Problems with clutch slave or master cyl
So I noticed that my clutch was feeling a little soft, and the engagement point was getting lower, so I decided that I would bleed it. I opened the bleeder valve and the pedal went to the floor like its supposed to, but then it wouldn't stiffen up. I tried and tried, then took the slave cylinder out and made sure there was nothing blocking the holes in the banjo bolt. After reinstalling the slave, I then tried to get the pedal to stiffen no luck. At this point I'm lost. The master cylinder is supplying the fluid(Not sure if there's enough pressure), and the slave it receiving the fluid, but the slaves piston has very little throw to it, its even soft enough that you can push the piston back.
So I really can't tell if the master cylinder is supplying enough pressure or if I have a bad slave. Neither are leaking, and I know its not the release bearing causing the problem because the slaves piston barely touches it.
Any thoughts??
Any thoughts??
If you were working by yourself and using the pedal to bleed the fluid, you did it wrong. Bleed it again.
You'll have to lift and push the pedal by hand. In fact, you may need a vacuum pump or powerbleeder this time since you might have enough air in the system to keep the pedal from working.
hez8813
03-12-2020 12:06 AM
t6378tp
09-29-2018 04:27 PM
pears
09-18-2015 05:25 AM
