OEM Electrical System Upgrade II of II: BIG THREE, Grounding Kit Big Brother (HOW-TO)
Old 08-26-2006, 05:41 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
This is the second section of my electrical system upgrade. You can read the first part, how to upgrade the OEM ground wire, here.
This how-to will be convering the details on how to perform the upgrade known as the 'Big Three'. Essentially, it will yeild the following:
1) Reduced dimming and smaller voltage drops
2) More stable voltage and better current flow
3) Less strain on your vehicle's charging system
The BIG THREE consists of:
(1) Battery negative to chassis
(2) Alternator to battery positive
(3) Engine Block to chassis
...it essentially does the same thing as a conventional grounding kit, however it does so in a different fashion. I am not a big fan of grounding kits as I prefer this method. People will argue this one way or another, but I swear by this. So, let's get started!
TOOLS/SUPPLIES
10mm Socket
12mm Socket
Ratchet
10ft. of 1/0AWG Power Cable
3 1/0AWG Ring Terminals
1 1/0AWG Fuse Terminal w/ 300-amp fuse
STEP I - BATTERY NEGATIVE TO CHASSIS
Simple enough. We are going to be making an attachement from the negative terminal of the battery to the chassis. If you peek behind the battery you will see a good place to plant the wire.
Remove the bolt with your 10mm socket and sand away the spot to bare steel. After that, attach about a 1-ft. length of wire to one of your terminals, crimp, and bolt everything back together.
STEP II - BATTERY POSITIVE TO ALTERNATOR POST
Alright, this one is a bit more tricky. You are going to need about 5ft of wire split into two equal 2.5ft. lengths. We are going to be attaching the wire to the battery positive to a fuse terminal, then fuse terminal to alternator post.
You can find the alternator just to the outside end of the engine block on the passenger side. Look for a rubber boot covering a bolt. That's your alternator post. We'll start there. Remove the bolt using a 12mm socket.
Attach one crimped end of the 1/0AWG wire to the bolt, then screw everything back together.
Take the lead attached to the alt. post and run this to the fuse. Take the other length of wire and run this from the opposite end of the fuse and lead it to the battery. We're almost done!
Metal Maxima is offline
Old 08-26-2006, 05:54 PM
STEP III - ENGINE BLOCK TO CHASSIS
The final step is simple enough. Start off by locating a spot where you want to land the lead on the chassis. I chose an empty bolt hole located by the engine block. Sand away as we have done before.
Next, simply ground this to the engine block. I chose one of the 10mm bolts located on the side of the block. You can choose just about anywhere on the block; for instance, you will see two grounding points on top of the block. Golden rule with grounding wires is to keep them as short as possible, so just keep that in mind when doing this...
...and now you're done! Here's a shot of the battery when all is said and done...pretty bada'ss if I say so myself!
Old 08-26-2006, 05:58 PM
大陆弟弟
n3985's Avatar
Nice tutorial! We even used the same wire haha. But, isn't it recommended to have the fuse for the positive battery>alternator wire to be within 6 inches of the battery?
n3985 is offline
Old 08-26-2006, 06:03 PM
Yes, it is...but the only thing working against us here is the fact that we need to mount a massive fuse terminal somewhere in the engine bay...in this case, I mounted it to part of the radiator shroud, so lamentably, it had to be a bit longer. The closer to the battery the better, it's only a saftey precaution.
Oh, and doncha LOVE the SE wire? MAN it's flexible!!!
Old 08-26-2006, 06:05 PM
大陆弟弟
n3985's Avatar
It is a great wire, but cutting off the plastic coating and hammering on the ring terminal FTL.
n3985 is offline
Old 08-26-2006, 06:09 PM
Compared to KnuKonceptz, this stuff is a dream to deal with...even considering the mentioned case.
Old 08-26-2006, 10:10 PM
BLK2BLU's Avatar
would it be worth it to do this with 4 AWG or do I really need to use 0?
BLK2BLU is offline
Old 08-26-2006, 10:19 PM
BLK2BLU's Avatar
nvm on the post above, I just found it in the audio forum
BLK2BLU is offline
Old 08-27-2006, 01:10 AM
I R The Law
The Law's Avatar
so dan how is the start up now since you did the big 3?
The Law is offline
Old 08-27-2006, 01:17 AM
I'm watching you, boy...
SilverGLE's Avatar
Same question... I don't believe using 1/0 is worth the extra cost compared to 4 gauge. Also, what size fuse did you use? I was thinking of 150A, since the alt is rated for 110A or so (OEM size).
SilverGLE is offline
Old 08-27-2006, 02:46 AM
Jfree's Avatar
Looking damn good! I never even thought about putting the original power wire on the front terminal, what size bolt did you use?. Great job on the clean install .
^^As for wire size, you can use 4 gauge wire, but 1/0 or bigger seems to be the choice for the big 3 since the bigger the wire the less resistance.
Jfree is offline
Old 08-27-2006, 08:11 AM
NICE. The start-up is NOTICABLEY quicker.
Old 08-27-2006, 08:13 AM
See, here's the thing - I do. You are making the addition as to supplement as much current as possible between the alternator and the battery, ergo, it is of great benifit to use the larget possible wire. Also, alot of people don't like using 1/0AWG vs. 4 or 8AWG as a matter of economics. They simply don't want to shell out the extra money. It would behoove them in every respect to use the larget wire possible.
When performing this upgrade, the fuse should be rated for the cpacitance of the wire...not the alternator.
Old 08-27-2006, 08:15 AM
Thanks, J! I forget which bolt size I used, I think it was the GM-sized post for the ORT. I am REALLY going to clean it up next spring when I dress up the engine bay.
Exactly.
