7" LCD TV, DVD Player, custom trim piece for tv..
Old 05-29-2006, 10:30 PM
phatmax95's Avatar
The TV is a 7" LCD made by TV ONE and the model number is LT-070S. It has a built in cable ready TV Tuner and supports 4:3 and also 16:9 formats. For connectivity it has a video out, headphone/audio out, composite video/audio in (RCA), and s-video/rca audio in. It has optional button controls if you wanted to mount those somewhere, and also a IR receiver for the remote control. Its not your typical car lcd tv, it is made for video playback on highend film videocameras, so it has a really good picture and very wide viewing angle. Used it very little, maybe 4-5 hours. Sold the car it was in and have nothing to put it in anymore so thats why I am selling it. It was taken out of the casing and modified so it would fit behind the dash where the radio and all is. I would like to get $260 for it. Here are some pictures:
I also have for sale a DVD Player made by XO Vision, model number XO-1100. Comes with a remote sensor eye so you can mount the dvd player elsewhere while still being able to control it. Also has a module to use to connect to the car 12V, or you could use the cig lighter adapter. Only used it like 2 times. I would like to get $75 for it. Here is a picture of it:
phatmax95 is offline
Old 05-29-2006, 10:32 PM
phatmax95's Avatar
I am also selling a trim piece that was custom made for a 7" LCD mainly this one. What I did was take the casing that came with the tv and cut it out and placed that inside, and bondo'd it all together. I was in the process of redoing it to make it better, and had finished the exterior but there are no mounts. Would be pretty simple to make some on the rear of this piece for the tv though. I would like to get $40 for it. Here are some pictures of it and one with the tv behind it:
Here is a picture of the remotes for the DVD and TV, the Remote sensor, and the 12V Module for the DVD.
Old 05-29-2006, 10:39 PM
phatmax95's Avatar
Here is a picture of everything when it was mounted in the car, as you can see you can just put your cd player in the bottom DIN slot.
Or, do a package deal with the TV, DVD Player, and Trim Piece for $350.
Or, just the TV and Trim Piece for $280.
Old 06-20-2006, 09:15 PM
phatmax95's Avatar
Bump......
Old 06-29-2006, 06:27 PM
Jacked Up off MountainDew
bluestealz's Avatar
cant see the pix
bluestealz is offline
Old 06-29-2006, 06:35 PM
phatmax95's Avatar
They load fine for me. If they still don't work for you, go to this link they are in there near the bottom.
http://www.flickr.com/photos/phatmax...7594119422991/
Let me know,
Thanks,
Tyler
Old 07-13-2006, 11:23 AM
phatmax95's Avatar
Bump this stuff needs to go..
Old 07-13-2006, 08:58 PM
jitiola's Avatar
yo do u think that it will fit in a 1996 maxima cuz if it will ill buy the tv plus trim off of you my dude
jitiola is offline
Old 07-14-2006, 10:37 AM
phatmax95's Avatar
Yes the trim piece will fit in any 95-99 maxima.
Old 08-09-2006, 06:18 PM
phatmax95's Avatar
Bump, needs to go!
Old 08-09-2006, 08:15 PM
SDB318's Avatar
how much for everything?
SDB318 is offline
Old 08-10-2006, 04:42 AM
phatmax95's Avatar
It says it at the bottom of post #3..
Old 08-19-2006, 05:11 AM
zippyflu's Avatar
im a noob to all this tv stuff.. but why is it all wirey?? im buying a dvdplayer or at least looking into it.. a dvd/cd headunit... of course ill eventually get a tv...
zippyflu is offline
Old 08-20-2006, 12:38 PM
Likes them corn fed
eckounltd287's Avatar
40 shipped to 12533 for the trim piece...
eckounltd287 is offline
Old 08-20-2006, 07:14 PM
phatmax95's Avatar
Because this TV has a built in TV tuner (to recieve tv station signals with an antenna, or you can plug up to cable). It also has audio/video inputs and outputs.. It's not just a screen.
Old 08-20-2006, 07:18 PM
phatmax95's Avatar
Should only be about $5 to ship it. So, $45 shipped.
Old 08-20-2006, 08:19 PM
Spak97max's Avatar
still for sale?
Spak97max is offline
Old 08-20-2006, 09:43 PM
phatmax95's Avatar
Yes... everything is.
Old 08-22-2006, 08:40 PM
Fre$h_TurK
how much shipped to 07058 only the tv and the dvd player...btw where did u put the dvd in ?
Old 08-22-2006, 08:56 PM
phatmax95's Avatar
Shipping should be around $10. I would put the DVD player under the seat. It has a remote sensor you can put up front so the remote would work with it. Where you going to put the TV?
