Virbration in whole car
Wen I drive from about 58mph and above, the car shakes, likes its out of alignment. The car was hit in the front before I bought it. Is it possilbe that it is just out of alignment, becuase my stearing is farily tight, or is it from the accident and is unfixiable unless I wanna spend big buxs?
-Dex
Has the car recently started vibrating or has it been doing it since you've purchased it?
Vibrations could be:
Wheels need balancing
certain suspension parts worn out.
alignment out of spec.
examine your suspension and try to narrow it down, check for too much play in axle, check ball joint, look at bushings etc. . .
definately from the accident, my max was bought after an accident, it also shook, turns out the engine mount's frame was completely destroyed... had to have it welded, might not be the same issue with u, so unless u got a car lift, take it to a shop.
I checked the ball joints there good, and its does it like i said at 58mph and above, i havent checked the motor mounts or anything like that, but im gonna get it algined and balanced first. Any other things it could be? The car only has 57k by the way.
Originally Posted by kormax97
....balance the wheels first. It might save you the money and trouble of getting an alignment.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
altome15
08-10-2015 07:05 PM
