Is there anyway to get a new wheel well cover in the trunk?
I need a new one of those cardboard wheel well covers that goes in the trunk. the one i have is beat up and sinks in. any way to get a newer stronger one?
i was thinking that the particle board in there has been fine for almost 8 years or so and is now showing it's age. a fresh-cut replica of the OEM part i think would last long enough and i feel that plywood or some kind of wood would (haha, "wood would") be too heavy? is fiberboard different than particle board? is it strong and light?
i was thinking fiberglass also, but it might not be worth the price, and obviously not for CF unless you have a system to show off. if you put the carpet back in, it's not really worth having anything fancy in there, and fiberglass alone may be too slippery/things sliding around. depends, i guess.
Anyone thought of plexi glass? stereo shops should be able to get hold of the stuff, and it wont break down like particle board. I plan on eventually cutting out the wheel well and weld in a "tray" of sorts for an amp or two with a plexi top, I know plexi is usually showy but like i said its light and strong.
i would only use plexi if i were going to shove some amps or something in the wheel well for show, but i just need something to support the subs. i think ill pick up some of that plywood from home depot or something. thanks guys!
rbaker100
09-06-2015 02:46 PM
