Need Help On Dek Swap Im Stuck!!!!
Anyone have a diagram or something of how all the egr and fuel lines work? and all the other hoses. That is pretty much all I have to do after I rewire the injectors. oh and what did yall do about the part of the wiring harness that only has the back 3 injectors and the oil pan connector on it? did you use that off of your de?
-matt
Originally Posted by Nismo3112
Can't you use the DE-K rear harness, and not have to rewire the rear 3 injectors? All of the other plugs should be the same as the DE?
-matt
Originally Posted by matty
I dont think the DEK harness has the same clip as the DE. That main large silver harness on the top section.
-matt
-matt
where is the fsm to look at?
http://www.phatg20.net/modules.php?n...ownload&cid=73
ok I tried to start in, but no start. heres a list of probs that I dont know how to fix
1. There was no fuel in the fuel lines going to fuel rail from filter
2. my tps on the 4th gen only has one connector the 5th gen has 2 and on my de harness I only have 1 connector to plug in, can I used the tps on my 4th gen tb?
3. Not sure how to hook up all rubber hoses? egr as well? and there are metal hoses im not sure where to hook up.
4. There is a black thing like on the back of the engine bay behind the abs with hoses not hooked up to anything..
5. I made a plate for the bottom of the tb to block the iacv but what do I do with that connector?
Will all that cause it not to start?
Did you swap over the crank, cam sensors? That is needed the DEK's sends out a different singal than the DE does. Someone correct me if I'm wrong. So if you still have the DEK crank and cam sensor in, that also could cause the car not to start.
You sure you have them all hooked up properly going the right way ?? The line from the filter, to the front of the fuel rail, then around the fuel rail to the Fuel pressure reg, then off to the tank return line. Does the FPR have vaccum ??
You can use your 4th gen TPS.
I think the upper cam sensor is different but the crank ref on the bottom by the main crank, I think is the same.
All your grounds hooked up properly ??
-matt
-matt
where is the fpr? I ran the fuel line from the back fuel rail to the other rubber hose to the left of the fuel filter assuming that was the return..but where is the fpr?
im grounded on the valve cover
When you turn the key to ACC you should hear the fuel pump "Prime"...its not going to be coming from the fuel filter locationg.....it will be a buzzing from the backseat that should last about 5-12 seconds.
if the car is starved for fuel you should still hear movement, and the car trying to crank. Fuel isnt the only problem. Did you test the crank/cam sensors to make sure they are in proper working order?
havent checked the rail return line, but im not getting fuel from the filter, ill check it when I get home. and I used my crank sensor from my working motor and left the cam sensor that came with the dek so I have not checked them. Could a faulty ground cause the fp not to prime?
ran wire to ground on battery and saw I was getting fuel so that solved the fuel problem then I tried to start her her up and she didnt crank the first time but did the second. Now she just wont stay on.
Vaccum lines..not all. The vaccum hose on front valve cover for the stock air intake system isnt hooked up. the coolant line for the tb needs to be plugged, the egr isnt hooked up all the way. on the back left part of the 00vi a nipple piece or somethin broke off that I guess was used for vaccum so i taped that off.
Im using a plate to block off iacv on the bottom of the tb and none of the connectors for iacv are plugged in. Im using 4th gen tps on 5th gen tb
Yes I tried holding thottle open..seems like it dies faster that way..
yeah I got the tps adjusted, and finally got the car to stay on buy keeping throttle open, I do hear leaks. going to work on them when I get off work. I need a little help figuring out egr hoses tho to get it hooked up right
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
tarun900
19
12-20-2021 06:57 PM
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
