Indiglo Gauges
Old 02-13-2006, 01:20 PM
tauLiFE45's Avatar
Indiglo Gauges
Recently my indiglo gauges keeps on flickering by itself. The color changes, lights going from full brightness to no lighting all by itself. Basically it seems like the controller is doing it by itself. Now i have the positive wire hooked up to the heated seat fuse and the negative is secured on a metal bracket under the steering wheel. Did I install it wrong? Any suggestion to where I should hook up the positive wire to have it light up only when the headlight is on? Any advice will help.
tauLiFE45 is offline
Old 02-13-2006, 01:28 PM
What's next!?..
JPMax's Avatar
I spliced the power line into the line going into the illumination control switch to the right of the steering wheel. Connected a small ring terminal to the ground wire and put it under the screw in back of the gauge cluster labeled GND.
JPMax is offline
Old 02-14-2006, 12:35 AM
MidniteMaxSE's Avatar
How long have you had them??...the ones on my old car were flickering and i needed a new inverter...12 bucks on ebay...
MidniteMaxSE is offline
Old 02-14-2006, 06:22 AM
§è~® f®ÈÄk
nismos14's Avatar
I think inverter as well. Probably not the wiring. DOuble check wiring and if it looks ok replce inverter.
nismos14 is offline
Old 02-14-2006, 06:37 AM
tauLiFE45's Avatar
I've had them on for less than 6 month. Which part is the inverter?
Old 02-14-2006, 04:52 PM
5th Gen till she dies!
ManualMaxima's Avatar
the inverter is the little box looking thing that you plus all the guages into, i guess it send a constant supplyof power to the guages....it usually makes the little hummnig noise...
ManualMaxima is offline
Miket2006
03-01-2021 03:55 AM
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
kadespraggins
09-14-2015 12:04 AM
NissanNismoZ
09-12-2015 07:30 AM
Quick Reply: Indiglo Gauges
