too rich with 259cc
Old 03-10-2005, 09:28 PM
95turbo gxe's Avatar
too rich with 259cc
Ok I put a set of 259cc in yesterday and the car is running dog rich. It want even idele or not blow nothing but black smoke out of the exhaust .
Well I have a safc 2 but nothing I do on it will seem to help. Mtcookson also has 259cc and I used his same # of his setting for the safc . They are working for him but nothing for me. OK I think the safc is making corrections because when I had the 180cc in their I could turn the fuel up or down and hear the motor tune change.
The only codes on ecu are the maf and coolent temperture sensor. Ok the maf is testing fine so I dont think thats the problem and I have tryed my spare.Ok the coolent temperture senor has been bad for a while I have replaced both of them with no luck of getting rid of code. But how do I get this bad boy to take the 259cc injectors.
95turbo gxe is offline
Old 03-10-2005, 09:52 PM
Eat, sleep, and sh*t 2JZ
DA-MAX's Avatar
are you sure that the injectors are seated correctly or if you didn't pinch one of the o-rings upon install?? I know it took me 3 times back in the day to get a set of injectors in the VG seated right when I did my first injector job.
DA-MAX is offline
Old 03-10-2005, 09:56 PM
well I checked for leaks and could not find any.
Old 03-10-2005, 10:01 PM
DA-MAX's Avatar
but thinking about it..i thought mt had his ECU reprogrammed for the 259s as well? or is he back to stock ECU?
DA-MAX is offline
Old 03-10-2005, 10:03 PM
no he did not finish it. he has stock ecu with the safc2 like me.
Old 03-11-2005, 01:53 PM
any Ideas anyone
Old 03-11-2005, 02:43 PM
mtcookson's Avatar
have you had a chance to check the resistance of the coolant temp. sensor yet?
mtcookson is offline
Old 03-11-2005, 05:48 PM
sleeper's Avatar
your ecu is programmed for stock injectors. try lowering your fuel pressure.
sleeper is offline
Old 03-11-2005, 08:39 PM
mtcookson's Avatar
turned out it was a broken wire that went to the coolant temp. sensor from when the crossmember broke. he fixed the wire and the afc started doing its job right away and leaned it out properly.
Old 03-12-2005, 06:36 AM
yeah its crazy how much the cooant temp. sensor controlls the fuel. But one more problem it seems to be realy hard to crank.
Oh yeah Mark out of the blue the dam throttle % just up and goes to working.
msellas
09-23-2015 09:16 PM
ballerchris510
09-10-2015 09:35 PM
AT978
09-06-2015 10:31 PM
punkdork
20
06-21-2001 12:19 PM
VQracer
10-15-2000 10:53 PM
Quick Reply: too rich with 259cc
