Wheels/tires Sticky? G35 wheels on maximas
Old 08-10-2005, 07:29 PM
retired moderator
irish44j's Avatar
There always seem to be alot of questions about G35 wheels fitting on maximas, and "how they look." Thought it would be good to have a sticky on the subject, since it comes up many times each week, and include pics of various maximas with these wheels. This would save alot of re-post threads on the subject. So, to start it, here's what I know:
Facts:
The lug pattern for all G35 wheels is correct for maximas. All G wheels have a correct offset to fit 4th through 6th gen maximas (not sure about 1-3G), though they will sit more flush with the wheel wells than the stock wheels.
The 7-spoke G35 Coupe 18" wheel is 18x8 with a 30mm offset
The 6-spoke G35 Coupe 17" wheel is 17x7.5 30mm offset (front) and 18x8 33mm offset (rear)
The 6-spoke G35 Sedan 17" wheel is 17x7 with a 40mm offset
The 5-spoke G35 Sedan ('04) wheel is 17x7 with a 40mm offset
The G35 Coupe 19" Rays wheel is 19x8 with a 30mm offest (front) and 19x8.5 with 33mm offset (rear)
Other notes:
-There are replica G35 18's on ebay and other wheel shops. They are usually sold with a yellow Nissan or Infiniti center cap, and are 18x7.5" with 30mm offset (slightly narrower than the real ones)
-The center caps from most Altimas and 00-01 Maxima GXE wheels will fit on the G35 wheels.
-The 18x8 G35 wheels weigh about 24 lbs
-The 17x8/7.5 wheels weigh about 25 lbs
-If you buy the G35 18's or 19's used, they may come with the automatic tire pressure sensor attached. You CANNOT use this, and probably should replace it with a conventional valve stem
-The 19's on the new G35 coupe are made by Ray's. They are much lighter than the other stockers, and MUCH more expensive ($2000+ on ebay)
-The 19's come with 225/40/19 tires (front) and 245/40/19 tires (rear)....if you use the stock tires, there is a good chance the rears will rub because of the relative high aspect ratio.
-You can find used G35 wheels for pretty cheap on www.g35driver.com and www.g35frenzy.com
irish44j is offline
Old 08-10-2005, 07:31 PM
retired moderator
irish44j's Avatar
Now, some photos (more on my homepage)
The G35 18x8:
The G35 Coupe 17x8/7.5:
The center cap fits (these are from a 2000 GXE Maxima)
irish44j is offline
Old 08-17-2005, 01:26 PM
tripleGmax's Avatar
here is my gallery of pictures
http://gregg-henry.com/gallery/g35-18s
my favorite part is how the 30mm offset with the 8inch wide wheel is flush on the 3rd gen!!
a 235 tire was too wide for the back for me since im 1.7 inches lowered. so i bent up the inside lip of the wheel well of the car. a 225 tire id bet wouldnt rub if youre as low as me. i also think a 235 wouldnt rub if youre running eibachs 1. inch drop..... no rubbing in front for me unless i hit a crazy big bump while turning very hard(which i did once).
i love the overall look of the rim and it doesnt matter what gen its on it looks great. Irish was the one who inspired me to get mine.
tripleGmax is offline
Old 08-17-2005, 01:42 PM
I'm needing a caw
Jeff92se's Avatar
The G35 18" wheels also clear most if not all big brake kit calipers including the 13" Cobra rotor/300z caliper kit I use and sell parts for.
And another pic of a 3-gen with G wheels
Jeff92se is offline
Old 08-23-2005, 10:29 AM
大陆弟弟
n3985's Avatar
Sorry to bump an "old" thread, but do the eBay replica G35 coupe wheels look narrow in the wheelwells of a 5gen? I mean does the OEM 8.5" sit flush on a 5gen?
n3985 is offline
Old 08-23-2005, 10:33 AM
tripleGmax's Avatar
ebay replicas are 7.5 inches wide. stock g35c's are 8 inch wide not 8.5
use the wheel offset calculator in the wheels/tires section and input the 8inch for current width 30 for current offset and the knockoffs as the second set of #s
Old 08-23-2005, 10:34 AM
I'm needing a caw
Jeff92se's Avatar
Um what? Ebay CHEAP ARSED COPIES OF WHATEVER QUALITY are 7.5" wide. OEM G35 18" coupe wheels as shown above are 8" wide. Where is 8.5" ever mentioned? As far as looks, there are pics on the 1st post.
Jeff92se is offline
Old 08-23-2005, 12:55 PM
Tuna's Avatar
i know this thread is about the G35 wheels but i have seen some threads asking about the 18" 6th gen SE's so heres a pic of them on my car..
Before Drop
After Drop
they fit perfectly in the rear, however there is a slight rubbing issue when the front wheels are turned all the way but its nothing major.. i dont know the exact specs on these however i do know they came with the Goodyear RSA's 245/45/18.. also, im not sure how heavy the G35 wheels are, but these things are like cement boots so an upgrade on rotors, brake pads, and ss lines is recommended.. there are a few more pics on my cardomain site..
