VQ 30 and 35 4th and 5th gen Stainless Steel Clutch lines !!
Old 07-12-2007, 09:34 AM
AuToMaX_95's Avatar
WE NOW OFFERS 1 PIECE CLUTCH LINE FROM MASTER TO SLAV FOR $40 SHIPPED!!! IN STOCK!!
Hi guys, since derrick is really busy with his thing, I am taking over for now.
GD: Stainless Steel clutch lines for your VQ! They are made by the same company that makes the D.O.T. approved SS brake lines for our cars, Technafit!
It will come with everything pictured, one SS clutch line, 1 banjo bolt, and 2 replacement brand new copper washers!
Great, simple upgrade for your max. Increase the feel and responsiveness of your clutch with these easy to install SS clutch lines. If you are planning on doing a 5sp swap, or plan on changing out the fluid in your clutch these lines will be a cinch for you to install while you're down there.
On to the pricing:
For U.S. residents just $25 including shipping anywhere in the U.S. !!
For Canada $27 including shipping!
For other international orders please PM or email me. Thanks!
Payment info:
pay with CC over the phone please contact us at 19093487277
You can send payment via PayPal to paypal@racetechperformance.com
For Money Order information just PM or email me!
Be sure to include what car and what part you are paying for in the notes of your paypal or along with your money order!
Shipping:
USPS mail 2-3 business days
we not carries 1 piece clutch lines from master to salve for $30!!
AuToMaX_95 is offline
Old 07-13-2007, 12:46 AM
Ride2kMax's Avatar
Do you have intructions on how to put it on?
Ride2kMax is offline
Old 07-13-2007, 09:54 AM
AuToMaX_95's Avatar
Sorry, i don't have any instructions, search on the forum there is plenty.
takes less than 20 mints to do.
Regards
jason
Old 07-14-2007, 05:05 PM
95BLKMAX's Avatar
Hey, Jason just to verify...
Is this the clutch line that runs from the hardline to the slave cylinder?
or
Is this the clutch line that runs from the master cylinder to the slave cylinder (eliminates the c00k00 turns and loops of the stock hardline)?
Thank you sir!
95BLKMAX is offline
Old 07-14-2007, 10:28 PM
sweetdaddygotu's Avatar
just sent a payment!
sweetdaddygotu is offline
Old 07-15-2007, 10:42 AM
SpeedCrazie's Avatar
Jason-
This is the full line correct, NOT just the lower line?
Thanks.
JP
SpeedCrazie is offline
Old 07-15-2007, 12:56 PM
AuToMaX_95's Avatar
this is the short line where you shifter is, it doesn't replace the master cyl hardlines.
Old 07-16-2007, 10:00 AM
Snypa's Avatar
is it still available or has it been sold?(stainless steel clutch lines.)
Snypa is offline
Old 07-16-2007, 10:28 AM
AuToMaX_95's Avatar
this is a group deal, we have more than 1 available
Old 07-16-2007, 12:31 PM
IS there anyway you can get ahold of the FULL line?
Old 07-16-2007, 12:49 PM
OOmaxSE's Avatar
For the 5th gen, there are two lower rubber hoses (a divider between the two), one connects to the slave and the other connects to the hardlines... Which does this replace?
OOmaxSE is offline
Old 07-16-2007, 01:39 PM
AuToMaX_95's Avatar
I can get the full line, but price will be different.
OOMAXSE
e-mail replied
jason
Old 07-16-2007, 02:19 PM
How much for the full line?
Old 07-16-2007, 03:16 PM
AuToMaX_95's Avatar
VQUICK installation describtion:
Broaner and I installed the SS line on my car last night. It took us forever because of one rusty-a$$ connection on the stock line: where the little hard line meets the short rubber line. It was a true b!tch. Finally I thought to use a big old pipe wrench on one side and we cracked it. (Second time that the pipe wrench has come to the rescue on my Maxima modding!)
We did end up bending the hard line slightly to give us more room to get at the rusty connection, but it was easy to bend back and put it back in the plastic clips to secure it. The Technafit line went in easily and was plenty long. Just make sure you tighten the bolt on the slave cylinder (banjo end) of the line as tight as you can. I thought I tightened it enough at first but when we went to bleed, air and fluid was coming out there. Also, we reused the stock bolt here, not the Technafit bolt. The stock bolt is longer and has a smaller head (12mm stock versus 11/16" for the Technafit bolt), and I do not think it's even possible to use the supplied bolt because the 12mm stock bolt head barely fits in there as is.
As has been noted, the SS line replaces both the long and short rubber lines (between the little hard line and the slave cylinder on the right side of the engine) as well as the metal box thing between the two stock rubber lines. This little box might be some kind of check valve, although I shone I light in there after we got it out and couldn't see anything. Anyway, I assume it's not necessary, and my clutch is working fine without it. Does anyone know more about this box thing?