Old 08-27-2006, 08:23 AM
GBAUER's Avatar
...hope you painted the bare metal after you attached your grounds.
GBAUER is offline
Old 08-27-2006, 08:25 AM
They'll be fine. The car is a 2001, making it half a decade old, and there is no significant wear on any of the bolt heads.
Even so, you're right, it would be in the best interests to paint over them if you were concerned about corrosion.
Old 08-27-2006, 08:29 AM
GBAUER's Avatar
you live in Jersey. With all that salt, you should take a look at those spots in the spring....
GBAUER is offline
Old 08-27-2006, 08:31 AM
Will do. I am going to be doing an overhaul of the engine bay in the spring, so I will address any issue at that point in time.
Old 08-27-2006, 11:19 AM
Future Camaro SS owner
MyownNismo's Avatar
Did you have a positive wire going into the long fuse box next to the battery. I have one wire going from batterey post to fuse box.
MyownNismo is offline
Old 08-27-2006, 12:12 PM
crazy97's Avatar
The starter should be grounded as well.
You may not need it yet, but eventually you will....
I dealt with this in my sig->
crazy97 is offline
Old 08-27-2006, 12:15 PM
Hrmmm...seems as though this is something I should look into...
Old 08-27-2006, 12:21 PM
trigger005's Avatar
if u already have hypergrounding will the big 3 make any difference
specifically, the only difference would be the alternator->batt connection
ill probly do big3 in addition 2 my current setup
lovin the engine grounding
no chance of trapped electrons there
trigger005 is offline
Old 08-27-2006, 12:28 PM
trigger005's Avatar
wow
thx 4 sharin
and findin out the hard way for the rest of us
$2k 4 a harness
sick
is this a 4th gen only problem as far as u no
Old 08-27-2006, 12:41 PM
crazy97's Avatar
Originally Posted by trigger005
wow
thx 4 sharin
$2k 4 a harness
sick
One 5th genner has had this (Max Gator) on that thread. I think more will follow.
crazy97 is offline
Old 08-27-2006, 12:50 PM
PAREDLINE's Avatar
Looks like you're the man to call if the space shuttle ever needs a jump. Nice job on the 00 cable. How much did that set you back?
PAREDLINE is offline
Old 08-27-2006, 04:25 PM
SilverGLE's Avatar
This is true... I do understand that the larger diameter wire offers less resistence, and, therefore a better, easier path to ground (or whatever). But whenever I take into account that 1/0 is about $5/foot and 4 gauge is about $1.60/foot, it moves me to buy the cheaper of the two. Also, this decision spurs from how I've read other threads regarding the Big 3 and how they used as small wire as 6 gauge (which I firmly believe is too small) and got great, definitely noticeable results. Then again, this isn't something I should cheap out on, but you did use 10' of 1/0, which would cost abou $50 or so, plus the ring terminals. Just can't afford that now, crap! Regardless, great write-up!
Thanks! I'll remember that!
Old 08-27-2006, 04:41 PM
Probably $100 considering that the I have all Stinger Expert in there...
Old 08-27-2006, 05:18 PM
BLK2BLU's Avatar
Metal, is your l.e.d. cluster any brighter from this?
BLK2BLU is offline
Old 08-27-2006, 06:37 PM
I was wondering if it would be, but unfortunatley it is not. All of the LEDs I have don't draw in excess of 25A, which really is not all that much, so I did not suspect it would help at all.
Old 08-27-2006, 06:53 PM
MyownNismo's Avatar
what about my question. Do you have a 4gauge sized wire going into the fusebox. I do. This is something I will look into once I get settled in from moving.
Old 08-27-2006, 06:59 PM
Ah, yes. My apologies.
Oh, and I think it's absolutley hilarious that someone rated this thread one star. I have my suspicions as to who it could have been, and, if it was, you can go f'uck yourself. You bring nothing to the table.
Old 08-27-2006, 07:02 PM
MyownNismo's Avatar
who me. 10 char.
Old 08-27-2006, 07:06 PM
who me. 10 char.
No, no, no...certainely not you; sorry if it came across that way.
Someone rated this thread with a single star. I find it to be wholly humorous how some people whom do absolutley nothing to innovate find it nessecary to spite a helpful thread.
Old 08-27-2006, 07:46 PM
Droppin logs
D-Bo's Avatar
I have the HPM terminal with the voltmeter and was thinking about te display being upside down. What are your thoughts Dan? I would rather have it oriented so it's readable from the front. Did it not make a difference or was that easier for routing the cables?
D-Bo is offline
Old 08-27-2006, 11:42 PM
Jfree's Avatar
Thx for the help, your engine bay puts mine to shame
Jfree is offline
Old 08-28-2006, 04:35 AM
crazy97's Avatar
Wasn't me. I didn't even know that we could vote(I don't pay attention to that), but I just gave her 5 stars.
crazy97 is offline
Old 08-28-2006, 08:43 AM
CVicVogel's Avatar
MM
Nice job!
Maybe we'll get to see it at the next Moorestown meet of Maxima owners?
CVicVogel is offline
Old 09-19-2006, 02:00 PM
REXXX
BaDMaNDUNK's Avatar
are these the very same connections as those recommended by the nissan grounding kit? if not, what makes this connection strategy better?
each setup (nissan vs. metal) uses a total of four connections, correct?
BaDMaNDUNK is offline
Old 09-20-2006, 04:50 AM
VQ20's Avatar
Where u got the terminals with the voltmeter from???
VQ20 is offline
Old 09-20-2006, 05:03 AM
misiek's Avatar
i got mine from ebay ($50 for both shipped)
misiek is offline
Quick Reply: OEM Electrical System Upgrade II of II: BIG THREE, Grounding Kit Big Brother (HOW-TO)