-TUNA
EDIT: sorry bruh, i thought i was posting useful info in a sticky rather than having people come up with same threads over and over again..
Tuna is offline
Old 08-23-2005, 01:27 PM
tripleGmax's Avatar
perfect fit and slight rubbing dont go together.
why wouldnt you go to those threads and post your pics rather than here?
Old 08-23-2005, 02:06 PM
retired moderator
irish44j's Avatar
that's why this thread is a sticky, so it's always bumped...
don't know what you mean by narrow....does this look narrow to you?
irish44j is offline
Old 08-23-2005, 03:00 PM
大陆弟弟
n3985's Avatar
Ok my bad, I meant 8" OEM wheel. I couldn't think of the word so I used naoorw, what I meant was that the wheel is tucked in and not flush with the fender. But I guess the pic irish posted answers it all. And to the 2 peeps who posted regarding my first post, read my question first. I asked whether the 7.5" replicas will sit flush and whether the OEM did too or not, albeit maybe the wording was kind of weird.
n3985 is offline
Old 08-23-2005, 03:05 PM
I'm needing a caw
Jeff92se's Avatar
I don't recommend those cheap copies. I don't know how they will sit. But if the offests are the same, it will tuck in about 2.5" in further.
They sell wheels with some cheap arsed tires for over $800 + whatever shipping. I'm selling my REAL 8" versions for just about the same price. With Michelins that are $240 each new.
Jeff92se is offline
Old 08-26-2005, 05:53 PM
Champ2433's Avatar
Hey Irish, thanks for the write-up, its very informative. Do any of you know whether the 18" g35c centercaps are 50 or 58mm's? I know you say which years will work but the guy from eBay is unaware of which is for a 00-01 altima. 50mm would be 2" and 58 would be 2 5/16" in diameter. I do not yet have the rims so I cant measure myself or I would just measure myself.
Champ2433 is offline
Old 08-26-2005, 08:19 PM
retired moderator
irish44j's Avatar
Originally Posted by Dooley
What are the offsets of the following wheels:
1) Stock '97 Max SE 16" x 7
2) Stock '03 G35s 17" x 7
I need to know if spacers are needed to get the look I want. Thanks!
the G35 sedan 17's are a 40 offset, I believe. No idea about the 16's
irish44j is offline
Old 08-26-2005, 08:26 PM
retired moderator
irish44j's Avatar
my measurements show 55mm outside lip diameter and about 50mm inside lip diameter....but I used a tape measure, so it's not too precise. The center caps I used were from a 2000 GXE maxima, which also fits.
irish44j is offline
Old 08-27-2005, 03:23 PM
Champ2433's Avatar
Irish, Appreciate the help man. I found some that where for a 2000 GXE max, so I should be all set.
Old 09-01-2005, 09:18 AM
Dooley's Avatar
I too am looking for a set of 2000 GXE center caps. Suggestions?
Dooley is offline
Old 09-07-2005, 05:46 PM
retired moderator
irish44j's Avatar
Upgrading from 5-spoke SE 16"s to G35 sedan wheels (17x7), what spacers would be recomended to push the wheels flush with fender cut on a 4th gen? What are other people running with this setup?
Thanks!
for a 4th gen, try them without spacers first. Since you don't have the wheel arch flared as much as a 5th gen it might look pretty good.... The offset is 40mm, but since they're 7" wide, they are (I think) wider than your stockers, which (I think) are 6.5"....
I would suggest you put them on and see how they look before you go and get spacers.....
irish44j is offline
Old 09-07-2005, 08:40 PM
retired moderator
irish44j's Avatar
I have what I believe G35 sedan wheels, they are 17 x 7.5 and 17 x 8 wheels. My questions are:
- What do I have to do to get these to look even on my 4th gen? Spacers?
- Is anyone else running G35 staggered 17's on a 4th gen? Pics?
- Anything else I should be considering?
Thanks!!!
no, what you have are the G35 coupe 17's, which are almost identical to the G35 sedan wheels in appearance. The only difference is the rim width and the offset. The G35 sedan does not have a staggered setup. The sedan wheels are more "flat" in the front, while the coupe wheels curve inward more...
I use these wheels for winter and autocrossing (and my 18's for regular driving). All 4 of mine have 225/45/17 tires on them for autocross, and in the winter they get 235/45/17 tires....
these are the G35 coupe 17" wheels that you have, on my car(the 18's lying on the ground next to them are the G35 coupe 18's):
irish44j is offline
Old 09-07-2005, 09:01 PM
Dooley's Avatar
So I can put the same tire size on the 17 x 8 and the 17 x 7.5? Won't that same tire sit differently on a wider rim? Currently they have 225 50 17 and 235 50 17 on them.
Dooley is offline
Old 09-08-2005, 02:06 PM
NISMAX03's Avatar
OEM G35 Coupe rims with 235/40/18 tires and S-Techs with Illuminas.....no rubbing and no wheel gap.
