US Maxima LSD option
Originally Posted by Cdg2125
haha nice posts. How easy is it to swap in the lsd from the canadian max or the infinit? Need new axles right?
Originally Posted by scrhale
Wow ... you should have your flame suit on. What you do is you pretend that your LSD tranny and LSD driver's side axel are actually non-LSD tranny/axel and reinstall it.
Originally Posted by MadMaxSE-L
in other words, get a LSD tranny, LSD drivers side axle and keep your stock non-LSD passenger axle and I think you are good IIRC, but someone chime in here it seems like I am missing something-maybe about an axle seal or something???
jjam
Originally Posted by i30ds
Non touring could have lsd as well.
jjam
Just so you remember, LSD sucks in the snow. Had a '91 Sentra SE-R w/ LSD and couldn't keep it on the road. Just spins both front wheels all the time unless you have great snow tires. Maxima is heavier, so that should help, although the tires are slightly larger too so it might even out. Food for thought.
Originally Posted by jjamzman
This appears to be the drill. I am working on this right now. The left axle needs to be from a 95-99 Infiniti I30 Touring, which is the LSD version. A total remanufactured left axle assembly is $77.00 or a new one for $118.00 based on online searches. I have not run into anything about other seals...yet. Anyone can jump in here and help. I am going to make this swap since my original trans just slipped away at 218K...if you know what I mean. I am looking for an Infiniti LSD trans now. I will just drive my beater truck until I find one. I have found 3 JDM LSD trans locally through an importer, but I have not determined if there are any hidden surprises going that route. I have emails into them right now for the ECU, TCU, mechanical, electrical, wire connector, differences to do this. As someone else indicated, I am being a pioneer here....I am just gellin like Magellan!
jjam
jjam
What are you trying to do ? You only need the tranny and the axle.
Was the LSD an option in any 4th gen Maxima or was it only in Infinitis?
There is a local JDM importer near me with several LSD trans. Unfortunately, they have been a bit short on info. They were not even aware that the left axle was different so I am trying to get more accurate information from this group. There is a considerable amount of time and money involved in changing this. I want to be sure I have compatible parts. Wouldn't you?
jjam
jjam
i have a 95 fed maxima. My auto tran got screwed when the axle popped out. destroyed 1/3 or more of the tooth. Had to use a dremmel to carve the tooth so that I can put an axle in. Took 6 hours pounding it in. If all the tooth wears out...I'm gonna do this. Hope you document it!
jjam
try this.. it's better to call them. http://www.engineworldusa.com/home.htm they have transmissions.
Your correct, but it would be an option, in which case you have to specify that and it leads you to the Touring model anyway. If you order the I30 Touring axle from the start, it is only an LSD version.
jjam
jjam
I'm letting you know that the 96-99 (there is no 95 btw) touring is not the lsd version. It maybe one lsd version, but other trims like some non touring and AE maxima had that tranny.
jjam
Maxilano
08-31-2015 07:33 PM
BobMax
08-15-2015 12:35 PM
ef9
08-14-2015 03:03 PM
