Wideband o2 decisions, decisions, decisions
Old 03-23-2006, 06:38 PM
Need A Light?
steven88's Avatar
2k2 6spd Nissan Max...standard bolt ons and Apex-i VAFCII piggyback unit..
So now I'm in the market for a WBo2 sensor...I'm not interested in an external gauge becuz I don't like light shows....I'm more interested in datalogging with the laptop...so far I see PLX R300, Innovate LM-1, Zeitronix ZT-2...and a few others I prob forgot....
Zeitronix ZT-2 seems to be a cheap and effective route....it has datalogging features and RPM...thats my main concern right there....able to datalog AFR per RPM...
Also, how hard is it to install one of these babies? I already have 2 spare bungs in my test pipe...how about the RPM wire? do I just hook it up to my tachometer wire? any further detailed explaination would be greatly appreciated!
steven88 is offline
Old 03-23-2006, 07:45 PM
The Definitive AE Master
Larrio's Avatar
Installation isn't hard if you know which wires to tap. I had a harder time routing the harness from the exhaust through the firewall into the car. I had to take out the glove box assembly to get more access.
The ZT-2 installation instructions will tell you which wires you need to tap. IIRC, a 12V source and tach. The wideband o2 just fits directly in your standard o2 bung
Larrio is offline
Old 03-23-2006, 08:22 PM
Need A Light?
steven88's Avatar
Larrio, which wire did you hook up the 12v and tach too? on the ecu or somewhere else?
and how is the zt-2 treating you btw?
steven88 is offline
Old 03-23-2006, 08:48 PM
Kevlo for President
Kevlo911's Avatar
Does it data log?
I want one that data logs so I can tune better.
Kevlo911 is offline
Old 03-23-2006, 08:49 PM
Need A Light?
steven88's Avatar
also, would a 2nd gear pull be okay for tuning? i'm tryin to shoot for mid-range power too...and doing 3rd and 4th gear pulls on the freeway are kinda dangerous since I'm going real fast....and 3rd gear at 65 is above 4k...kinda steep
I'm looking to do maybe a 2nd gear punch at 1500
steven88 is offline
Old 03-23-2006, 08:50 PM
Need A Light?
steven88's Avatar
Originally Posted by Kevlo911
Does it data log?
yeah the zeitronix does datalog...
steven88 is offline
Old 03-24-2006, 01:41 AM
Turbo is too much fun!
jcy98maxse's Avatar
pull tach and power from safc. since you have them tap from the ecu already, its simple to tap into those wires( easier to get to). I would say tune in 3rd or 4th to get the best performace. Second gear is too short and when i pull datalogg in second they can be inconsistent at times. Also in 2nd gear you may not see full power like you would in 3rd and 4th so tune let like to would on a dyno.
I tune in 3rd on the freeway in the late night so cars are at the minimal, I dont want to tune in 4th for the same reason that top of 4th its like 130ish for me where as 3rd is still around 100mph.
http://www.zeitronix.com/Products/zt2/zt2.htm
download the datalogger from their site. Its fairly simple and user friendly. IMO its the best wb02 for the buck. you dont even need to buy the display which puts you only at $279
jcy98maxse is offline
Old 03-24-2006, 06:21 AM
Kevlo for President
Kevlo911's Avatar
Nice, I might have to buy it soon. The SMT has wideband input so that will make it easy for me to keep the AF nice and flat.
Kevlo911 is offline
Old 03-24-2006, 06:42 AM
MDeezy's Avatar
I've been poking around thinking about the zt-2. I have a laptop on the way, and looking to data log my stock 3.0 while its still in there.
From what I've seen the price for zt-2 seems to be the best bang for buck
Have you ordered yours yet Steve88?
MDeezy is offline
Old 03-24-2006, 07:18 AM
Larrio's Avatar
I remember now.... you need power, ground, and tach signal. Since you already have these tapped for the S-AFC, just tap into those wires as previously mentioned to make life easier.
The unit has been real neat, my only complaint is the LCD display screen is too large. But I plan to modify it somewhat into a smaller unit.
