KS troubles..........and I mean trouble!
well, yesterday I finally replaced the KS on my beloved VE. After putting everything back toghether and getting ready to enjoy a couple more ponies at the wheels, I go to fire up the car and it sputters REALLY bad for about 5 seconds and then dies.
I say to myself, "it's probably because the fuel rails have been drained" So I try it again. I go to fire it up again, and same thing: it sputters really bad, and you can her popping from the intake and then it dies again.
I try the same thing one more time with the same results. At this point; it's obvious something is VERY wrong. I double check all my connections and hoses (from my experience with cars, I'm thinking there is a major vacuum leak somewhere but I can't see anything.)
At this point, I have no choice but to pull everything off. I don't understand, if I can replace my Tranny with no FSM, how is it that i $%^#ed up something so simple as a KS replacement.
Anyway, my question is very simple; any of you other guys have any trouble replacing your KS? From the symptoms that I have described above, are there any obvious things to check for?
Any help would be appreciated for the simple fact that i'm forced to drive my 5.0 now everywhere. I miss my VE!!!!!!!
man i miss my 5.0... way faster than Maxima...
I very much doubt the knock sensor is causing this problem.
I think you are right it does sound like a vacuum leak in the intake... though you would get the same popping if it was starving for gas too...
a common problem when changing the ks is when you put her back together. do you remember when you put the injector rail back on that there were 6 black o rings that the injectors sat on ? well they dont like to go back on easy and even though you may think they went on right DOUBLE check to make sure that they did it took me 3 tries and a new set of injector seats to get it to seal perfect. if they dont seat right theres your vaccumm leak and what is happening is your motor is running VERY lean thus your stuttering and stalling.....check that out first......
there are actually 12 injector o'rings.
most 5.0s are slower than the max.
of course it also depends on the 5.0
Maybe now is the time to start sellin 'KS' -trunk stickers for maxima people?
Originally Posted by Wiking
All that PAIN for the useless KS??? I am baffled at my american max bro's... Resistor bypass surgery is 1minute job, then one can drive with 95 octane 100 years and still be on positive in gas costs...
and the knock sensor will protect your engine from destroying itself.
in about a year you can save the cost of the knock sensor in being able to use the lower cost gas.
If octane vs timing is incorrect, that kills engine, with/out sensor. KS's the blondie safety device; those are imperative for those who have no clue of either.
Btw. Floatin vaseline is danGerous, crack sLippin dRiverskulls: hair color/qty does not count...
even if your timing is absolutely perfect, you can't control the screw ups filling your 93 octane tank with 87 octane.
Here it has to be done with diesel. Tell u what happens next in this blondie "TV": Service station nerds start to deinstall saab's tank (3hr job) to access (!!?!) that diesel oil. Luckily I get a call an make an loud objection. Just unplug the hose after pump and let the engine do tha job... Alas, the stations instant expert mech kids did not get their salary that day...
HUGE difference... these cars are not at all comparable for straight line acceleration. Don't get me wrong.. I love my Maxima already (after 2weeks), but Mustang is/was waaaay faster.
And once again, if you used proper gas in the first place, the KS is not needed to 'protect' the engine... that is only if you're cheap and think you'll save money by getting cheapo gas.
Originally Posted by Jeff92se
Too bad 93 isn't available in Oregon?
There have been many mildly modded VEs into the med-14s already. Check the 1/4 stickie
Hmmm... it depends on your definition of mildy modded I guess. I really don't see this as being an issue up for debate. The cars are 2 different classes for straight line acceleration.
If you have to adjust the timing lower than stock, what's the point? Especially if you have to granny the gas pedal and "listen for knock" Hard to do when some knock is beyond the hearing range of the human ear?
The early 5.0 engines were pretty sorry for 5 liters of displacement. And stock, they were nothing special. It's a shame that the comparison can even be considered, much less have similar times with a family 4-door sedan that's fwd.
Originally Posted by 92SE_Dave
This has to be the most blatantly stupid thing I have ever seen on this forum. ALL 5.0's run under 15 seconds stock. Do ANY Maxima's ?? Possibly the newest ones... but even a heavily modded 3rd gen can barely crack 15 sec barrrier, while lightly modded 5spd 5.0's can easily do under 14 seconds...
