Hood Struts mod
Old 12-10-2005, 07:46 AM
Dougn's Avatar
Hood Struts mod
The gas filled hood struts in my car is shot. I was working on the engine the other day and lucky for me when I turned around to get some tool I hear a loud slam noise when the hood dropped. I could get hurt from it. I want (/need) to replace the struts only to find out Courstesy Nissan carries them for $180.00 each. That is a bit much for my 91 max. I am sure I could get a better price at a local AutoZone but how long would those last me. My other cars just have a simple rod operated by hand that swing up to hold up the hood. I wonder if any one has made or swap from hood struts to the metal rod and if that would work. Thanks.
Dougn is offline
Old 12-10-2005, 08:57 AM
Josh's Avatar
Internetautomart sells them for $40 a pair. i'd say go there....or just stick an icescraper under the hood :<--ghetto:
http://internetautomart.com/maxima/3rdgen.html
Josh is offline
Old 12-10-2005, 10:11 AM
Dougn's Avatar
My first option is looking for a rod operated by hand from another car model from the junkyard. DI do not know which one will fit yet. My last resort will be oder another set of replacement hood struts. You are right. Icescraper or better yet a 2x4 piece of wood is pretty safe but it does look ghetto and if I ever take my car to a mechanic he will not use the 2x4 and hurt himself.
Dougn is offline
Old 12-10-2005, 10:24 AM
99grnmaxgxe's Avatar
Lol, same thing happened to me just this morning, good thing it fell slowly or I would've have a big headache.
99grnmaxgxe is offline
Old 12-10-2005, 12:34 PM
Way out West
Cliff Clavin's Avatar
Mine are starting to get weak. Maybe after the holidays I will put an order in with Internetautomart.
Cliff Clavin is offline
Old 12-10-2005, 01:31 PM
Apple Pie Monster
wolfpack_5150's Avatar
another ghetto mod is a set of small vice grips. Lift hood up, clamp
vice grips to the piston/ inner rod at the base of the cylinder/outer rod. It works in a pinch and will save u a headache or better.Trust me I was changing oil at walmart and was working on a Sebring I think. I couldnt get the filter from lower bay so I went up top, laid down next to the car and put 1 hand on filter w/rag and other hand on the frnt 1/4 panel for leverage. (car had been in the shop hood raised for a few minutes already. Next I know the hood slammed shut on my entire hand, all the way down till it latched closed.
I got lucky, it hurt but hand still works. Worst part was I just had stitches in that hand less than a year ago so the tissue was still (hypersensitive) so they call it.
wolfpack_5150 is offline
Old 12-10-2005, 02:15 PM
goon9's Avatar
[QUOTE=wolfpack_5150]another ghetto mod is a set of small vice grips.
...if only they made black powder coated vise grips....
OH yeah! I was stripping my parts car last year with craig brace. The frikn hood knocked me out for a second.
goon9 is offline
Old 12-10-2005, 03:08 PM
Cyclothymia's Avatar
Yeah Mine are SHOT too but I have to keep it in perspective and wait till i get the body work done... then i will totaly be in the market for some
Cyclothymia is offline
Old 12-10-2005, 03:21 PM
Dj Paul's Avatar
i keep a little metal pole under my hood back by my brake booster (passenger side against firewall) and just prop it up under there, who cares im not paying even 80 bucks when i could just use a pole. lol
Dj Paul is offline
Old 12-10-2005, 03:23 PM
vansskaterfreek's Avatar
vansskaterfreek is offline
Old 12-10-2005, 04:25 PM
Dougn's Avatar
vansskaterfreek. That is exactly the location and how I used my 2x4 to hold up the hood the ghetto way. As I said before, I do not want any poor mechanic get hurt when I drop the car off for some repair in the future. Also it could be one of my younger relatives who likes to tinkle under the hood.
Dougn is offline
Old 12-10-2005, 04:46 PM
¯\(°_o)/¯
Greeny's Avatar
Here is my redneck hood prop...
Greeny is offline
Old 12-10-2005, 05:06 PM
mod or sell?
internetautomar's Avatar
mine started burbling and oozing on friday
oh well, I have a good set still from my old max
internetautomar is offline
Old 12-10-2005, 05:56 PM
Josh's Avatar
hood struts we dont need no stinking hood struts.
Josh is offline
Old 12-10-2005, 06:05 PM
DennisMik's Avatar
all the cars i've had that use the gas struts have the same problem. i carry a broom stick in my trunk and put it down behind the radiator and rest it on the cross member. i don't worry about mechanics because mine are so worn out that the hood won't stay up at all. but i am tired of the broom stick and just ordered struts from internetautomart.
i have a 97 max and the struts are shot on that car also. i can't do the broomstick the same way because it doesn't have a crossmember like the 3rd gen.
DennisMik is offline
Old 12-10-2005, 06:22 PM
mtbendo's Avatar
The first time mine fell was when I was changing rotors. The distributor cap plastic cover was sitting on the intake when the hood fell. Now I have a small pimple on my hood and a cracked cover... I finally replaced the struts for about $35 or so each, that was several years ago and they are still holding up.
mtbendo is offline
Old 12-11-2005, 02:09 PM
gapboi210's Avatar
Hmm well since we are adding ghetto things to the list, I have a hockey stick in the trunk....works well and the girls dig hockey players LOL.
gapboi210 is offline
Old 12-11-2005, 03:53 PM
Mattster's Avatar
You could have kept my lovely log I left in there for yah. lol!
