high idle speed...? WTF.....
Old 05-31-2007, 06:09 AM
RayRey21's Avatar
last night I pulled in my driveway.......as I shutoff the radio I notice that the car is idling at 2,000 rpm!!! Throttle cable was not sticking or anything....any ideas? will see what happens today but what could cause this?
thanks
RayRey21 is offline
Old 05-31-2007, 06:16 AM
mikekantor's Avatar
If you manually open your throttle a little bit, do the rpms go down?
mikekantor is offline
Old 05-31-2007, 06:27 AM
RayRey21's Avatar
I opened the hood while it was idling high.....I pulled the throttle cable in the engine bay but it went back down to 2,000.....no lower...if that is what you mean?
RayRey21 is offline
Old 05-31-2007, 06:39 AM
redwood_usa's Avatar
probably your IACV. reset the idle by switching off you ECM and adjusting idle. If that does not work. remove the motor part of the iacv (3 screws), remove the chock that stops the valve from rotating and then rotate the valve out a few turns and reinstall.
redwood_usa is offline
Old 05-31-2007, 06:41 AM
Way out West
Cliff Clavin's Avatar
my guess would be IACV or coolant temp sensor problem. I had something similar happen to mine, except idle was surging, too.
Cliff Clavin is offline
Old 05-31-2007, 07:11 AM
RayRey21's Avatar
do you guys have any pics on how to do this?
RayRey21 is offline
Old 05-31-2007, 07:33 AM
No, but its really easy, all you need is a philipps head screwdriver and a pair of pliers to get the bypass hose out of the way. Ask mygreenmax for a pic of the valve itself.
Old 05-31-2007, 09:13 AM
Ad·min·is·tra·tor
DanNY's Avatar
next time that happens take a pair of pliers and pinch the IACV hose...it's a rubber hose that goes into the intake. if you notice the idle going back down to normal you know that's your problem.
DanNY is offline
Old 05-31-2007, 05:25 PM
92 Max's Avatar
The IACV controls idle by letting a small amount of air past the throttle plate. If you have a small crack or leak in the IACV hose to the throttle plate you could see an increase in the idle.
92 Max is offline
Old 05-31-2007, 05:32 PM
¯\(°_o)/¯
Greeny's Avatar
Greeny is offline
Old 05-31-2007, 07:08 PM
RayRey21's Avatar
you guys are awesome....you are 3 for 3 with issues on my max......on looked at the IACV hose and what do ya know....it has a crack in it.......will replace it tomorrow and the idle should be back to normal.......
thanks again...
mygreenmax...thanks for the pic...made life alot easier!!
RayRey21 is offline
Old 07-10-2007, 08:11 PM
MAXatBEACH's Avatar
My 3rd gen has been idling in the 1500-2000 range for some time. I did this pinch test on the IACV hose and indeed my idle went way down, to the point of just barely running. My question is if everything is working properly and one does this pinch test, what is the result?
MAXatBEACH is offline
Old 12-19-2007, 10:28 AM
drftking1's Avatar
oh beautiful....this made my life easier....one of the guys at work flushed my vg with a garden hose to get my heat working better and had the intake off.....idiot left that IACV hose off a little and the clamp wasnt even on it.....idle went down form 2000 back to normal....oh thank you!
drftking1 is offline
Old 12-19-2007, 10:32 AM
mikekantor's Avatar
three cheers for easy fixes
TKHanson
11-24-2018 01:39 AM
Unclejunebug
04-02-2016 05:42 AM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: high idle speed...? WTF.....