I'm sure that if I look I'll find quitwe a few that can't outrun a geo metro.
it depends on the year /options/etc.
but typical of a rustang owner unwilling to admit the car went through a typical power loss phase.
So you mean you go through the trouble to change your knock sensor.. for the sole purpose of running sub-standard gasoline ?? You do realize, that with the loss of torque do to retarded timing, that running a lower octance gas will probably not 'save' you any money, and may in fact cost more...
I like cheap insurance, and $130 is cheap insurance against doing a $500 motor (If i can find one that cheap)
And since you onviously know better than I do , I will end this conversation and probbaly won't reply to your other threads, I'll let you enjoy your ignorance.
1982 5.0 V8 mustang: 1/4 time: 16.1 sec.
http://www.maximum-cars.com/Cars/Car.php?carnumber=471
Okay let's give the mustang the benefit of the doubt and go with a 1994 model:
1/4 time: 15.0 sec flat.
http://www.maximum-cars.com/Cars/Car.php?carnumber=473
...And since you onviously know better than I do , I will end this conversation and probbaly won't reply to your other threads, I'll let you enjoy your ignorance.
This KS issue sits on the edge; what u say is really ok for general public [VE is different to VG etcetc]. But. Always there are people who survive agains all odds... and people who perish with life vest on. So lets those of us who want, drive without KS... I have already presented my points why I do it.
not all 5.0s run under 15 sec stock.
That is a ridiculous assertion.
Try a real 5.0 1987 - 1993 (0-60mph in 6.4 seconds bone stock)
I didn't realize we were encompassing all years possible... why not just compare a 2005 mustang to a 1st gen Maxima ??
I'm not trying to start an argument with you... it's just silly to say that Maxima's are faster than Mustangs.
I gave the mustang every benefit I could. A 1994 5.0 V8 vs a 1992 maxima. What do you want?? You got 2 more liters and 2 more pistons. The mustang is ford's sports car right?
In 1995, the 4-gen VQ was doing 0-60 in 6.7 sec.
Ok so you picked 2 of the SLOWEST possible mustangs, 82 is not a HO, it was a very early and underdeveloped motor, while the '94 was the next generation where they added 500 pounds and reduced power output by 10%... yet stiiiiiiillllll... they are faster than Maxima of the same years..
Also I took a look at the 1/4 mile thread and the average of 15.5 - 17 seconds was exactly what i expected.. in fact the very fastest one I saw taking a quick look was a heavily modded somewhere in the mid-high 14's.. like I said about what you expect from a STOCK 5.0 HO.
Originally Posted by tripleGmax
there is a VG nicely modded and boosted that is running 12s....faster than your mustang there boy.
so much for your very fastest statement
There are streat legal modded Mustangs running in the 10's... big deal.
lol youre so bitter! chill out dude!
It's ok though I like Maximas alot thats why I got one.
The 1992 Mustang 5.0 was the lx. I guess Ford has to result to the lightweight version to beat the maxima. Nice accomplishment I guess. It's a shame that a Ford V8 is even close to a Nissan V6. Nissan's V8 in 1992 was making about 280hp with 0.9 liter less.
Like I said you picked 2 of the slowest Mustang's and yet they are still faster than Maxima's of the same year. What are you arguing ? The Mustang is faster period no way around it.. I'm not talking about fuel efficiency or hp/liter ratio, # of pistons, or displacement.. just straight line acceleration and the Mustang has it beat hands down. Also why not compare a 92 Maxima to a 92 Mustang oh.. wait.. that would make too much sense...
Mustang KS? ...or KustangMS. Mustang is like BMW: Stuck in snow... never collects 60 in winter, if it will, next sec its in the ditch.
But how this ditch relates to KS?
I'm surprised this thread is still open
it's way
jeff - ford made the 92 lx as a last shot at beating the camaro before the Lt-1 came out and whopped it's a$$
Now lock this thread already!!!
it's way