NISMAX03 is offline
Old 09-08-2005, 03:19 PM
retired moderator
irish44j's Avatar
yes, you can. That's how I have it on my autocross wheels, which are the 17x7.5 and 17x8s.... I would say to go with 235/45/17 to avoid any rubbing...
irish44j is offline
Old 09-08-2005, 11:06 PM
Dooley's Avatar
Anyone know the part# on the 2000 GXE cap? My 97 SE and Infiniti caps are not deep enough to lock, the part #'s are 40343/5P010 and 40342/AU510 respectively.
Thanks!
Dooley is offline
Old 09-09-2005, 11:43 AM
cutter's Avatar
Does anyone here have the new 19" coupe rim on a 5th gen? How about the new 350z track wheels? I am considering getting these also, I just want to see what they look like.
cutter is offline
Old 09-13-2005, 12:08 AM
rchun08's Avatar
rubbing issues
would 245/40/18 be ok with g35 coupe rims on a 2002 maxima se..would i have any rubbing issues
rchun08 is offline
Old 09-13-2005, 05:46 AM
elambert24's Avatar
What tire size would you guys suggest for 18" G35 Coupe wheels on a 97 Maxima stock springs? Also, if I had about a 2" drop (as I may be getting one in the future)?
elambert24 is offline
Old 09-13-2005, 06:01 AM
tripleGmax's Avatar
elambert, i think a 235/40/18 would be good. thats what im running.
dooley, did you just ask for a part number and then list it?
cutter, jeff92se has pics of his track editions on his car. someone on here has pics of the new 19s on his 4th or 5th gen, i forget which one. check members ride section.
rchun not sure, but you might have some rubbing dont quote me.
Old 09-13-2005, 05:10 PM
retired moderator
irish44j's Avatar
^^what he said
irish44j is offline
Old 09-19-2005, 10:39 AM
Dooley's Avatar
3G, I was listing part#'s of caps that did not work with my 4th gen and g35C 17" wheels.
Dooley is offline
Old 09-20-2005, 04:43 PM
SMOKEYMOUNTAIN's Avatar
I just recently bought 04 OEM G35 coupe 18 by 8's on my 98 GXE w/ an eibach pro-kit drop on illuminas. It really feels like my camber is off even after an alignment. Should I invest in a camber kit?
SMOKEYMOUNTAIN is offline
Old 09-30-2005, 07:10 PM
retired moderator
irish44j's Avatar
what do you mean it "feels" like your camber is off? A drop of less than 2.5 inches really should not need camber adjustment. It probably just feels different because of the offset of the wheels being farther out.
irish44j is offline
Old 10-08-2005, 10:14 PM
elambert24's Avatar
I love my G35 wheels, but wondered what is the best product for caring for them? A general wheel cleaner or is there better stuff out there? Thanks in advance.
Old 10-17-2005, 08:55 PM
replicant's Avatar
omg i'm so glad i searched the forum.. i was gonna ask about this. those g35 coupe rims are so hot! though, i just bought michelin pilots for my stock 17s at nissans recommended tire size; so i guess i'm stuck with getting the 17" g35 coupe wheels for now. can anyone share what they paid for their g35 wheels (specifically for the 17" variety)?
replicant is offline
Old 10-18-2005, 07:35 PM
retired moderator
irish44j's Avatar
It'll be a while before we see those, I'm sure.....unlike the 18's, which can be had for $500-700 used, the 19's on the new G are made by Rays so they are VERY $$$....The only set I saw on ebay was going for about $2500.00 - for that price you can get pretty much any set of high end rim you want, not stockers, even from a G....
irish44j is offline
Old 10-18-2005, 07:37 PM
retired moderator
irish44j's Avatar
As I recall, I paid about $4-500 for my 17's and a bit more for my 18's (both without tires). Check the G35 forum classified sections for the best deals on REAL ones, or get the knock-offs from ebay which are a bit heavier and probably not quite as strong....
irish44j is offline
Old 10-19-2005, 02:20 PM
cutter's Avatar
I just paid $520 with shipping for just the wheels. They are in perfect condition with no road rash or anything. Irish when I put these rims on is the gap going to be horrible or will it look fine? I just want to know because if it is going to look like crap I mine as well get some springs and struts and put them on when I put the wheels on.
cutter is offline
Old 10-20-2005, 06:46 AM
replicant's Avatar
cutter and irish, thanks for the info gents.
i've been on a rampage to find these wheels. i'm just so glad this thread was started. hopefully within the next couple of months i can find the 17" sized wheels.
thanks again.
Old 10-20-2005, 10:13 AM
cutter's Avatar
Go for the 18's I think they look a lot better on our cars. I see me and you have the same car and I would say go with the 18s. Keep your brand new tires and use the 17s for the winter or something, but definitely go with the 18s.
cutter is offline
Old 10-20-2005, 11:12 AM
tripleGmax's Avatar
my friend is trying to sell his 04 g35c 18s if you want....he will let them go cheap, and they are in great shape. pm me
Old 10-21-2005, 04:01 PM
tripleGmax's Avatar
if you get the right tires the gap should be the same.....
Quick Reply: Wheels/tires Sticky? G35 wheels on maximas