Mattster is offline
Old 12-11-2005, 06:08 PM
Suprise butsechs!!!
Dillbag's Avatar
what about $20 autozone replacement hood shocks? anybody tried those?
Dillbag is offline
Old 12-11-2005, 06:33 PM
autoblown probably has remanufactured ones (like everything else) and probably have a lifetime warrenty,,, but if they fall on your head... sue them!!! lol
Old 12-11-2005, 06:47 PM
Get Off My Lawn
Chris Gregg's Avatar
I have used a thin fiberglass rod I found. Sanded and painted a nice blue. Fits reall good into corner hood hole underneath front lip of hood. Bottom rests nicely against headlight bracket. Subsequently removed my hood struts. Made hood heavy as can be. Never realized how heavy the hood is without even the BAD struts!
Chris Gregg is offline
Old 12-11-2005, 07:05 PM
Suprise butsechs!!!
Dillbag's Avatar
maybe get a carbon fiber hood from fiber images...lol
Dillbag is offline
Old 12-11-2005, 07:40 PM
maxitech's Avatar
Mine still work...kind of. Whoever had the car before me bent both hood struts so when you raise it all the way you have to push past some friction and when you let go it falls about an inch but the friction keeps it proped up.
maxitech is offline
Old 12-11-2005, 08:42 PM
I miss my VE
VEvolution's Avatar
It probably depands on where you live and how cold/hot it gets, but whats the average life expectancy on these things till time of replacment? I've bought two 3rd gens so far, and on both within 3-4 months, the hood struts started to fail. They work pretty poorly I noticed in cold conditions.
VEvolution is offline
Old 12-11-2005, 10:37 PM
mtcookson's Avatar
I made my own prop using a metal rod and the swivel piece that the struts use:
Higher res:
http://www.machzracing.com/pictures/hoodprop1.jpg
http://www.machzracing.com/pictures/hoodprop2.jpg
mtcookson is offline
Old 12-11-2005, 10:43 PM
MrGone's Avatar
working hood strut crew signing in
MrGone is offline
Old 12-12-2005, 07:43 AM
Dougn's Avatar
mtcookson. That's what im looking for an idea like that. One question those. It seems like your hood is raised a bit hight (would it flip over to the top of the car?) I might mod my to something like that but with a shorter rod. Any way, I still looking a another place since it looks like a chalenge when one opens and lifts the hood and reachs over way back there to flip the rod stand. For a short guy with short arms it will be difficult. I am sure Shaq would not have any problem if he get this ghetto mod.
Dougn is offline
Old 12-12-2005, 08:05 AM
95turbo gxe's Avatar
Higher res:
yeah mark im going to do the same as it makes it abit more easy to get to things. Mark By the way what is that big pipe underthe hood of your car and just what does it do. I dont think it suppose to be thier.
95turbo gxe is offline
Old 12-12-2005, 10:20 AM
mtcookson's Avatar
I set it up that way so that the hood would stand up like that. It allows for much more room to work in the back of the engine bay. I'm only about 5'9" and have no problem getting it into place. Usually I'll just lift it from the side and set the prop.
So far, I've not had any trouble with it coming out and the hood going further, even on windy days.
That's the red neck turbo intake pipe right thar. It'll look much better once I get the aftercooler put on (not to mention flow a hell of a lot better)... not sure when that'll happen though.
Old 12-12-2005, 10:51 AM
bhunter's Avatar
[QUOTE=mtcookson]I made my own prop using a metal rod and the swivel piece that the struts use:
This one is the only someone can call a "mod" An oar or a broomstick is not a mod----it's being a cheapskate.
bhunter is offline
Old 12-12-2005, 12:13 PM
Lives in a Maxima
Phoenix's Avatar
For those who have replaced your hood struts (or have working ones), can you experiment a little and see if they will support the weight of your hood plus a cat?
At first mine would support the hood, but not the hood + cat. Now they don't even support the hood. If your good struts can support a cat on the hood, I'll get some. If not, i guess I go mod.
Phoenix is offline
Old 12-12-2005, 12:58 PM
mod or sell?
WTF???
a cat?
dude get a dog, problem solved
Old 12-12-2005, 03:42 PM
Josh's Avatar
Dude your cat should most def be under the car.
Josh is offline
Old 12-12-2005, 04:34 PM
maxima94ever's Avatar
hood gadget
or u can take a piece of pvc tubing 3/4" make a slot from one end to the other an insert on strut, it does the job for me its about 3" long.
maxima94ever is offline
Old 12-12-2005, 04:55 PM
maxitech's Avatar
That's the first good solution I've heard so far, other than mine, of course.
maxitech is offline
Old 12-12-2005, 05:11 PM
Dougn's Avatar
Let call is 3x3/4 PVC pipe solution. I would try to make one and try it out but it's 30 minutes from Monday's night football so that will have to wait.
Dougn is offline
Old 12-12-2005, 05:24 PM
mod or sell?
I'll stick to using a monopod
Old 12-12-2005, 05:28 PM
maxitech's Avatar
Good call...headed out to watch it and drink beer right now...over and out.
maxitech is offline
Old 12-12-2005, 10:11 PM
Tampa93MaxSE's Avatar
I got cheap ones at autozone or pep boys can't remember and they have been working fine for years now, it was less than $40.
Tampa93MaxSE is offline
Old 12-13-2005, 04:18 AM
mod or sell?
I sell em for $50 the pair shipped
Quick Reply: Hood Struts mod
