Nuts backing out???
Old 12-05-2006, 07:19 PM
tcf_dk's Avatar
Nuts backing out???
Started about a 1 1/2 months ago.Left rim wobbled on road.Had to retorque nuts.Found 4 to be very loose and backed out quite a bit.Only one was tight.Any idea what's the cause?The studs are not stripped.Do I need a new rim or nuts?By the way,I have steelies.
tcf_dk is offline
Old 12-05-2006, 07:55 PM
Hoooper
i would check to make sure that the conical mounting surface on the wheels hasnt been stretched or anything. if they look to not be round, or look bigger than they used to be then thats your problem and you need new wheels
Old 12-05-2006, 08:03 PM
tcf_dk's Avatar
The 4 lugs that came out does this every week or week and a half depending on miles put on.
I was thinking about just getting a new steelie to see it that'll solve the issue but don't wanna waste the money if that's not the problem.
tcf_dk is offline
Old 12-06-2006, 02:00 PM
Hoooper
yeah, check on what i said and post back
Old 12-07-2006, 07:52 AM
CanadianMoFo's Avatar
Are you sure you're torqueing them to spec? Also make sure that there is no grease or anti-seize on the stud threads. That can cause the nuts to work loose quickly.
CM
CanadianMoFo is offline
Old 12-07-2006, 08:51 AM
Da Roller Coaster!
foodmanry's Avatar
Torque spec is around 72 foot pounds to 85 foot pounds I believe.
I've always torqued mine at 78 foot pounds and never had any issues. I even put a little bit of anti-sieze on the threads and the lug nuts still hold up fine.
foodmanry is offline
lowpost99
05-16-2021 11:18 AM
captchaos
17
03-15-2016 12:18 PM
Maxima30
09-07-2015 06:13 PM
ef9
09-05-2015 11:18 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: Nuts backing out???
