Bi-xenon wiring ???
Old 06-12-2007, 11:20 PM
Whatchyou say?
JtzMax's Avatar
Bi-xenon wiring ???
MOD -
What about a Sticky on HID (both Xenon and Bi-Xenon)? Maybe a "how to" wire and parts needed. Just a thought! Thanks
Ok, I need official help! (that's what she said too! hehehe) I have loooookkkkeeedddd for a "how to" on wiring bi-xenon lights, but I am having a hell of a time.
I found one diagram on HID Planet here ::: http://www.i-club.com/forums/showthread.php?t=36831 ... but I am confused. Not only cause this is for a Subaru, but I will only have the A6 projectors in the HL housing. The diagram shows having the HID and a Halogen, but I won't have the Halogen, hence the reason for Bi-Xenon ... right?
I understand that you have to wire in a diode (and a relay? were can I get the relay I will need?) for the high switch to activate the arm on the projector. I guess I am confused on just how to do this, and then what about "flash to pass"? Can someone please clue me in or point me to a more conclusive thread / site? PLEASE! I want my high beams and my low beams too.
Cheers!
Jim
JtzMax is offline
Old 06-13-2007, 05:52 PM
Whatchyou say?
JtzMax's Avatar
Bummpidy Bump Bump! Anyone?
JtzMax is offline
Old 06-13-2007, 06:09 PM
.org window licker
96nismomaxi's Avatar
i just purchased a plug and play kit from e bay and i was done from there
i had to mount a ground and tuck wires so they didnt look bad!!!
sorry i cant help
i do know that you wont have to worry about different types of bulbs and so on as long as the wireing scematics say that it is for both hi and low beam you should b fine
sorry
-Jared
96nismomaxi is offline
Old 06-13-2007, 06:16 PM
MorpheusZero's Avatar
Our cars use a 9004 socket and are positive-switched.
The strange thing between the high beam and low beam positive wires is called a diode, it only lets electricity through one way so it's important that you install it in the pictured orientation.
MorpheusZero is offline
Old 06-13-2007, 08:04 PM
Whatchyou say?
JtzMax's Avatar
Morpheus Zero ~~~~ Thanks mate! This helps a ton! I am not sure what relay to get and were to get it. I don't think it'll come with my D2S system. Maybe, but I doubt it. Also, is there a certain size of Diode that I need? This clears things up SOOOOO much.
96Nismo .... I have looked at the kits on Ebay, but I would rather wire it myself to be honest. Not that I don't trust "their" wiring, but I know I can trust mine. Also, there is a sense of accomplishment by doin it on my own ... ok well with the help of the Org! lol
Thanks!
JtzMax is offline
Old 06-13-2007, 08:07 PM
Whatchyou say?
JtzMax's Avatar
One more thing .... were does Relay point 86 go to ... the diode? Thanks!
JtzMax is offline
Old 06-14-2007, 05:50 AM
Whatchyou say?
JtzMax's Avatar
Where can I get a Relay ... and also, a Diode too? I'm not sure if there is a certain size I need or what.
JtzMax is offline
Old 06-14-2007, 06:42 AM
aznstormin's Avatar
Relay point 86 are the positive wires for the high and low beams. Just somewhere inbetween the relay 86 and the 9004 socket, there can be a diode connecting the both positive wires.
www.parts-express.com for most of your parts. They have a great price and shipping is reasonable.
30A Relay: http://www.partsexpress.com/pe/pshow...TOKEN=36743558
Diode (I don't think it matters what kind you got...I bought the cheapest one and it works): http://www.partsexpress.com/pe/showd...tnumber=1N4007
aznstormin is offline
Old 06-14-2007, 06:48 AM
aznstormin's Avatar
Here's a thread I started when I was thinking about retrofitting...read through it; it may answer a few questions.
http://forums.maxima.org/showthread.php?t=516679
Old 06-14-2007, 07:39 AM
Whatchyou say?
JtzMax's Avatar
Thank you Aznstormin! Just ordered the relays and diode, mabe everything will arrive at the same time and I can get it all done.
Have a great day! Cheers
Jim
JtzMax is offline
Old 06-19-2007, 06:11 AM
heresmymind
Here I clarified it all up for you. here is a diagram I just drew up. yay for being awake at 9:20 Yawn*
Copyrighted*
Old 06-19-2007, 06:50 AM
Whatchyou say?
JtzMax's Avatar
Thank you SOOO much! That is Sticky worthy in my book mate! Can we get a mod to second that? I should have my ballasts tomorrow, so - it's go time. I am nervous, but at the same time, I know I'm handy enough I can do it. I just want it to look good too. I'll try to post pix when I'm done, not sure when that'll be ... but none the less.
