"Going Under The Knife"
Alrighty well my baby is about to go the mechanic tomorrow for what i believe is a major over haul. I'm very into my car and when i see something wrong with it, i just have to fix it. I'm also very paranode about my car. So i wanted to ask you guys a few questions before i bring her in, so that nothing else get's messed up.
First Off: I bought the oem 5th gen clutch, i wanted to know if it will fit %100 like the oem 4th gen.
Second: Resurfacing the flywheel is a good thing? because i've never heard of doing this before.
Third: When i drop the tranny to replace the rear engine seal and clutch do i need to replace the bolts that hold the tranny? I've read that these might cause leaks if not replace...?
Forth: Polyurethane bushing on stock suspension sould be ok?
Fifth: Can the clutch pedal be adjusted? meaning can i adjust the height of the pedal itself???
Thanks for help. I just want to make sure everything i'm doing is going to work out in the end.
1. Yes, I think 5th gen PP has more force however.
2. Yes, it should be done with any clutch job.
4. Yes.
5. Yes, it is shown in the FSM. If you need a link PM me.
I have not heard/looked into #3.
4. Yes.
You dont need to replace the bolts that hold the tranny in place, there a strong good grade bolt, no need to replace. But when doing the Rear main seal, make sure its seated properly and dont be shy with the RTV sealant.
YES!!! TY was hoping for both of you to respond...lol
What's RTV sealant?
Oh also i got some lube from energy suspension, what else can i use that lube on and what's it's purpose exactly..it doesn't say on the box.
What's RTV sealant?
would anyone else like to chime in? any opinions, ideas, tips, or anything to make the job smooth.
Here's what i'll be doing.
1.) Rear Engine Seal
2.) 5th gen clutch + pressure plate + TOB
3.) Resurfacing Flywheel
4.) A/C and Power Steering Belts
5.) Polyurethane Control Arm Bushings
6.) SS Clutch Line
7.) New Amsoil Tranny Fluid, Mobile 1 motor oil, and OEM DOT3 Brake Fluid for the clutch (Super heavy duty oil)
Thank You once again for your time.
Edit: Freeway to adjust the clutch, there's a bolt behind it right? do i need to bleed it after i adjust it? should i adjust it before or after the new clutch goes in? Help..LOL
6.) SS Clutch Line
I thought the maxima flywheel couldn't be resurfaced. wait EDIT: can't be lightened, oops anyways they know what they're talking about 99se5speed, now get out there and "get 'er done" - George Dubbya.
o god i think i messed up...i think i also bought a 2001 pressure plate, will it fit? or should i have bought a 99 pressure plate..omfg it's 2am and i'm supposed to be at the shop at 8am. I'm definetly not gonna sleep tonight.
6.) SS Clutch Line
6.) SS Clutch Line
I don't have the 5th gen setup so hopefully someone can step in.
What's RTV sealant?
What's RTV sealant?
Just a type of silicone sealant/ gasket material. I think it stands for room temperature vulcanizing. Ie cures at room temp.
^ i was just making sure, i became very paranode at the last minute..
Anyway this is the best thing i could have done so far. The tranny shifts so smooth and the clutch is great, better then expected. Thanks for all the help.
