Finally! Cammed DEK is alive and makin' sweet music to my ears
#41
3.5 in the works
Originally Posted by vipervadim
the 3.5L cams are more aggressive than PF, so you should be seeing an EVEN fatter Midrange and SWEETer top-end, but because there's more lift/duration.. the low-end HP/TQ is lower (good for launching) and idle is a little lopy-er (but definitely not as lopy as JWT cams.....) if you drive the car at 2000+ rpms you shouldn't notice anything out of the ordinary
Ok I mentioned an alternative to drilling the cams/getting adapters. If you have machining access here's what can be done. I think the picture is mostly self-explanatory. You still need to make a spacer obviously, there's no getting around that, but only one dowel is used, and it's not fixed into the thin spacer/adapter, but into the cam itself. You remove the stock dowel from the 3.5 cam and replace it with a single longer dowel that can be bought at most specialized fastener places (like Spaue-Naur for example) for pennies (it's just standard hardened 6mm dowel).
#42
Interesting. How does your intake cam timing (more specifically intake centerline) compare to the 3.0 cam timing? I remember reading from the VQ35 swap pioneers that the dowel wasn't exactly 180* off. Your thoughts?
#43
3.5 in the works
Got a link? How did they come to the conclusion it wasn't 180?
#44
3.5 in the works
Originally Posted by TDotMax
Dandy, what overlap did you get the cams at? I'm wondering if mine are too extreme. Intake closing at 56* (with adaptors) and exhaust opening at 49* with spacers.
#45
not stock 3.5 cams??
i see.. that's cool, i just hope your heads can flow.
It's definitely not exactly 180 degrees on the intake cams.
I have both tilley's and stephenmax's cam adapters, and they are both off-center
i even checked the cam adapters installed on 3.5L cams compared to stock 3.0L intake cam.. they both line up by the lobes.
tilley's was closer than stephenmax's tho..
#46
Originally Posted by spdfreak
Your buddy has one in his garage, like his house garage?
I have full access to a machine shop, but if I recall correctly they dont have any cnc machines, but I could be mistaken.
Can you pls find out the company of the machine along.with the model, i'm curious.
his house garage. it's not a big $150,000 machine like we have at work, but it does good 3D machining.
#47
With most aftermarket cams you don't want them timed at the exact same spec as stock. That is why adjustable cam pulleys exist. You can have the sprocket machined to have any amount of cam timing. 180* is probably a decent starting point.
I have had this same idea for some time now. I am glad you were able to do it and that it came out so well.
You could have just not drilled the inner sprocket and just rotated it and made a mark for alignment with the chain. The outer sprocket needs to be machined though to allow for the cam sensor readings.
#48
Originally Posted by DandyMax
I never said I've got stock cams...
Do you have the dimentions to the spacer/washer part.
Thickness / inside diameter / outside diameter.
I think I can have some one replicate these for real cheap, not that I want to take buisness away from anyone.
#49
3.5 in the works
But in general, with a head that's somewhat restricted, a more aggressive cam is needed (to a point). With great flowing heads, you don't need as much lift/duration since you're moving more air in the same amount of time.
#50
I see what you're saying now Dan. It's not that the holes aren't 180* apart, they just didn't want to relocate the dowel pin 180* because it would result in cam timing that they didn't want, I guess. Amirite?
#51
3.5 in the works
Or in other words... "yezzirr" - lol.
#53
Did you get his standard 3.5 adapters or request specific intake timing? BTW your exhaust opening with stock 3.5 cams is at 52* BBDC and closing is at 8* ATDC. For overlap you are interested in the exhaust closing and the intake opening.
I know I'm fine witht his. Re-read some inquiries I had before and sicussions with fellow orger's. Now its pretty much the time game for these
Can't wait to hear the motor.
#55
3.5 in the works
Dandymax, after me looking over the pictures for a while I think I noticed what I missed the first 100 times. You cut the sprockets opposite the original cut.
Am I correct?
Am I correct?
Got, I got specific timing on the intake at 56*
Have you checked the dowel position on your adapter(s)? It should 4* off the 180 line on the adapter.
#56
Sorry I might have asked you that before, but I have a lousy memory most of the time. Hmm so that will put your centerline at 117, which means your overlap is 10*
#58
spdfreak..
this is an ADVANCED PERFORMANCE section..
what's with all the n00b questions..
ie. if you don't know which motor you have....
I knew I was right about which motor I have in my 2000.
The car was built in 03/2000 and on the plate in the firewall it says VQ30 (DE).
Which part am I missing that the 00-01 cars are dek?
Explain.
#59
Explain.
Explain.
#60
Originally Posted by Dandy Max
You could get away with just rotating the secondary sprocket if you were setting the dowels exactly at 180. However if you're changing that angle then I'd say no, because you'll be limited by significantly discrete steps given the angle between each tooth, unless you rotate the intake and exhaust secondaries as an assembly, but if you do that then the exhaust timing changes also. (And keep in mind whatever degree change you make on the sprocket is actually double on the crank, so it doesn't take a large change to make a large change.. haha).
It is also true that if you try to offset the angles any more than 180* then the exhaust timing will be changed, which if you really know what you are doing could be a good thing. You could also machine the inner sprocket independently of the outer to change the exhaust timing, but that is getting pretty complicated for most. It is fairly common on KA24DEs to do this sort of thing. They don't even use a machine shop in the write up.
http://jimwolftechnology.com/wolfpdf...STRUCTIONS.PDF
http://www.nicoclub.com/articles.php?id=199832
So what are the exact specs if you machine the sprocket 180* from the stock dowel hole? If you don't mind lending us your hard work
#61
3.5 in the works
With stock 3.5 cams, if you machine the sprocket at 180* the centerlines INT/EXH will be 125/112.
