Help would be GREATLY appreciated. Ticking noise.....
fwd gone rwd cr00
hey, it's that time again, I have a problem with my car.
Today, I replaced a belt (accessory belt), checked the oil (kind of black, but still a good amount), and ran seafoam through the brake booster line. it smoked just as it should have, and ran great. I went to the track today, and on the way there, I noticed I had a ticking noise, and it got faster the greater the rpm's got.
I looked in my engine bay, and it sounds like it's coming from the rear valve cover. I disconnected each coil pack (it wasnt a coil issue) and checked the IACV. The car runs fine, although a little slow, but the ticking is there and it's very annoying. I've searched for this on the .org, and i went to Requin6's thread, where he had to replace his engine cause it was valvetrain related.
I'm hoping it's not, I didn't beat on the car before this happened, so I don't know what the issue would be.
Does anyone have any idea what the problem could be, and a possible solution?
Thanks alot.
Thanks alot.
Noticable ticking from a valve cover is most likely a lifter/valve clearance issue. Only way to diagnose it is to measure valve clearances. It amazes me that these cars do not have a scheduled valve adjustment in the maintence tables - many cars specify adjustment around 100K. The manual simply says "If valve noise increases inspect valve clearance." Nissan, for some reason, made the adjustment process very complex, (special tools, micrometers, 64 sizes of shims to choose from, etc.).
It's a very dependable and long lasting design. Thats why Nissan put it in the VQ.
fwd gone rwd cr00
just changed the oil, and installed a new oil pressure gauge, about 13psi at idle, and 70psi at 3k rpms. I added STP oil stabilizer, and I still have the SAME TICKING. ANYONE have this same problem?
If you have a compression tester handy I would use that to see if there is any signs of low compression in one of your cylinders. You might want to also use a s***hescope to help pinpoint where it may be coming from.
Originally Posted by tavarish
oh well, i guess i gotta get a new engine.
fwd gone rwd cr00
Originally Posted by crazy97
Mine does have a lite tick, just loud enough so I hear it at idle but the engine seems ok. My tick sounds like its coming from the timing chain. I'm running some AutoRX to see if anything happens. I would say just keep driving it.
VQ35's going in soon. Anyone need a spare VQ?
shilov
02-19-2024 09:40 PM
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