So we ended up cleaning things up in there quite a bit: removed the box thing and the bracket it was on, and removed another unnecessary bracket which was holding the connection between the hard line and the short rubber line. Probably removed a pound of weight from my engine bay! Not to mention the shiny steel line looks great.
I've only driven a few miles but the clutch does feel better! Definitely more control of clutch engagement and the modulation seems more evenly spread throughout the pedal travel.
Thanks again, Derrick! Best GD customer service ever!
Old 07-16-2007, 03:18 PM
AuToMaX_95's Avatar
they dont make one, just got off the phone with the owner.
sorry
thanks
jason
Old 07-16-2007, 07:42 PM
Snypa's Avatar
Hey Guys, the clutch hose that AutoMax is selling, can it possibly replace a clutch hose in a 4th generation as mine has a small pinhole leak.The hose im looing for is the hose right next to the bleeder screw.Please,i would appreciate some help.
Snypa is offline
Old 07-17-2007, 11:11 AM
Red Lion's Avatar
I'm down. Can I pay right now?
Red Lion is offline
Old 07-17-2007, 01:57 PM
AuToMaX_95's Avatar
YES you may
Old 07-18-2007, 07:00 PM
wirelessdude04's Avatar
me too $25 shipped right..... And you have them for my 97 maxima..... Im gonna send payment now... But its a echeck so it takes a few days to clear is that ok?
wirelessdude04 is offline
Old 07-18-2007, 10:47 PM
Red Lion's Avatar
Originally Posted by AuToMaX_95
YES you may
lol I'll get back to you tomorrow night, hopefully my paypal transfer will have funded!
Red Lion is offline
Old 07-19-2007, 09:40 AM
AuToMaX_95's Avatar
sure =)
yes we have the clutch lines for 95-2006 maximas e-check is fine
Old 07-20-2007, 09:40 AM
Ghase's Avatar
I'm going to order one tonight... My friend needs one.
Ghase is offline
Old 07-22-2007, 05:24 PM
OOmaxSE's Avatar
Payment sent! I'll PM you as well.
OOmaxSE is offline
Old 07-23-2007, 08:58 AM
MetalBlueMaxx's Avatar
Hi, still more available? I will paypal you as soon as you respond to this, thank you.
MetalBlueMaxx is offline
Old 07-23-2007, 10:09 AM
AuToMaX_95's Avatar
Yes, we have plenty to go around
Regards
jason
Old 08-04-2007, 01:15 PM
1chewabacha1's Avatar
Hey automax, is there any way you or any orger here, could show a picture of how the SS line is connected to the OEM Slave cylinder?
1chewabacha1 is offline
Old 08-04-2007, 01:22 PM
Payment sent.... Hurry... My line is starting to leak pretty bad... Filling the reservoir once every 2-3 days now....
Installed.... Beautiful Product. Works like a dream. Great replacement over stock.
Old 08-05-2007, 10:55 PM
AuToMaX_95's Avatar
lol will ship tomorrow
thanks
jason
Old 08-07-2007, 08:17 PM
Sweetness.
Old 08-08-2007, 10:14 PM
eK9aT10pSi's Avatar
do you have one for a 04 max?
eK9aT10pSi is offline
Old 08-14-2007, 01:43 PM
AuToMaX_95's Avatar
Yes we have it for 04 maximas
Regards
jason
Old 08-15-2007, 10:21 AM
97maxdaddy's Avatar
im about to do my 5spd swap on the 25th of this month, how fast is your shipping if I paypal tomorrow (Thursday 8-16-07. Will I get it in time?
97maxdaddy is offline
Old 08-15-2007, 02:31 PM
AuToMaX_95's Avatar
in stock, pay today before 12:00 pst order will be ship same day USPS prioity mail 2-3 business days so yes it will get there before the 25th
Old 08-18-2007, 10:58 AM
Ghase's Avatar
Hey Jason I just ordered the lines for my friend with his 98' maxima.
Ghase is offline
Old 08-20-2007, 10:05 AM
AuToMaX_95's Avatar
payment received, will ship out today
thanks
jason
Old 08-29-2007, 09:26 PM
themills's Avatar
payment sent
themills is offline
Old 08-30-2007, 10:31 AM
AuToMaX_95's Avatar
received! shipping it out today
thanks
jason
Old 09-06-2007, 07:34 AM
97maxdaddy's Avatar
I've just sent payment (from paypal email mac187htown@yahoo.com)
lemme know when you ship.. Thanks
-Mac
Old 09-06-2007, 10:14 AM
AuToMaX_95's Avatar
Received!
thanks
jason
Old 09-14-2007, 11:53 AM
AuToMaX_95's Avatar
sorry guys I accidentally empty my mail box so all the new P.ms are gone, if you have anything please p.m me again
sorry for any inconvinces.
Regards
jason
Quick Reply: VQ 30 and 35 4th and 5th gen Stainless Steel Clutch lines !!
