Just got Fast blinking LED turn signals. do you like them?
2002 maxima se
I went to autozone and replaced my tail turn signal bulbs with LED RED 1156R. it was not easy to get those bulbs into the connector socket because the OEM1156 bulbs are a bit diffrent than new LED 1156R but i managed to push them in with force and they fit straight in. ok then i noticed that all of my turn signal bulbs have become quicker comparing to the stock timing and also are nice and bright LED. now they blink faster and produce more light because of new LED bulbs. in front i got silverstar amber 1157 they look better than any stock bulbs out there and they noticed bluish when off. anyway if any of you want to get fast blinking turn signals go with 1156R RED LED. you wont be disapointed. cost $18.00 heres the picture>>>
2002 maxima se
Originally Posted by ktranne
yeah, that happened to me b4. Had it for 2 weeks then realizes it draws attention to cops so I got load equalizer.....
Originally Posted by greg84mk2
load equalizer? you mean some kind of relay that slows the flash intervals?
its easy - you're just adding the resistor to the circuit. You splice one end to the ground wire, and the other end to the... black wire? Something like that. Works as advertised though! you'll need one for each light.
they sell it on ebay...its called load resistor
http://cgi.ebay.com/ebaymotors/LED-L...4184QQtcZphoto
2002 maxima se
Originally Posted by bluedevil1550
Does anything happen if you use LEDs for the brake lights and not the signals?
I tried LEDs in my brake lights and everytime I'd hit the brakes, a red bulb in the instrument cluster would come on (the one that tells you you have a brake light out). I got tired of that real quick, but when I put the originals back in, the brighter filament on one bulb was out. I got a new bulb and it worked fine, but it was kind of a pain.
My $.02, since you asked, is that LED replacement brake or turn signals look extremely cheesy unless you get them custom made to fill the whole housing like a few ppl on here have done.
Ive been doing some research since finding this thread, and came across this site:
http://www.superbrightleds.com/mini-wedge.html#
It discusses the load resistor and explains that not to expect the LEDS to be brighter than regular filament bulbs unless one particu;ar style is chosen.
I have no affiliation with that site and Ive never bought from them, so this isnt a testamonial for them... just good reference.
Originally Posted by OC guy
i dont think cops should have any problem with quick blink. afterall we are using the red and amber lights?
i have the same problem with the LEDS, even though i have the load resistor, i've haven't found time to install them. i don't get hassled by the cops and i live with the best of the worst cops....NYPD!!!
if ur getting LEDS, get the refracting LEDS 7740/7743. they definitely shine the entire taillight at nite.
pears
09-18-2015 05:25 AM
chernandez1278
09-16-2015 01:18 PM
BrandonCause
09-14-2015 10:41 PM