Old 08-22-2006, 09:03 PM
Fre$h_TurK
just where u put it ...(ur pic up there)
i was thinkin of getting a screen and a dvd/mp3 capable HU... without the dvd player ur selling ... is that possible ?
how does the TV work ? satellite or sumthing... lol sry for the nooby questions
Old 08-23-2006, 04:33 AM
zippyflu's Avatar
howcome u have a seperate headunit in ur car? how did u plug ur tv into the dvd player (the one ur selling) and the headunit where the tray is? just bought a dvd/hu so i would like more info
zippyflu is offline
Old 08-23-2006, 11:07 AM
phatmax95's Avatar
You do know that it won't fit where I put it unless you modify the trim piece, like I did to the piece that I am selling.
Sure you can use any dvd player you would like, you will need a power inverter for a home dvd player though. And if you get a dvd headunit it will need a video out and you can plug that right into the screen.
The TV works like any other TV. You either use the built in antenna to pick up local TV stations, or connect an external antenna to the coaxial input, or if you wanted hook it up to a cable tv line through the coaxial input.
Old 08-23-2006, 11:11 AM
phatmax95's Avatar
What do you mean seperate? I only have one headunit, you have to have one to connect to all your speakers. Its similar to a receiver in your house. You just connect the audio out from the tv to the audio in on the headunit through ordinary RCA cables. And connect the audio/video out from the dvd player to the video in on the tv, and the audio in on the headunit. If your headunit plays dvd's then there is no need for my dvd player.
Old 08-23-2006, 11:37 AM
maxiquin's Avatar
you sold this yet? i'll give you 200 shipped for everything...
maxiquin is offline
Old 08-23-2006, 12:24 PM
phatmax95's Avatar
No.. I still have it. Yeah right, $200 is way too low. It's worth way more than that.
Old 08-23-2006, 12:56 PM
maxiquin's Avatar
200 without the dvd player...
maxiquin is offline
Old 08-23-2006, 02:57 PM
zippyflu's Avatar
i see that you have a headunit underneath the tv, and u have the stand alone dvdplayer. wat is the dvd player for and how did u connect it to ur tv along with the headunit on ur dash underneath ur tv?
zippyflu is offline
Old 08-23-2006, 04:48 PM
phatmax95's Avatar
The DVD player is for playing DVD's... the headunit doesn't play DVD's...
You connect the audio out on the dvd to the audio in on the HU.
You connect the video out on the dvd to the video in on the TV.
If you want the sound from the TV tuner, you connect the audio out on the tv to the audio in on the HU.
Old 08-23-2006, 04:52 PM
phatmax95's Avatar
Old 08-23-2006, 08:40 PM
Canepole
Like I said man I was only trying to help
Old 08-24-2006, 12:07 PM
phatmax95's Avatar
Originally Posted by Canepole
Asking way to much man. I can get a new Screen/DVD player for around $250 (check Ebay). The custom in-dash part is just a bonus. You can't charge anything for it. Just trying to help you man.
Sure you can get a cheapo screen, without a built in tv tuner. I can't charge anything for a custom trim piece that has hours of fab time in it? Sure I can.. I have yet to see a maxima with a piece like that, all the others have a step down piece to the tv. I have already done my research and this is what these pieces are worth give or take a few bucks. If you want to help, buy something and stop posting worthless posts.
Old 08-29-2006, 03:00 PM
mtnbikeair's Avatar
How much for the DVD player and TV if picked up?
mtnbikeair is offline
Old 08-29-2006, 06:00 PM
phatmax95's Avatar
The prices I have listed are not including shipping, so basically the same. But since I wouldn't have to pack it up I may take off a few bucks. Let me know if your interested.
Old 11-20-2006, 05:43 AM
phatmax95's Avatar
Bump... still have everything listed.
Old 11-20-2006, 08:33 AM
edlab03's Avatar
whats the lowest you would go for just the dvd player?
does it have last memory playback? the dvd player i have now gets on my nerves since it doenst hold the memory from the time i turn off the car. if it does im really interested.
let me know. thanks.
edlab03 is offline
Old 11-21-2006, 06:33 AM
phatmax95's Avatar
I have no idea. I only used it once and that was to test it to make sure it worked. What I have listed is the lowest I want to go.
Old 12-09-2006, 09:59 AM
jattdemax's Avatar
how much to ship the trim piece to canada. K4A3C9
jattdemax is offline
Old 01-29-2007, 01:51 PM
Hey There Mr. Paperboy...
ionblu_max96blk's Avatar
have you sold any of these b/c the pics don't work...
ionblu_max96blk is offline
Old 01-30-2007, 07:58 PM
phatmax95's Avatar
I still have them I will have to relink the pictures.
Quick Reply: 7" LCD TV, DVD Player, custom trim piece for tv..
