battery and brake light on????????
any suggestions why my battery and brake light would be on? the alternator is good, battery is good as well as the fuse. the battery is holding a charge and the alternator is doing its job, its not overcharging. and i figure its not under charging because the battery is at 12v
if anyone has any knowledge on this subject please let me know, i've been rubbing my head for 2 days now.
thanx
thanx
thanx
thanx
My wife's maxima did the same thing last week Tuesday. She was able to drive it about 5 miles, then the car died. Brake and battery light is Nissan's way of saying you need a new alternator.
I replaced the alternator and all is fine now. Good idea to check your belts and also the tensioner at the same time when you replace the alternator.
If you're getting the brake and battery lights it means your car is receiving less than 12 volts. As mentioned above your alternator should be putting out more then 12 volts to keep everything charged. Sounds like time for a new alternator.
Originally Posted by bhmax16
Your battery should be around 13.5-14 volts with the car on. If it's only at 12v then your alternator is junk. And as for the brake light being on too, it's just how Nissan designed the electrical system.
tsi6001
10-03-2022 10:23 PM
JMag90
08-25-2015 09:17 AM
