looong cranks, losing fuel pressure??
Old 10-16-2007, 05:43 PM
TunerMaxima3000's Avatar
UPDATE 01/11/07:Problem Found>http://forums.maxima.org/showthread....ght=hard+start
anyone else experiencing something similar. READ THIS THREAD! It fixed my problem> To sum it up you need to run a ground from the starter bolts to the tranny, I also added one from the tranny ground point to the strut mount stud(body)
just looking for some advice, car has 213,000KM,
just recently after the car has cooled down (a few hours) it'll crank over, 'half' fire, then crank again, repeats for a good 8 cranks.
If I give it a shot of throttle when it 'half' fires she'll start up.
Seems to me (guessin) that im losing fuel pressure after it sits.
Is there a pressure check valve or something of the sort that could be allowing it to lose its prime when its sitting for any length of time, or what/how show I check? only other thing I can think is a relay, but it only does it after it sits for an hour or two. Its a 5spd.
Any advice would be great. sure someone has experienced this, damn maximas the run great, if you can get em runnin, thanks for any help.
matt
TunerMaxima3000 is offline
Old 10-16-2007, 08:09 PM
19Maximus98's Avatar
I am having similar problems with my Max, hard starting after sitting for a few hours. I figured the fuel pump is working so maybe it is the fuel pressure regulator.
19Maximus98 is offline
Old 10-16-2007, 08:13 PM
Hammy
I Know What it is, Give me 2 minutes to look up the part name.
Edit:
Its the tempature coolant sensor, IIRC it was 17 bucks at autozone and all you need to change it is a 19mmn
wrench.
http://www.autozone.com/selectedZip,.../selectZip.htm
Old 10-16-2007, 08:23 PM
andrei3333's Avatar
i had a weird crank recently that was fixed by replacing the starter
check my video and tell me if its similar to your problem
http://www.youtube.com/watch?v=2b6-nN0mr4c
andrei3333 is offline
Old 10-16-2007, 08:31 PM
wants an I35
ROCKART's Avatar
im watching and thinking "holy sh*t his spedometer goes up to 220mph!! what mod is that?"
then i remembered you were canadian and i was an idiot.
ROCKART is offline
Old 10-16-2007, 08:45 PM
nsnrider's Avatar
Edit:
wrench.
are you sure, i would think that its the idle control sensor on the TB, those go bad often when car hits over 100k miles
nsnrider is offline
Old 10-16-2007, 08:49 PM
andrei3333's Avatar
AAAAhahahahahah thats hilarious - yeah its called the Canadian Mod and its available anywhere in CANADA
yeah i wish i could drive that fast, and BTW if the government does not want people to speed then why not put a chip in every car that tops out the speed at 100 Km\h (maximum legal speed limit in Ontario)
PS im not canadian btw i just live here
Old 10-16-2007, 10:05 PM
Hammy
In the FAQs there is something about it, being that if the car sits in the sun or is warm that it has starting issues because of the TCS.
I'm going to look more into it though, You may be right.
Old 10-16-2007, 11:12 PM
KRRZ350's Avatar
Check 'ur coolant level first (K.I.S.S.), check your FIC (Fast-Idle-Cam) It's a small plunger on your throttle body that applies throttle when your engine is cold, it retracts away from the throttle bracket once warm coolant begins to pass through it, it has an adjustment, and steps for doing so can be found in the FSM, EC-29.
KRRZ350 is offline
Old 10-17-2007, 02:06 PM
J-hop's Avatar
lol because people like us would just take those chips out.
J-hop is offline
Old 10-17-2007, 04:29 PM
Thanks for the feedback,
andrei it is similar to your vid, just more cranking in between fire's.
my starter is new however.
coolant's good, ill have to inspect this FIC tomorrow. Good info never would have known that man appreciate it. Ill keep updated.
Old 10-17-2007, 09:19 PM
My issue is hard starts after the car has been sitting for a while and cools down, so I dont think it could be this. As for Starter troubles, having had this porblem with previous cars I am certain it is not that. Will do somemore tinkering this weekend. Thanks
Old 10-18-2007, 11:56 AM
95jr6708's Avatar
hey man, i got the same problem, i have had it for some time...and now with the weather cooling down, it seems harder and harder...so if you figure this one out, let me know what you did please!
and if i solve mine i will let you know...
i have had a similar problem it ended up being the ignition switch...
95jr6708 is offline
Old 10-18-2007, 05:05 PM
J-hop's Avatar
Edit:
wrench.
I tend to agree with you, i ran into this problem when i was tuning my cranking pulse width on my custom fuel management system on my last car. A cold engine requires a lot more gas during startup then a hot car - has to do with atomization etc, therefore if the temp sensor is reading improperly and is telling the ecu that the coolant is hot/warm then you will have to crank it over several times get it to pop. If I were you I would try it, its a pretty inexpensive fix and probably needs to be done anyways
J-hop is offline
Old 10-18-2007, 07:16 PM
67whitegoat's Avatar
Edit:
wrench.
CTS.
67whitegoat is offline
Old 10-18-2007, 08:16 PM
Thanks guys, I am going to give this a try and let you know what happens. The price on that link is actually $34, but probably needs to be replaced anyway. Will get back to you next week.
