Changed rear struts, wheel cylinders..
Well as the title says, a friend and I changed the rear struts, wheel cylinders,shoes, and brake lines from cylinders to main line. Took us 12 hours including a few lunch breaks...mmm White Castle 30 cheeseburger Crave Case..anyway, what consumed the most time was running to my job to buy some tools we SHOULD have had and finding a certain tool to remove the cover to remove the cartrige from the assembly, we ended up buying a 14" monkey wrench and pounding on the top. As for the brakelines we had to bend em the way the original ones were, wasnt as bad as I thought it would be. The second MOST time consuming thing was the damn KYB strut boots, holy sh*t were those a pain to slide on. Well whether it took 2 hours or 12, I still think it was worth the damn time, my car no longer feels like a boat bobbing back and forth in the ocean
Is there a specific tool to remove that top piece of the strut assembly that holds the cartrige in place? cuz we asked people and everyone said there was no tool in specific for that.
as you saw, the strut nut (or whatever the name is) is just a big hex nut. i also used a monkey wrench on mine rather than try to find a giant open end wrench. as for the boot problems, i put kyb on my car and didn't have any problems with them. maybe you just needed to put some lube on it instead of doing it dry.
i haven't had a white castle since i moved away from 63rd & cicero many, many moons ago.
I did apply lube to the boot and it was still hard, the process we used to slide the boot on was for me to get the monkey wrench on the closed side holding the lil tube up while my friend pushed down with the boot, took us about 15 minutes each boot.
As for the oil in it..what oil lol? All I know is that when I took the old cartriges out, it squirted diarrhea look-a-like fluid..but I didnt put any oil in there that I know of.
Yes I did use a long tube, in fact I have 3 different size tubes for when I work on my car, I have the standard house plumbing pipe which is a 3/4 copper that is about 14 inches long and is reinforced with soldered pipe joints on 2 spots lol, my next tube comes off my jack which is longer and stronger, then the 3rd one came from a fence we used to have outside but dug it out, thats the one we used mainly for this job since my air compressor went out in the middle of the job so no more impact gun for us lol
63 & Cicero..dude you lived kinda far south didnt you? lol Was that Cicero?
Hey john glad you finaly got it done. sounds like you did it right with new brake lines and crap. Feels good to have all brand new parts and knowing you did it right doesnt it? I just finished putting all new pads on my grandpas caddie and it needed it in the back.
Did you check the shape of the fuel lines next to the brake lines? I know some times the brake and fuel lines get all corroded from getting salt and other corrosive garbage trapped in the plastic guard.
~Alex
~Alex
Well, I guess I didnt put any oil in there..dont know if I was supposed to, perhaps someone on here will know.
Alex, no I didnt check the fuel lines but I can only guess how they are right now..oh man I dont even wanna know.
On another note related to suspension, looks like I'm gonna have to change both control arms. Yesterday I went to carX to get a free estimate because my car has been "clicking" when I go forward and stop then reverse and stop..they lifted the car up and shook the front wheels and they werent exactly incredibly firm. They told me that it was the control arm..I asked if it was just bushings/ball joints and they said it was the whole thing, not sure why but does this make sense?
Sounds like wheel bearings...
When you install rear strut cartridges your supposed to use some of the old oil to fill the cartridge up about 3/4 way (when the strut is in the cartridge), so that it can disperse the heat. If they fail in the future you'll know why. After the oil, then reuse the rubber o-ring, to prevent the oil from splashing up to the piston.
Yea thats what I been thinking about getting, Energy Suspension Poly bushings but they will run me a good 30-40 bucks for the front set and right now I'm a little broke, now 20 bucks more and I can get the entire control arm from Brian with bushing and ball joint. Alex do you know how to change control arm?
Its not that hard you just unbolt two big (19mm I think) nuts holding up the control arm and.....wait dont you have an FSM Its not that bad of a job at all.
Are you talking $20 more then the ES bushings for one control arm or both? Id rather keep the old ones as long as they are fine and get even stiffer then new bushings. But hey waste your money as you see fit
~Alex
~Alex
As Vans did before:
Donate to "Save a Colombians Life" fund by donating straight from your heart to his paypal, it will save him and his car's life. There is no minimum amount required to donate, just donate what your heart tells you to donate. Paypal is Mr_Alvarez86@comcast.net
btw, I'm just kidding but if you guys are feeling generous, no one is holding you back :P
hi i have a question, i took my kyb cartridges and eibach springs to the shop, and needed to install them for the rear. i was wonderin if you look inside where the rear wheels are, are you suppose to see the shocks? or does something cover over the shock. because the kyb cartridges are silver, and when i look inside the wheel, all i see is black and so im not sure if the shop is trying to **** me over and installed different ones, or does something cover over the shock, other then that i see the eibach pro springs. please message me asap. or IM me on aim: stwodahorty. thanks
Originally Posted by Pervis Anathema
Yes there is but I doubt that you can find it. AFAIK, it was a dealer only tool. .
Originally Posted by Maxpwer
Thats what she said!!
haha my gf wont even let me get near her whether I got lube or not!
hey Maxpwer, where in Chicago are you located? I've never seen you around
MaxStock
08-14-2015 09:59 PM
MaxStock
08-08-2015 01:18 AM
laparka66
08-06-2015 09:36 AM
