Heads-up: 19" traklites at tire rack
Old 06-10-2007, 04:33 PM
MorpheusZero's Avatar
19x7.5J +45. I know it's a bit narrow and the offset's kind of crappy but they're going for $230 apiece, for a forged 19". The 17x8J Traklite is 14.5lbs so I'd guess this would put the 19x7.5J at 18-19lbs or so.
Check 'em out here.
MorpheusZero is offline
Old 06-11-2007, 11:55 AM
+Cru OG
NisMoN00B's Avatar
Too narrow for me, but TY for the info.
I've been eyeing that Moda MD1 for sometime now though, it looks decent. And they're coming out with the SportsEdition KV5 (MM Evo5 Clone?) in 19s too for $200 ... .
NisMoN00B is offline
Old 06-11-2007, 03:55 PM
350 Detroit Muscle
Ammi's Avatar
For 19"s, you definitely want minimum of 8" in width.
Ammi is offline
Old 06-11-2007, 05:31 PM
I like my 17x8" Tracklites better.
NmexMAX is offline
Old 06-11-2007, 08:49 PM
I'd like those better too, but they're about 50% more.
Old 06-12-2007, 06:57 PM
I paid 280 a pop.
NmexMAX is offline
Old 06-12-2007, 07:49 PM
Originally Posted by MorpheusZero
I'd like those better too, but they're about $50 more.
Fixed. Teh happy naow?
Old 06-12-2007, 11:37 PM
The tracklites don't fit 4th gens. They were way off on the rear, and slightly off on the front. I ordered them (17" version) the week they came out a long time ago. I had to return them. After my whole ordeal, they stopped showing 17's and 18's as fitting the Max within 1 week. I don't see how 19's would be any different considering the fittment issues I encountered. You could make them work with extreme spacers and new lug bolts I suppose.....
The Wizard is offline
Old 06-13-2007, 12:01 AM
Well, the offset isn't exactly ideal... but get some spacers and you should be ok I think. This is only 7.5J anyway.
Old 06-13-2007, 10:27 AM
IIRC, I had the same problem with my 5th gen. For some reason, I want to think your problem was a little more extensive than mine.
But, for me, 15mm spacers fixed things in the rear, and the fronts worked alright.
NmexMAX is offline
coolsun
Wheels/Tires
11-13-2016 05:01 PM
Garrettz459
09-28-2015 02:50 PM
Quick Reply: Heads-up: 19" traklites at tire rack