Old 10-19-2007, 07:09 AM
scooby68's Avatar
Similiar but different hard start
Longgggggggggg crank when starting first thing in the morning AND also if car has sat for half hour or sometimes even 15 minutes, so its not hot/cold issue. It will start instantly if I interrupt the initial crank (let off the key) and immediatly turn the key again and crank it a second time whether it is hot or cold! Happens every time, second turn of key and the car starts instantly like it was new. Changed fuel/air filters, using 93 oct, suspect fuel regulator issue?
scooby68 is offline
Old 10-20-2007, 10:07 AM
Originally Posted by scooby68
Longgggggggggg crank when starting first thing in the morning AND also if car has sat for half hour or sometimes even 15 minutes, so its not hot/warm issue. It will start instantly if I interrupt the initial crank (let off the key) and immediatly turn the key again and crank it a second time! Happens every time, second turn of key and the car starts instantly like it was new. Changed fuel/air filters, using 93 oct, suspect fuel regulator issue?
upon further playing around, ive noticed my issue to be the same, and also if i crank it, let off, and turn back immediately, it works! I also changed air/fuel filters.
I wonder now, because it seems to do it after only 15mins of sitting, if it could be a relay, starter most likely, at least i would assume so because of the crank/letoff/crank right away. Im goin out right now to check the other suggestions Ill let you all know what turns up,
Old 10-20-2007, 12:27 PM
xkazik's Avatar
i have the same problem . where is this part located http://www.autozone.com/selectedZip,.../selectZip.htm ? if i want to change it?
xkazik is offline
Old 10-22-2007, 03:30 PM
Still no luck, getting worse
ok sorry for the late update,
ive checked the FIC, all apears good there,
and the CTS, is this not the ECTS ?(engine coolant temp sensor/engine temp sensor). In checking the FIC you also check the ECTS correct?, so it should be good right?
I forgot to mention i have 1 code, but ive had it for 30,000km. its the EVAP 0903.
so i doubt it has any bearing here just wanted to mention.
I'm still lost, and it seems to be getting worse, have not noticed much difference between cold/hot at all. the car runs mint when i get it going, so I truly am lost here. Im going to go out now and swap the starter relay, any other ideas though? thanks again for imput so far.
edit- swapping relay did nothing. If I just push in the clutch and crank, with no gas, not quick flips on the ingnition or anything, she cranks and cranks and cranks, FINALLY when it fires, bogs just a bit, and I can smell fuel. Im really puzzeled on this one, no idea where to look next,,,
Old 10-22-2007, 05:06 PM
scooby68's Avatar
Hard starting
Im with you bud, unfortunately I'm in the middle of water pump reapair waiting for parts shipment so the car is down and not running. My thoughts were moving in fuel regulator issue, possibly clutch interlock, ignition key things......I don't know either, maybe we need to start a new thread on this one, but I'm too new at navigating here. Vince
scooby68 is offline
Old 10-23-2007, 07:17 AM
hermtm2's Avatar
I have the same problem in ny 96' I30. I spent almost $1k but it is still pain in the a****. I found a guy who sloved the problem so sent PM to him. However I'm still waiting his answer. As soon as I get the answer, I will let you know.
hermtm2 is offline
Old 10-23-2007, 07:59 AM
scooby68's Avatar
Hard Start Issue
Thanks, that would be tremendously helpful on this long time tough issue, mine has been doing it for at least 4 years and just haven't found the time to chase it down since I had discovered the "double start" solution go around. Downside is I had to replace the starter, not a big deal but eventually double starts catch up to it.
BTW, I have 97 SE, I understand that its a California car, even though I bought it here in NJ.
scooby68 is offline
Old 10-23-2007, 11:36 AM
clint240sx's Avatar
on cold starts, my 99 max sometimes takes a few seconds to crank up. It turns over with no prob, not losing any battery power either. what could be that problem? never had the problem before now
btw, i only have 113,xxx miles
clint240sx is offline
Old 10-23-2007, 12:34 PM
scooby68's Avatar
Hard start Research
Thats still good bro, if you find out what he put in then it will narrow down the options. thanks!
scooby68 is offline
Old 10-23-2007, 12:42 PM
scooby68's Avatar
Hi, I'm curious if you tried this with any positive results?
scooby68 is offline
Old 10-23-2007, 03:28 PM
I assume you are talking about trying the FIC? all tested good as I stated above, so grrr . still playin with this one, hopefully someone can give me somewhere else to check, relays I've pretty much ruled out.
One thing illbe doing is upgrading my intake - firewall and tranny to chassis grounds, and just quickly double checking connections on the starter and my already upgraded grounds.
will keep updated.
