300ZX Brake Swap Complete
Old 03-07-2005, 08:23 PM
jblinga's Avatar
Here are some pics the swap and up to date pic of my 96' SE
I used the 91' Twin Turbo setup
Let me know how you think it looks
jblinga is offline
Old 03-07-2005, 08:29 PM
Doc
Doc's Avatar
Looks good. But the big question is, how is it working for you? Any hitches, or is it working well, as in stopping power, etc.?
Doc is offline
Old 03-07-2005, 08:30 PM
Skiptronic's Avatar
does it squeek? i hate that noise.
Skiptronic is offline
Old 03-07-2005, 08:57 PM
Zack342's Avatar
how hard was the install? Looks great?
what was needed to make it work
Zack342 is offline
Old 03-08-2005, 09:00 AM
jblinga's Avatar
I'm still breaking in the setup so I haven't really got on the brakes very hard yet. But all in all everything seems to be working fine. There was some squeking/minor grinding, but that is normal in breaking in new rotors/pads. But the main reason I did this swap is my stock calipers sucked(installed new rotors and I still had vibration in the pedal, this is common in all stock maxima calipers, my girlfriends' 5th gen has only 50K and it has the same problem). After replacing stock calipers w/300ZX calipers, this vibration is finally gone!
jblinga is offline
Old 03-08-2005, 09:10 AM
jblinga's Avatar
Overall the swap was easy, except I had to replace the steel brake lines from the master cylinder to the the wheel well on both sides due to my 96' having 135K and the fittings rounded off, but nothing to difficult!
300zx TT Aluminum Calipers(89'-91') 92'-96' have cast iron calipers,both work fine
300zx TT Brembo cross-drilled rotors(30mm)
240sx-300zx conversion stainless brake lines
jblinga is offline
Old 03-08-2005, 09:27 AM
Tha Snatcher
Iron Scimitar's Avatar
those calipers look sharp, great job on the paint!
Iron Scimitar is offline
Old 03-08-2005, 09:30 AM
I'm needing a caw
Jeff92se's Avatar
Just need to buy some 13" rotors and brackets from me.
Jeff92se is offline
Old 03-08-2005, 09:48 AM
MaxGordon7's Avatar
Can you just put on 300zx 30mm Calipers or do you need to replace the rotors and the brake lines too? I would like some more info or a write up on this, Also you need at least 17 inch rims right?
MaxGordon7 is offline
Old 03-08-2005, 10:28 AM
Minister of Silly Walks
mzmtg's Avatar
http://www.zeckhausen.com/bedding_in_brakes.htm
mzmtg is offline
Old 03-08-2005, 11:02 AM
jblinga's Avatar
Do a search under tt 300zx brake kit legit, this thread has Cheston's complete write up on the swap, the 300zx rotors are alot thicker than max rotors so i don't think you can run stock rotors, & you have to replace brake lines. I used 240sx-300zx conversion lines.
jblinga is offline
Old 03-08-2005, 11:11 AM
2 Da Max's Avatar
wow your car is beautiful, those are nice rotors
btw deezo your calipers are beautiful, do you have to keep cleaning the chrome? and imo i think you should at leas get slotted or crossed drils they will look sick. then again thats just me
2 Da Max is offline
Old 03-08-2005, 11:14 AM
DRIFFT MAX
Hey whats the cost for that swap, how much for the whole setup and where did u get it?
Old 03-08-2005, 01:59 PM
95nissanMax's Avatar
thats no chrome thats hours of polishing..HOT! i agree thuogh with the cross drilled idea.i also heard you can run 6th gen brakes and they are pretty big.
95nissanMax is offline
Old 03-08-2005, 04:32 PM
turbomaxima's Avatar
Those look hot how much did the calipers rotors and whatever else you needed cost?
turbomaxima is offline
Old 03-08-2005, 05:10 PM
jblinga's Avatar
Remanufactured 91' 300ZX TT front calipers 220$ after core credit from stock calipers Centric Parts Calif.
300ZX TT brembo cross-drilled rotors 154$ shipped ebay
240SX-300ZX conversion stainless steel brake lines 70$ shipped ebay
Brute stop raybestos pads 52$ checker auto
60$ to machine rotors down 6mm off the diameter Local machine shop
556$ total, not bad for four piston calipers, cross-drilled brembo rotors & stainless steel brake lines
jblinga is offline
Old 03-08-2005, 05:12 PM
jblinga's Avatar
How much for the brackets and what are they made of?
jblinga is offline
Old 03-08-2005, 05:45 PM
jblinga's Avatar
thanx for the info!!
here's a pic of the R35 Skyline GT-R
jblinga is offline
Old 03-08-2005, 06:20 PM
Kevin's Avatar
let me ask a questoin that noone has asked before, does this have enough clearance with 5th Gen SE wheels?
Kevin is offline
Old 03-08-2005, 06:26 PM
Custom User Title
Nismo3112's Avatar
Please resize your sig pic
Nismo3112 is offline
Old 03-09-2005, 08:10 AM
jblinga's Avatar
I asked this question on the 5th gen forums & they won't run w/out spacers
jblinga is offline
Old 03-09-2005, 08:16 AM
I'm needing a caw
Jeff92se's Avatar
Steel. $45 shipped.
