transmission fluid leak. NEED HELP
Hi. Today I noticed that my transmission fluid is leaking. Front of my transmission is dry but top, buttom and back is wet. Fluid is spilled from lower control arm up to throtle body. Can anyone help me??
Usualy this problem is assosiated with bad differential side bearing(need tranny rebuild), possibly somthing else you need to post pics.
I am finishing the process of rebuilding my transmission. The total cost for parts came close to $250 (including special tools). If you have never rebuilt a tranny, i don't recommend doing this yourself. To check if your bearing has gone, get under the car and try to move the axle (by where it connects to the tranny) up and down. If there is significant play and fluid spills out, you're one of the many owners with this defect....congratulations, you need a tranny rebuild.
I would recommend a professional to do it for you. The quote that I got here in Connecticut was between $1200 and $1500...You may be able to pull/put the tranny in/out yourself...but opening it up and replacing the bearings/seals requires professional's skills. When you do get it fixed make sure they shim the bearings correctly REFER TO this website go to "my first 5 speed rebuild" on the bottom...it explains your situation throughly.
P.S. are you polish?
Do you know any junk yeard in chicago area??
Need help
23
10-02-2015 08:56 AM
Pied
09-26-2015 03:29 PM
