Re: Transmission filter change
Old 10-19-2005, 02:45 PM
jay23's Avatar
Hello guys do you have any links in how to change my Automatic transmission filter. I have a 2002 Se.
jay23 is offline
Old 10-19-2005, 02:51 PM
A33 VQ30DEK's Avatar
Drain the pan, drop the pan, there should be bolts holding it up. Replace filter and clean magnets. Replace the Pan Gastket and bolt back up and you're done!
A33 VQ30DEK is offline
Old 10-19-2005, 02:54 PM
jay23's Avatar
Thanks A33 Now, do you think that i would notice any changes to my old and new filter? Recently, my transmission has been acting up. The tranny when shifted to R would not go to reverse unless you hit the gas till it goes about 4500rpm to about 5000 + rpms.
jay23 is offline
Old 10-19-2005, 03:37 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
Might as well erplaced your fluid with some Redline MT90 while you're in there. Someone on here has a KICK *** write up, I forget who...
Metal Maxima is offline
Old 10-19-2005, 03:40 PM
+Cru OG
NisMoN00B's Avatar
if you have to rev the motor to get it in gear, transmission oil might not solve the problem. you probably have stripped transmission gears if you have to rev that up high to get it to engage. i'm not sure if i'm entirely correct on this matter, though.
on the other hand, changing the oils and filters for the transmission you'll notice smoother gear engagement.
NisMoN00B is offline
Old 10-19-2005, 03:48 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
follow my sig.. have fun doing it.....
Lontar1 is offline
sctludwig
09-01-2022 01:32 PM
aminus21
09-12-2015 04:53 PM
pjgreek
09-09-2015 09:30 PM
Maxboy23
09-04-2015 06:04 PM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: Re: Transmission filter change