Thanks all for the help and the time.
edit: What about hooking up the low beams to the parking lights? To save the ballast when I "ftp". Anyone ... ??? Many thanks!
JtzMax is offline
Old 06-19-2007, 09:59 AM
matty's Avatar
Do that on both sides ??
Or thats it ?? One relay ?
-matt
matty is offline
Old 06-19-2007, 10:27 AM
aznstormin's Avatar
Nice job on the diagram!
Old 06-19-2007, 10:47 AM
heresmymind
if you want to hook them up to your corner lights/running lights. connect the green wire to a positive wire on your corner lights. whenever you put your running lights on they will turn the low beams on. you only need 1 relay. some people like to put small resisters in front of the solenoid positive wire because they get hot sometimes. Not bad for a diagram i drew when i was hungover:-p
Old 06-19-2007, 11:36 AM
f550maranello2's Avatar
ok im gonna give this out one more time and thats it... this was supposed to be stickied but nobody seems to care..
f550maranello2 is offline
Old 06-19-2007, 01:17 PM
heresmymind
that 2nd relay is overkill, you only need a 2nd relay if your using another bulb set up for a cleaner connection. The solenoid only needs minimal wattage and like .nothing for volts to operate. so the stock high beam wires are fine to power solenoid. and when u use the high beams. the high beam wire sends the tiny amount of electric to the low beam wire which draws power from the battery anyways. no need for a 2ndary relay IMO
that is directly from hidplanet *Ocelaris*
Old 06-19-2007, 01:29 PM
i put 2 relays in so that it would equal the initial load of the 2 ballasts... i checked the initial current to run 1 ballast at start up it was about 10 amps... so i put in another relay for the other ballast so that im not burning up any relays...
do it once and do it right is my moto....
Old 06-19-2007, 01:46 PM
heresmymind
they ballast will still get the same draw. and the same amps since they still draw from the battery direct. the diode just flips the switch to allow them to draw from the battery.... so ur way isnt RIGHT, they both work. my way just uses less wires:-p
Old 06-19-2007, 01:57 PM
no they wont... each relay will split the draw of 20 amps total from both ballasts during initial start up... aka it lightens the load for each relay...
ur wrong im right... dont argue
its like having 2 sources drawing 15 amps each... why would i use 1 30 amp relay when i can use 2 30 amp ones....
Old 06-19-2007, 07:08 PM
Whatchyou say?
JtzMax's Avatar
I will use a realy for each ballast, overkill maybe, but I would rather have overkill than not enough by all means.
Thanks all ...
Jim
JtzMax is offline
Old 06-20-2007, 05:54 AM
Whatchyou say?
JtzMax's Avatar
What gauge of wire should I run for power to the ballasts ????
JtzMax is offline
Old 06-20-2007, 05:57 AM
aznstormin's Avatar
Wire - 14 gauge is about as large a gauge as I personally would use. 16 gauge is also fine for lengths < 6 feet.
From: http://www.hidplanet.com/forums/viewtopic.php?t=6612
Old 06-20-2007, 06:37 AM
Whatchyou say?
JtzMax's Avatar
Thanks! I was thinking 14g would work, but I didn't know if I needed 12g maybe. Guess now I know! lol
JtzMax is offline
Old 06-20-2007, 08:49 AM
matty's Avatar
So Two Relays or ONE ??
-matt
matty is offline
Old 06-20-2007, 10:17 AM
Whatchyou say?
JtzMax's Avatar
two matt ...
Jim
JtzMax is offline
Old 06-20-2007, 01:38 PM
maxiquin's Avatar
somebody make me some my spending limit-$$$$$500
maxiquin is offline
Old 06-20-2007, 01:42 PM
heresmymind
1 matt
branden. hehe
Old 08-07-2007, 12:39 PM
SYCEFIRO's Avatar
Question about FX35 Bi-Xenon Projectors
Most of the Bi-Xenon Projectors out there have only 2 wires coming out of the projector itself. Does anyone here know how the FX35 Bi-Xenon Projector works?
There is a Yellow wire connected to the projector body
and two Red wires coming out of the projector body
If anyone had experience making the FX35 Bi-xenon projectors work. please share on how it's done.
Thanks in advance for your help.
Regards,
SY
sycefiro@yahoo.com
SYCEFIRO is offline
Old 08-07-2007, 12:44 PM
Kevlo for President
Kevlo911's Avatar
Regards,
SY
sycefiro@yahoo.com
Have you checked the forums on www.hidplanet.com? They should have this info already posted.
Kevlo911 is offline
trsandrew
17
04-08-2016 06:45 PM
doctorpullit
03-29-2016 11:08 AM
trsandrew
10-25-2015 02:47 PM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Quick Reply: Bi-xenon wiring ???
