Problem Starting!
Problem Starting!
My 95 Max has problems starting. Checked timing chain. Fine. Changed starter ,plugs, all the sensors, clutch,everything. Once it does start everything is fine.My mechanic is stumped and so am I! Please help!
The Car will start after after about 4 tries. When I turn the key and hit the clutch' you can here the fuel pump and the starter, and you can feel the car try to turn. Once its on its fine. It triggered the Cam Shaft sensor and it was replaced. My mechanic is stumped. So are the other three.
sctludwig
09-01-2022 01:32 PM
trungg86
09-04-2015 04:58 AM