Old 10-24-2007, 06:20 AM
scooby68's Avatar
Hard start update
If your is the same as mine it can't be starter, as the rpm's on the starter's cranking is never deficient. I've had three different starters in this car in its 200k miles, with different tooth counts, I think one was a seven and the other a nine or eleven or something and it hasn't made a difference in this issue for the record. Have you checked relays or had someone do that? It's been a consideration on my end as well as fuel pressure regulator possibility?
will keep updated.
scooby68 is offline
Old 10-24-2007, 03:53 PM
i just changed relays with others in the box of the same kind. Im still thinking this is a sensor issue, however I'd assume it to be a CKP, etc, otherwise a possible ignition switch, but is that possible? Would it not just stop working or could it have a poor connection? Im still thinking this is electrical, I start school on monday but if i can fit time in I'm going to test the fuel pressure, and check over my grounds at the very least.
Anyone have any ideas ?????
Old 10-24-2007, 04:00 PM
scooby68's Avatar
Well, when I did have the ignition switch go couple years back, I took apart the old one to try to fix it first (PITA) and the rotary set of contacts for each key position had the very last one(Starter contact) almost worn flat. So that explains that if I turned the key REALLY firm that it would start, if your starting with light to normal key pressure then its most likely something else at this point.
scooby68 is offline
Old 10-26-2007, 03:26 PM
95jr6708's Avatar
just keeping my promise...took it to stealership because this had gone on long enough (about a year and half). they replaced the electrical part of the ignition switch...starts just fine now.
about a year ago i replaced the mechanical part and that solved that problem...
just my .02
one more thing...this happened gradually...first only during cold weather, then if it was below 80 degrees outside then 90 etc...finally it just started to crank and crank if i left it for any amount of time...hope this helps.
95jr6708 is offline
Old 10-26-2007, 05:51 PM
just my .02
I'm really starting to think this is the ignition switch, playing with the key a bit seems to have the most effect to get it started. When you say they replaced the 'electrical' part, do you by chance know what that was/an invoice or reciept with a part number or something of the like? That would really help as I'd be doing it myself. Thanks for the imput it kind of confirms my recent suspicions!
Old 10-26-2007, 09:23 PM
95jr6708's Avatar
ya i am actually at work right now, but i think there is part number i can get you tommorow.
in addition, jiggling the key would tell me, that it would be the upper part which is the mechanical mechanism (not the electrical) behind steering wheel cowling the part i replaced a year or two back that is shaped like a cylinder with the ignition wires hanging off. it costs about 50 bucks from an autoparts store and is pretty much a plug and play fix.
i'll get back to you on both parts once i find them.
95jr6708 is offline
Old 10-26-2007, 09:42 PM
scooby68's Avatar
Ign. Switch part #
Easy install, but be careful cause your going to be close to air bags, also disconnect battery. www.coustesynissan.com for diagram explode and for part identification #'s , maybe www.rockauto.com also, I haven't dealt with them yet
For my 97 5 spd. SE it was Part#
http://www.courtesyparts.com/betasit...-p-132324.html
...or look for part description #48750 under section # 998 Misc. and Keys
JUST MAKE SURE THIS IS FOR YOUR SPECIFIC CAR year and model, CALL THEM AND SPEAK WITH SALES GUY. IT WAS LIKE $30 + The SHIP
I just remembered how I'd park on inclines with no obstructions all the time so I could get a rolling start in second gear when I came back to the car!.....those were the daze!.......good luck with it!
scooby68 is offline
Old 10-26-2007, 11:45 PM
Qbridg3's Avatar
I have the same problem. Mine cranks a few times then it stops cranking and cranks again and then finally starts. Does it every time.
I'll have to check the FIC and change the coolant sensor and I'll also regrease the starter. If it is the idle control valve I am not changing that any time soon. It's $250.
Qbridg3 is offline
Old 10-27-2007, 07:47 AM
95jr6708's Avatar
The first link is for the part i think it is for your problem.
http://www.autozone.com/N,314431/ini...cleSelect4.htm
and someonelese 2 above me was so kind as to leave more links for you...
good luck!
keep me posted on your progress
95jr6708 is offline
Old 10-27-2007, 07:31 PM
Qbridg3's Avatar
My problem was a starter problem. Looked for the brushes and I didn't find them. Had to buy the hole starter.
Qbridg3 is offline
Old 10-27-2007, 10:17 PM
scooby68's Avatar
Anacronym Hell on this Site!
Ok, I give up whats FIC, Fuel injector something?
scooby68 is offline
Old 10-28-2007, 08:33 AM
lexoid's Avatar
http://www.courtesyparts.com/betasit...-p-130621.html $35. At nissanpartsonline.net you get the same price with shipping included, but it could take a little bit longer to ship.
It stands for "Fast Idle Cam". It has a thermo element which opens the "throttle" a little bit to increase RPM when the engine is cold.
lexoid is offline
Old 10-29-2007, 04:32 PM
ok .. update. thanks for the part numbers and such, Ill give the ignition switch a shot. I was driving yesterday and the car just died. No spit and sputter, i didnt even hear it die. I'll will start back up again but is still hard to start. It did seem to happen when i put it in neutral or when I pushed in the clutch(lowering rpm to idle ) then it died. Im in school now out of town so I need my car I hope it doesnt crap out on me completely. Ill be cleaning out the TB tomorrow and Ill have to order the Ignition switch. and ill be cleaning the IACV this weekend as I have no tools here. thanks again for the part numbers.
Quick Reply: looong cranks, losing fuel pressure??
