Another DEK Swap Completed
Old 09-19-2006, 08:03 AM
SC Overspinning Swapper!!
meximax's Avatar
Old VQ30’s oil pump gave out at about 180,000. Swap conducted purely for low mileage reasons and not for performance. There is not a single mod in this car. As bone stock as the day as it rolled out of the asssembly line, albeit, with a VQ30DEK.
I swapped the DEK in a method I thought was simplest (to me). I chose to tap the VQ30DE lower plenum versus keeping DEK plenum and finding injector clips, getting an AFPR, removing swirl valves, filling holes with epoxy, etc. Only maintenance items were changed (spark plugs, fuel filter, air filter, pcv, etc). VI is currently not plugged, but will be once summit rpm switch arrives.
Vehicle Specs:
-1998 Maxima GXE, Automatic
Parts list:
-VQ30DEK (20,000 miles)
-Custom TB/IACV Plates
-Flex tubing to connect TB to stock air box
-Random hoses to reach IACV relocation
All else was plug and play.
Impressions: Engine is ridiculously quiet, much quieter than my VQ35. It’s got some decent low end grunt, and fair high end (when I tied the VI open). Exhaust sound is similar to the old VQ30.
Engine on stand:
Somewhere half way through:
About done (minus hood):
Very Close to Final Product:
Thanks maxima.org for the numerous swap threads and special thanks to Matty for the quick responses to my PMs
meximax is offline
Old 09-19-2006, 08:13 AM
Stephen Max's Avatar
Hi Andreas. Good stuff, how's the VQ35 running?
Stephen Max is offline
Old 09-19-2006, 08:20 AM
scrhale's Avatar
I am curious as to how much you paid and where you got it. I am always about keeping up with prices.
scrhale is offline
Old 09-19-2006, 08:22 AM
matts95max's Avatar
when I did my de-k swap, I kept the de-k injectors. I also had a 2.5in pretty much open exhaust and it backfired when I let off the gas. U think if I go back to the de lower and fuel injectors and rail it will get rid of it?
matts95max is offline
Old 09-19-2006, 08:28 AM
meximax's Avatar
VQ35 is running great after a year. Its about to run much better, but you know me, I don't post plans, just results.
I didn't pay for it, I just did the swap. My customer found the engine through a friend that works at a local junk yard in Houston. Total spent was less than $900 for the engine and all maintenance parts, including spark plugs, new belts, all filters, engine/tranny oil, gaskets, etc.
meximax is offline
Old 09-19-2006, 09:01 AM
Maxima Owner
MaximaSE96's Avatar
are u going to add to the write up list???
MaximaSE96 is offline
Old 09-20-2006, 07:07 AM
meximax's Avatar
I dont' have detailed pics of the whole job, but anyone conducting a swap can feel free to PM me. If you are in Houston and want a DEK swap, shoot me a PM for a very reasonable rate.
meximax is offline
Old 09-28-2006, 12:28 PM
chillin014's Avatar
have you done any transmission swaps? i'm most likely going to need help with an engine and transmission swap in the future. and i dont know anyone with any experience or knowledge thats local.
chillin014 is offline
Old 09-28-2006, 01:55 PM
meximax's Avatar
I've have made numerous replacements for both manual and auto, but not a full tranny swap. I have seen the swap threads and there isn't much to them. If you bring everything needed for the swap, I am sure that I won't have a problem swapping them.
meximax is offline
Old 09-28-2006, 02:03 PM
chillin014's Avatar
Do you have a shop? I'm really into this stuff but I'm a first timer to everything so there's no former experience but I'm learning as I go.
Old 04-04-2014, 05:19 PM
Kretzmech's Avatar
Any way to get these pics back up?
Kretzmech is offline
Old 04-05-2014, 06:54 PM
aackshun's Avatar
I'll shoot him a text, but I doubt even he has em still
aackshun is offline
James92SE
142
01-02-2024 09:23 AM
hez8813
03-12-2020 12:06 AM
Socalstillen
09-20-2015 11:46 PM
Bonka
09-14-2015 11:18 PM
I<3 A32's
09-10-2015 11:07 AM
Quick Reply: Another DEK Swap Completed