Jeff92se is offline
Old 03-09-2005, 11:04 AM
MAXRB8's Avatar
Let me get this straight, 300ZX rotors bolt on directly with 300ZX stock rotors to our Maxima's along with steel brake lines (240sx to 300zx ebay). Is there a difference between 300ZX TT and NA rotors?
And if you want to go to 13" cobra rotors jeff92se sells conversion brackets?
Hey Jeff do you sell the any kits minus the calipers?
This looks like it kicks *** on other big brake kits on a cost factor.
I used to have a 300ZXTT and the braking was awesome, can anyone answer these questions?? thanks
MAXRB8 is offline
Old 03-09-2005, 01:05 PM
jblinga's Avatar
Everything is direct bolt on. There is a little work to get the rotors to clear but it is minor. The 300ZX TT rotors are 30mm thick, the N/A rotors are 26mm. All that is needed for 13 in. rotors is the brackets from jeff92se and the rotors themselves.
jblinga is offline
Old 03-09-2005, 01:13 PM
vsamoylov
this soudns itneresting. i just might want to do it also. i hear that you need to rebulid the calipers though?
Old 03-09-2005, 02:52 PM
MAXRB8's Avatar
Cool thanks! I just noticed when comparing the difference between TT vs NA rotors I mean't calipers!
MAXRB8 is offline
Old 03-09-2005, 03:38 PM
jblinga's Avatar
same difference!
jblinga is offline
Old 03-09-2005, 04:49 PM
MAXRB8's Avatar
A new project! thanks jblinga
MAXRB8 is offline
Old 03-09-2005, 05:27 PM
I'm needing a caw
Jeff92se's Avatar
What's needed to fit the 13" cobra rotors:
1) 1 set of adaptor brackets from me. $45 shipped.
2) 1 set of adaptor rings to fit the cobra rotors onto the maxima hub. Ford has a larger hub bore than Nissan, thus a hub ring is needed. I have ONE extra set but Candiman was the guy that sells them. $45 shipped.
3) 1 set of additional bolts/nuts/washers to hold the bracket onto the maxima spindle. YOu can use the stock hardware to attach the 300z caliper to the adaptor bracket.
remember 30mm calipers needed. I dont' sell the calipers or lines. But they are easily obtained.
Jeff92se is offline
Old 03-09-2005, 06:34 PM
z32drifter's Avatar
early production 89 and 90 model 300ZX NAs have the 26mm rotors... however after 91 all 300ZXs use the same brakes 30mm rotors ... I have the 26mm setup... it's been on the car for a year or so.... no problems ... brakes work fine.... however the fronts will lock before the rear in a panic stop... even more than normal... pedal feel is better than stock... fade resistance is better than stock..... I have never tried to measure the stopping distance.. I would guess small improvement if any
z32drifter is offline
Old 03-09-2005, 07:18 PM
hiphipmaxima's Avatar
alright let me get this str8, i have a set of 92-96 300zx rotors and calipers front and rear. I also have a set of steel brake lines.
is it just a matter of bolting everything on?
do i need to have the rotors milled 3-4 mm?
also do i have to buy the jeff92se brackets?
hiphipmaxima is offline
Old 03-09-2005, 09:00 PM
vsamoylov
what kind of rotors though? and is there a bbk for the rear also? and will this be effective and work on a 2k2 max?
Old 03-09-2005, 10:39 PM
baughb's Avatar
Calipers and Rotors dont clear 5th Gen 17"s do they?
baughb is offline
Old 03-10-2005, 05:53 AM
questwest's Avatar
just found this if anyone is intersted
http://www.jcwhitney.com/autoparts/P...splay/ss-10101
questwest is offline
Old 03-10-2005, 09:15 PM
jblinga's Avatar
sorry about the misinformation, apparently i don't have a p.h.d. in 300zx brakes, i was just going off of info from the org
jblinga is offline
Old 03-11-2005, 06:42 PM
Old 03-11-2005, 06:57 PM
z32drifter's Avatar
the calipers will bolt on..... make sure and use some washers to space the bolts if you use your Maxima bolts for the calipers.... they are a few mm to long and will damage the threads in the caliper.... you will have to remove the dust shields from the knuckle they will not fit with the Z rotors ..... you will need to have the diameter of the rotors machined ( I think it was 3mm) .... you may need to grind the ridge on the lower control arm to clear the rotor when the wheel is turned.... for brake lines.... you need the conversion line for a 240sx .. or you can use the factory lines from a 300ZX if you have the metal lines on the calipers.... allow yourself a day to do the install it sounds simple but the little adjustments and mods add up... and you don't need adapters if you are using Z rotors ... only cobra rotors
Old 03-11-2005, 07:05 PM
alright thank you for the info where can i get the conversion brake lines for a 240 also will stain less steel brake lines for a maxima work?
Old 03-11-2005, 07:14 PM
z32drifter's Avatar
look on some of the 240 sites...... I'm sure you can find the lines easy enough... you can not use the Maxima lines.....
Old 03-11-2005, 07:15 PM
STFU n00b!
Matt93SE's Avatar
Only way to get the Z brakes on the rear is to custom fabricate an entire new parking brake setup for it...
I sell all the parts you need for the conversion, as well as larger front setups using the 2004 Max rotor (12.6").
Bolts, lines, etc..
pics, prices, and specs here:
http://www.mattblehm.com/brakes.html
Matt93SE is offline
Quick Reply: 300ZX Brake Swap Complete
