Oil here, Oil there, Oil Oil Everywhere!
Old 01-18-2007, 07:29 PM
4togrfr's Avatar
Over the last couple years, my '90 has been leaking more and more oil. Best I can tell it is the rear main seal. Has anyone replaced this in your garage? I am very capable mechanically, but this looks like a real PITA and I am debating just taking it to a shop. Time is not particularly of the essence as the Maxima is no longer my daily driver. Any opinions?
Mike
4togrfr is offline
Old 01-18-2007, 07:42 PM
¯\(°_o)/¯
Greeny's Avatar
If you can pull a transmission,then you can replace the seal...
Greeny is offline
Old 01-19-2007, 05:36 PM
slickblack94's Avatar
How about the front seal? Last oil change I noticed some oil coming out.
Is this an easy job? Think I'll just put J/B weld all around it.
slickblack94 is offline
Old 01-19-2007, 05:41 PM
¯\(°_o)/¯
Greeny's Avatar
Step away from the blunt..
Greeny is offline
Old 01-19-2007, 05:49 PM
oh ,ok your right. I just found my duct tape. Lets call it a wrap puff puff pass
Old 01-19-2007, 08:36 PM
timstover's Avatar
A seal softener product may solve your problem, However do not use a seal softener if you are leaking at the front crank seal or cam seals. The chemical can damage the timing belt. Take your car and presure wash the motor. Watch it over the next day or two and you will see where it is leaking by the fresh oil. If you ever replace the timing belt, be sure to replace the front crank seal and cam seals while the belt is off.
timstover is offline
Old 01-20-2007, 06:09 AM
<<<<<< no belt there,but then again dont know if your
talkin to me.
Old 01-20-2007, 04:58 PM
mod or sell?
internetautomar's Avatar
I had the front main seal on mine done recently. gave me a reason to upgrade to a UDP
internetautomar is offline
Old 01-20-2007, 06:26 PM
mikekantor's Avatar
Has anyone seen an oil leak at the UDP? I think mine is doing that, or maybe from the oil pan seal but its not clear.
mikekantor is offline
Old 01-20-2007, 10:02 PM
mod or sell?
yup, if it hasn't been sleeved than there is a good chance of it doing it
litch
123
01-04-2024 07:01 PM
Miket2006
03-01-2021 03:55 AM
mclasser
22
11-12-2020 01:58 PM
05RLS2
04-14-2016 11:49 AM
Quick Reply: Oil here, Oil there, Oil Oil Everywhere!
