate the signal. This makes the ECU happy and he won't throw a CEL at you!
Oh, and o2 sensor wires don't like to hold shape when bent, and solder won't stick. You'll have to crimp them together somehow, or I suppose you could use a vampire tap to avoid cutting.
everything ^^^ is AFAIK. correct me if something's wrong....
mowgli29 is offline
Old 11-19-2007, 08:09 AM
mowgli29's Avatar
Like I said the ECU looks to the o2sensor to see if the cat is working or not.
An o2sim pretends to be a working sensor that sees a working cat.
mowgli29 is offline
Old 11-19-2007, 01:48 PM
jvckustumz's Avatar
oh ok, i learn something new everyday lol
Old 11-19-2007, 09:15 PM
KRRZ350's Avatar
No fawking ****! Wow, that explains it. I tried to solder o2's into my brothers audi recently and I was heating the wire cherry red with a torch and for the life of me could NOT get it to do anything but roll off.
KRRZ350 is offline
MaximaDrvr
08-19-2015 08:20 PM
1992maximase30
08-05-2015 09:27 PM
BlackBIRDVQ
53
06-04-2007 12:44 PM
NmexMAX
01-12-2005 09:05 PM
Quick Reply: o2 simulator - where can i get one for my 99