A 2nd gear pull would be too short and there isn't as much load on the engine vs. 3rd or 4th gear (each higher gear will have a slightly higher A/F... on my car at least). You'll have to find a empty highway late at night. I go on the 71 freeway around 1-2 am. There is a stretch of nothing before the 91 about 2-3 miles long. I do 3rd gear, 2500-7100 rpm (tops out around 110 mph)
Larrio is offline
Old 03-24-2006, 09:03 AM
speed racer's Avatar
I was looking into the zeitronix awhile back. I think I saw something about being able to download via. palm pilot. Does anyone know about this? If you don't have an o2 bung how hard would it be to get a shop to do it?
speed racer is offline
Old 03-24-2006, 09:11 AM
LSSexhaust(budget) sells a bunged test pipe for ~ 40$.
Ever heard of FJO wb o2's??
NmexMAX is offline
Old 03-24-2006, 10:20 AM
3.5 in the works
DandyMax's Avatar
Jime has had/still has an FJO IIRC. I don't think he had any problems with it but you'd have to ask him.
DandyMax is offline
Old 03-24-2006, 10:26 AM
It has the data logging a/f vs rpm, trottle opening
It's a good item, I recommend it
NmexMAX is offline
Old 03-24-2006, 10:53 AM
Need A Light?
steven88's Avatar
Naw I haven't...but I'm thinking of going for the ZT-2 in the end...it seems very effective
steven88 is offline
Old 03-24-2006, 10:58 AM
Need A Light?
steven88's Avatar
Alright 12v and tach from the AFCII it is! but quick question...do I tap it in from the AFCII wire side, or the ECU wire side?
Larrio - hwy 71 near the 91 is a good spot? I'll have to check it out sometime....isn't that a toll road though? Or is that the 73...
steven88 is offline
Old 03-24-2006, 11:13 AM
Larrio's Avatar
IMO, the less wires around the ECU the better.
The 73 is a toll road and has speed traps. The 71 becomes a 1-2 lane highway right before it merges with the 91 freeway. Its quite desolate out there. I usually make a few passes at normal speed to scope things out before going ***** out. Recommended to bring a radar detector just in case
Larrio is offline
Old 03-24-2006, 11:19 AM
Need A Light?
steven88's Avatar
Does this mean I draw power from the AFC wires, and not the ECU wires itself again?
steven88 is offline
Old 03-24-2006, 12:07 PM
jcy98maxse's Avatar
in reality you are drawing power from the ecu since you're safc is drawing from the ecu wires. The power source is ecu wires but you're just getting it further down the line if you know what I mean. you can tap right before or after the safc connection plug (where you can disconnect the display from the wires). since the safc wires are cover by a black plastic loom, just cut before the connector(the loom to give you more room) and tap in from there. Tap red for power, tach is green and tps is gray. you'll need tps too for dattalogging.
Old 03-24-2006, 12:38 PM
aznsap's Avatar
is it okay to use the wideband 02 just after the cat? like in the very beginning part of the b pipe?
aznsap is offline
Old 03-24-2006, 12:41 PM
Need A Light?
steven88's Avatar
I'm going to need TPS? I thought tach was all that I need...I just needa know what RPM my AFR is going to be, thats all
steven88 is offline
Old 03-24-2006, 12:53 PM
Larrio's Avatar
TPS is displayed on the LCD unit. I'm not sure if its needed if you are only going to buy the wb02 by itself.
Larrio is offline
Old 03-24-2006, 12:56 PM
Need A Light?
steven88's Avatar
Yeah I'm just buying the WB02 itself and using my sisters laptop to datalog...I already have a VAFCII as my primary gauge ....no need to buy more gauges!
steven88 is offline
Old 03-24-2006, 12:57 PM
jcy98maxse's Avatar
u can read the TPS on the laptop too. nothing extra to buy but you dont need to hook it up fi u dont need to. Also i believe you can hook up the MAF votage to be monitored as the unout user function. Its +5v compatible.
Old 03-24-2006, 01:21 PM
3.5 in the works
DandyMax's Avatar
That is correct.
DandyMax is offline
Old 03-24-2006, 02:00 PM
Larrio's Avatar
Hmm, interesting... I didnt' know about this
Larrio is offline
Old 03-26-2006, 02:12 PM
nismology's Avatar
The SMT6/EU is compatible with WB02's that have a linear 0V-5V output signal. The Zeitronix unit doesn't.
nismology is offline
Robert Schneeweis
01-11-2017 06:47 PM
BkGreen97
04-02-2016 05:47 AM
lrb6805
17
09-30-2015 08:12 AM
Slamrod
09-03-2015 07:38 PM
FlaMark
25
08-28-2015 10:15 AM
Quick Reply: Wideband o2 decisions, decisions, decisions