#62
3.5 in the works
I actually don't have an electric cutout, I sold the one I had to someone else and now I just have a manual one that's easy to undo with 3 wing nuts. It's mounted right on the end of the y-pipe.
#63
Hey dan glad to hear you got the beast running.I final opened mine up and you were right about the buckets over the springs are smaller than on the regular DE motors so looks like I'll have to do some grinding work also to get these cams to fit.Thanks for the heads up on that. I have just a quick question off topic about your cut out.I think I read that you have bypassed your maf unit(Is this correct?)that maybe you are running a speed density setup and if you are does this mean that you are running a separate tuning program for when you run your cut out on your exhaust.Running cutouts with the maf and it will compensate for the raised engine VE but with the set up you have wouldn't you have to set a different program to keep from running lean and getting knock at wot?I would love to see a dyno with cutouts opened(and properly tuned) and then closed(and properly tuned) just to see how much power is lost with the extra backpressure.Here I go again whoring up someones thread with something off topic lol.Sorry I just figured with the set up you have you would be the best to ask this question.
#64
3.5 in the works
And OT, I hardly EVER race on the street, and in general I don't condone it, but last night at 2 am with no one around on the freeway coming home this modded 5.5th gen with blingy wheels wanted to go. Would have been a fun one, one of us would have been in for a big surprise, but all I could do was wave as he took off. Stupid clutch break in.. lol.
#66
3.5 in the works
Hey dan glad to hear you got the beast running.I final opened mine up and you were right about the buckets over the springs are smaller than on the regular DE motors so looks like I'll have to do some grinding work also to get these cams to fit.Thanks for the heads up on that... etc etc.
Hah! Yeah I know, but I figured I'd try to do the break in properly, plus I haven't tuned WOT yet so I don't want to punch it at high rpm and be really lean (which I'm almost certain to be...)
#67
I'm installing the S1 knockoffs for the 3.5 using stephenmaxs adapters with his standard timing advance.Opps I think I see what your meaning I might have too much overlap because the spacers were made for the stock 3.5 cams.Oh well if it doesn't work it's just another reason for me to go ahead and install a 3.5 As of now I'm running a neo to control my afr but I plan on running a e-ultimate before long thats why I was asking about you using the map sensor instead of the maf to control your afr.As far as idling I'll probable just adjust the idle screw for now.Funny how my car idled like crap after installing the dek but after installing a bigger maf it idles perfect after adjusting the inputs on my afc for the bigger maf.Go figure?!
#68
3.5 in the works
I'm installing the S1 knockoffs.As of now I'm running a neo to control my afr but I plan on running a e-ultimate before long thats why I was asking about you using the map sensor instead of the maf to control your afr.As far as idling I'll probable just adjust the idle screw for now.Funny how my car idled like crap after installing the dek but after installing a bigger maf it idles perfect after adjusting the inputs on my afc for the bigger maf.Go figure?!
#69
no I haven't finalized anything as far as the cam timing yet.I've been search the web for a good dyno simulation program so I can run sims with differant timing numbers but the only thing I've found is the desktop dyno from summit racing.
#70
3.5 in the works
Video Part 1
Ok here's a teaser video. It's not with an open cutout sadly, but I'll get one made with an open cutout in the next few days. The idle's not exactly where I want it yet either but it's gettin' there..
It never sounds the same online as in person so please check your EQ settings, make sure bass/treble are relatively balanced and up at least to the middle on the sliders, a bit more bass than treble is good to counteract the ambient/background noise also since it's just off a camcorder mic. Maybe when I do the cutout one I'll set up an actual mic...
Cammed DEK Part 1 (cutout closed)
Stay tuned for part 2...
#72
3.5 in the works
Just wait till Part 2 with the cutout actually open...
Although I gotta say if you listen to that vid on a computer without a good sound setup (ie crappy 2 little speakers or whatever) it sounds bad. Much better in person, too much extraneous noise and reverberation in the garage there with the basic mic on the camcorder. I'll see what I can do for the next one.
#73
SOUNDS SEXY!
Sounds great! And you can really hear those cams with a little lope.
(Am I correct or is it my crappy laptop speakers?)
PS. I'm going for a DEK swap, and if I got the extra money I'll get cams like yours.
Oh, and your only partially tuned? Whats left to be done? And do you do your own tunning?
#74
#76
3.5 in the works
SOUNDS SEXY!
#77
can't wait to hear it...
now I need to get cams and have those heads I have sitting around port and polished!
which cutout do you have dandy? I have the qtp one on my 2000 max...where are is it in your exhaust stream? mine is welded in a straight pipe, so it's right after the cattman headers...sounds beautiful on the de-k! can't imagine what top end would sound like with cams and tune...
#78
Yes that's lope. I have yet to tune cold start/warmup idle, and WOT mainly (clutch break in). Driveability (low/partial throttle/cruise has mostly been taken care of now. Yes I do all my own tuning, always have. I'm still having an issue with my IACV, but will be swapping in a spare so hopefully that'll take care of it.
#79
I'm in the process of getting another 3.5 built. I'm supercharged; would it be beneficial to us FI guys to have that angle adjusted, to essentially retard the timing? Or is that just crazytalk?
#80
Sounds to me like you're referring to ignition timing and he's referring to cam timing. Two totally different things.
