Wb wiring into cabin suggestions/questions
Wb wiring into cabin suggestions/questions/Results
Where did you 5th genners get your wide band wires into the cabin? Been tossing around many different areas & ideas and have heard of some using the glovebox area as a starting point. Would this be in the area of the in cabin micro filter?
Any other suggestions? How about the gear shifter 'area'? Looking at the FSM there could be a way using the shifter cable hole. (4AT) but will still require some grommets for sealing.
Are there any other easy access points under any of the seats...or anywhere for that matter?
Originally Posted by NmexMAX
Haven't gone and looked yet, just in the FSM, but the A33B does not have a rear o2 sensor. But, will check on that.
I wired mine 02 sensor through the shifter housing between the body frame and the shifter...I just took off a corner of the rubber piece, put it through and put the rubber peice back on.
I kept the entire LC-1 unit inside the cabin, even though innovate sais you can mount it outside the car.
Brought it in from the firewall.
I'm actually doing ok AFR wise. starts @ 13.5 and heads towards 12.8-ish. Here's my post in the general forums 'What have you got waiting...'
Not on....yet
Read this thread for details. Don't make assumptions, just read it..mmk? http://forums.maxima.org/showthread....AF#post3844522
Done... Data to come. Pretty clean install. I bunged the y-pipe before the flex section.
Strange thing is, I'm running OK AFR wise. Anywhere between 12.4 - 13.6 WOT.
There is definitely room for improvement though.
Not on....yet
AaronL
08-08-2020 10:31 AM
trsandrew
10-25-2015 02:47 PM
