00VI Adapter Diagrams
I'm having a buddy make me IACV and TB adapters for my 00VI as a favor to me, but he needs something to work off of, especially since my manifolds aren't here yet. I have some vague pictures from Ceasar's gallery of the IACV, but an actual diagram would be better. I also have nothing on the TB (which I'm assuming is just a square with 8 holes on it). Can anyone help me out here? Even just a quick sketch?
I will be going through the same thing with my car very soon. My suggestion is to wait until your UIM shows up and make a template of the outside shape of the UIM neck and bolt pattern on a piece of poster board type material. Do the same from your IACV and then map out the dimensions from how things will be positioned in the engine bay. From that you (or your friend) should be able to come up with an adapter.
Doing it on your own is part of the fun, right? It is for me at least.
Good luck!
Good luck!
Ehh...I dunno about fun. I didn't think I was really going to need one so much for the TB, but the IACV I dunno...seems a little weird. I'm just trying to get an understanding from the pictures, but my friend has to machine these obviously and needs something to work off of.
So are you using the 4th gen TB and IACV? If you are, it should be fairly easy to make a shape and bolt pattern template from them to start. If I had an 00VI UIM, I'd sketch the templates for you.
An even better idea Kev. As soon as I get my 00VI UIM and start the process of making my adapter, I'll be posting some pictures and make an offer to reproduce them (for a fee of course) for those who want to do the 00VI swap using the 4th gen. TB and IACV. Details to follow.
Awesome tatanko we'll be doing this at the same time. I also need those adaptor plates man so hook it up!! I'm gonna be using the 4th gen lower manifold too, what about you? Are you using both the upper and lower from the 00?
Originally Posted by Kevlo911
Use the 4th gen IACV gasket and the 4th gen TB gasket as templates.
Nearly all the adapters I've seen were simply a flat piece of plate with either a fitting or piece of tube feeding the air from the intake to the base of the IACV. Maybe I'm missing something, but what is the purpose of the recessed area?
Below is a link to a photo of the integrated spacer/IACV plate as fabricated for the PF TB swap:
http://pg.photos.yahoo.com/ph/ceasar...cd.jpg&.src=ph
Here is an IACV plate only that was fabricated by Stephen Max:
And finally, here is one that Kevlo is referring to with the recessed area:
God this is confusing with the cup crap lol. Oh well, I'll just have to wait til friday when my stuff gets here.
Kev, if I have said "cup," and remove it, do I need the recess? Or can I just make a flat plate with a hole on one side and a hose connector...thing...on the other side of the hole?
Probably the best thing for you to do Tatanko is to unbolt the IACV (should be fairly easy to do), pull it back a little and look at the base to see what's involved. From there, you can also take a piece of poster board material and trace a template for your plate. If you take the time to understand how the IACV works and how the plate will be made and have an accurate template, your buddy should be good to go from there. If he has a machine shop with all the right tools, he should be able to crank out a sweet product for you.
The cup has 3 screws. Remove it and throw it away. Yes you can use a flat plate. Drill a hole so a 10mm nipple will fit and use it.
Yeah, my memory is better today haha.
From what I've seen other people do, you either have to create a port on the UIM near the neck or drill and put a nipple on the adapter plate between the UIM and TB. You can see from the adapter (first link in post #15) - it serves both purposes.
Not sure if you're going to follow that method, but you may want to read up on idle issues and make sure you think ahead before deciding which method you use to attach the IACV. I'm certainly not an IACV expert, but I do believe position of the valve, air volume, and port size make a difference in the IACV function. I could easily be wrong though.
I took off my adapter plates but I truelly think the only way to get the 4th gen IACV to work is to use a nipple that provides a good amount of flow. I used a 3/8" barb fitting and I thought the flow was too little. I would hear the IACV allways clicking. When coming to a stop the rpms would be at 850 than drop to 600 RPM after a second or two. So the setup has to be done correctly if you are trying to get a functional 4th gen IACV.
Also, don't connect the hose coming out of the IACV to your Brake Booster Hose. That's a NO NO. Your brakes will most likely go out on you.
The Brake booster hose is the one closest to the firewall. It connects to the left rear side of the upper intake manifold as if you were facing the engine.
Also, one other question...where would I get the necessary PCV valve for the swap? Most write-ups I've seen say you need a new one that has a bend in it or something, but none ever list a part # or where they got it or anything.
also, i'm looking for adapter plates as well, so toddmullins please do let us know when you can reproduce some plates.
im not sure waht the plate looks like but i saw this in an 00vi for sale thread. is this what yall are talkin about?
taken from http://forums.maxima.org/showthread.php?t=483040
Yeah I figured out after removing my IACV yesterday and cleaning it and stuff that I needed a recess regardless of whether or not the cup was there.
Earlier I went to Advance Auto and asked to see a PCV valve that would fit a 2000 Maxima, and the one they brought me looked identical to my 4th gen one. But apparently ours don't fit? What gives? So I bought one the same size with a 90 degree bend in it and I'll modify it a bit if I have to (to make it's height a little smaller).
EDIT: I'm a tard.
EDIT: I'm a tard.
EDIT: I'm a tard.
EDIT: I'm a tard.
once you have the tb and iacv adaptor plates and your modded LIM all you have to do is grind down the coil bosses and then your ready to go? or what.
http://forums.maxima.org/showthread.php?t=477210
Read the above link post #20. It shows a comparison of 4th and 5th gen. People have been able to get the pcv to work on a 4th gen. but if not done correctly you will have a vacuum link. For this reason its good to hacke the 4th gen rear valve cover so that it has a barb fitting horizontally.
so whats the status on the plates and all that? you still waitin on your 00vi? mine should be here on the 25th.
