Lexus Metal Tensioner Pulley Part Number & Pic
For you SC guys that were asking. This makes for a great reduction in belt shredding issues and an increased margin of error for belt alignment...
You do actually need to stack up washers inside the pulley in order to bring the nut to an accessible position. No special bolt needed. You only need the pulley and a few washers. In some cases you may have to stack a washer or two behind the pulley as well so it clears everything. Just use your best judgement on it, and you'll be fine. Post up any questions, those who have it can answer and clear up a few things about using this pulley.
And no problems wit adding it to the stickies...good stuff.
Licensed to Spell
This is for that guy who is searching in 4 years from now and only sees a red X in TJ's post #1:
Toyota "Idler Sub Assy" 13503-5011
Try and keep up Taterboy.
http://forums.maxima.org/showpost.ph...7&postcount=15
Licensed to Spell
*Cough*already done a while ago*cough*
cause you are the few who monitors the belt. i never had an issue either but this is for the less fortunate,lol. with this pulley there is a lot of slack that is not tolerable wih the ribbed version.
yeh it's the stillen pulley with sidewalls, i believe is the correct wording. this is going on my 8th yr owning, installing and working with the stillen sc. many of my friends have the dreaded belt issue, but i have been very lucky, because as i said i monitor the belt almost every other time i drive it. by that i mean i check the belt for flexing and buckling when gas is applied. in the cold it is very important not to go into boost ,especially in the northern section where it can get very cold. also boosting puts a lot of stress on the tensioner and over a time period can become loose causing the belt to ride a rib and break. every now and then i retighten the tensioner to avoid that problem.
Tried Metal Idler Pulley.. but too big
I gave this part number to the toyota dealership and they had to do a cross reference. They sold me a puley that looks like the one in the picture, but when I tried to put it on, it was so big that it was rubbing up against the hose that runs to the radiator. I have a V2 bracket (probably guessed that, if I had a v1 I probably wouldn't be having alignment problems.) WHAT IS THE DIAMETER OF THE PULLY IN THE PICTURE?
So I can double check that they sold me the corrct pulley. Thanks Guys!
Lexus Pulley too big:
http://forums.nycmaximas.org/showthread.php?t=32892
trying to find this pulley what store did this pulley come from? i tryed autozone and advance autoparts and that part number dont come up. but when i give the infiniti j30 timing idler pulley more than one pulley comes up any help would be good.
they discontinued the old ones, the new ones are slighlty bigger and causing some rubbing issues. if you have the old one just go to any part store or dealer and have them match up the size, i have a friend who did that. i dont knonw if this guy still makes them but he use to make them for us. lee 1 877 928 8675
the factory pulley number is 13077-F6511 can be had on e-bay for like 20 bucks. Good luck with it....
mrc00l88
01-25-2024 01:14 PM
BassAddictJ
08-04-2015 11:38 AM
